EdZ
Professor EdZ
Reged: 02/15/02
Some information about the population of stars in M44 gives a very good indication of magnitude ranges. The 25 brightest stars all range between mag 6.3 to mag 8.0. M44 has 80 stars to mag 10.0 and has 100 stars to mag 10.9. My chart (see link) has just over 200 stars plotted, 140+ stars plotted within the boundary and 60 more within the 2° square periphery. I can see every star on this chart (plus more) when tested with my 5" scope that has a measured LM of 13.1, so this chart reaches to about mag 13.
Follow this for a link to the M44 Chart
On the west there is a very distinct N-S line of 5 bright stars (in a 8x40 it's 4 bright and 1 dim), running from top to bottom of the cluster. On the south there is a distinct string of mostly bright stars just outside the true boundary that I use as my defining limits. On the left (the east) there is a very noticable barren area that helps clearly define that edge. These recent observations overlooked 4-6 stars on the extreme periphery that were included in early observations.
Previously, With various binoculars I have seen
56 stars using Pentax PCF WP 10x50 sky5.2
67 stars using Fujinon 10x70 sky5.2
72 stars using Nikon Superior E 12x50 sky5.2
70 stars using Orion Minigiant 15x63 sky5.0
80 stars using Oberwerk 15x70 sky5.0
Under mag 5.0 skies, the Oberwerk 15x70 just reaches the limit of mag10 stars.
Here are results from recent observations over a two night period. Both nights were about mag 4.9.
42 stars - Captain's Helmsman 7x50
41 stars - William Optic 7x50
39 stars - Oberwerk Mariner 7x50
39 stars - Captain's Storm King (old single coated Swift) 7x50
40 stars - Bushnell Legend 8x42 roof
40 stars - Nikon AE 8x40
48 stars - Nikon AE 10x50
51 stars - Nikon AE 12x50
If I were to hazard a guess, I'd say 40 stars is mag 9 and 50 stars is about mag 9.6 to 9.8. In all cases, each of these binoculars saw just a few stars on the limit borderline needing averted vision.
Several other observations.
M81-M82 were both seen in all binoculars. In the AE 12x50, AE10x50, WO7x50 and CN7x50, both were fairly bright and some shape and orientation could be seen (elongated axis). The AE8x40, BL8x42, OM7x50 and CSK7x50, could not see these bright enough to say any more than both spots were seen.
Only one member of the M65-M66 pair was seen, and only in the AE12x50, AE10x50, WO7x50 and CN7x50, and in all cases just barely seen.
edz
-------------------- Teach a kid something today. The feeling you'll get is one of life's greatest rewards.
member#21
Randy Cordell
Reged: 09/16/07
Loc: Cedar Rapids IA
Hi Ed. This post prompted me to go out and examine M44 last night with my 7x50M's. I've never spent any time looking at it. I was trying to count stars hand held and it was immediately evidient to me that I didn't know how large an area is considered part of M44. I saw the chart through the link above and then through the link found there. It still looks like there are many stars that are borderline and just outside of the circle. I guess that is why you suggest printing it and then circling all the stars you can see. This can be pretty challenging I assume in figuring out which of the stars on the chart are in the eyepiece but it sounds like a fun challenge. It's also very interesting to attempt to determine the magnitude the instrument can resolve. The number of stars that can be counted can be somewhat subjective (depending on where a person defines the line of the circle lands) but the magnitude of the stars that are visible is less so. Would you count everything visible with averted vision? I seem to have pretty bad direct vision for all except the brightest objects so i use this a lot.
Thanks for an interesting (and yet again, exhaustive) post.
May the day-time nourishing rain always clear for night-time viewing!
-------------------- Randy Cordell
Meade StarFinder 10" F/4.7 Dob, Telrad, Craford, Fans
Bogen 3040 and 3050 Tripods with Orion Paragon-Plus Parallelogram or 3047 head
Pentax PCF WP 8x40
Garrett Optical Gemini 15x70 WP-IF
Laptop running Kubuntu and Stellarium 0.9.1
EdZ
Professor EdZ
Reged: 02/15/02
Always. The limits of every binocular are always found in what can be seen with averted vision. If you don't test to the averted limit, you are never finding the limit. You might see stars at the limit of magnitude reach for only 5-10 seconds out of each minute you look at the spot.
I have two other charts, one for Cr399 and one for M45, that I originally developed just for doing star counts. later, both charts were detailed with the magnitude of all the individual stars on the chart. I haven't yet developed my M44 chart that far. But I know from experience and from research what some of the counts represent.
Once you've used a chart and get to know the patterns, star counts are easy. I know this chart so well, having used it so many times, that I can draw a sketch of about 70-80 stars in M44 from memory. I could put another 30-40 on the chart to show the dense areas, but they wouldn't be accurately placed. I'd say it takes me no more than 2-3 minutes to count 40-50 stars in any 7x50 - 10x50. But I could spend another 5 minutes more to scan around with averted vision to see if any stars more pop into view. So the first 40-50 take 2 minutes, the last 2 or 3 take 5 minutes.
edz
member#21
ronharper
Reged: 02/14/06
Ed, Don't think we don't appreciate this study, just because we are rendered speechless and dumbfounded. This sounds like a real observing challenge, which would improve anybody's skills. I would guess the final few stars would depend as much on who, as through what. I am trying to muster up the necessary retinal energy for this one. Thanks especially for getting down to the nitty-gritty of how you do this.
Personal differences and challenges aside, it is a wonderful real-life way to compare binoculars. It sounds like hard work to us typical lazy bums, but I trust that for you it was fun. Ron
RichD
Reged: 11/08/07
Loc: Derbyshire, UK
Its a beautiful cluster in 16x70 binoculars, perfectly framed.
I tend to just stand and stare at it though rather than count - we're all different.
-------------------- Clear skies
Rich
RichD
Reged: 11/08/07
Loc: Derbyshire, UK
Forgot to say - thanks edz for the post
Rich
EdZ
Professor EdZ
Reged: 02/15/02
always welcome edz
member#21
jrw11
Reged: 06/09/07
Loc: U.S.A.
Ive also liked the view in my 20x80's
-------------------- Celestron C6n -HD Reflector
dual axis drive motors added
Orion 80mm Short tube refractor
Skyscout
Early 70's Pentax 7x50
Garrett Optical 12x60
Garrett Optical 15x70
Oberwerk 20x80 Standards
Canon Rebel Ti (film)
4 Minolta Srt cameras
Mamiya RB67 Pro-s with 180 lens
127mm KL lens for RB, Bellows hood for RB67
120 and 220 film backs
over 50 other film cameras
several eyepieces
Reverie
Reged: 03/27/08
Very interesting topic!
I could count only 20 stars with 10x50.
Air pollution, light pollution, poor weather...
I hardly get a decent result in my location.
I counted more than 20 with 15x70 5 years ago. Unfortunately I lost most of my observation log.
-------------------- Where are the stars now? Where would I have to go in order to see them?
I walk forth into this fractured world, yet my thoughts were forever of the sky.
~Reverie Planetarian~
Randy Cordell
Reged: 09/16/07
Hi Ed,
I got to spend a long time under a pretty decent sky last night. I had my 15x70's trained on M44 for a long time. Our club had their public night last night so there were a lot of people coming and going. I noticed something I have NEVER experienced before and wonder if this is a usual thing or is it atmospheric dependent? While viewing the cluster the very "center" small triangle asterism of three stars appeared to be deeper than the rest. Actually there were two or three sets of stars that appeared this way while looking at the center. However, any stars I looked at directly would appear to move back and become sharper and cause the same three dimensional feel. Have you ever seen anything like this? It was quite unusual. I have a new pair of glasses (a whole different subject!) but wonder if I just was not seeing what everyone else does prior to this? This was using my 15x70's.
As for counting how many stars I could see....I uh...ah-hem...have a printed copy of your chart with me every time I'm out...but in the excitement never seem to get to that count.
Pentax PCF WP 8x40
mttafire
Reged: 02/02/06
Loc: midwest
I was just looking at M44 night before last w/ my 15x70's. Good seeing but i didnt count..just looked this night out. Tonight, Im wanting to go out around 11:30 for another look and also try to find the Sombrero Galaxy. I sometimes CAN and sometimes CANT see it. Even when viewing seems to be the same. Hopefully tonight will be a successful go at it. Should be clear and dark!
-------------------- God Bless America
Binocular astronomy
for me ONLY.
8x45 Garretts
15x70 Skymasters
2 eyes!
EdZ
Professor EdZ
Reged: 02/15/02
sorry to say, I don't recall experiencing this. I would say it is not usual. I would also say it is not atmospheric dependant. I would say it is an illusion, perhaps for you a very neat illusion.
BTW, I had my new Nikon Prostar 7x50 out a few days ago. I counted 45 stars on the M44 chart. LM at the time was about mag 5.2. very early next morning, while observing Cr399, I could clearly see several stars of mag 9.1 and I suspected seeing one star at mag 9.3.
On the same evening I had out my Oberwerk 25x100 and I counted 129 stars in M44.
Also saw NGC 3628 along with M65 & M66 thru the 25x100. Only one member of the M65-M66 pair was seen in the 7x50.
edz
member#21
Randy Cordell
Reged: 09/16/07
It was very strange and I've never seen that before. I didn't think to try without my glasses. But what I noticed earlier in the evening was that without them my astigmatism is apparent. I never noticed this before either. I am learning new things as my observation skills get more refined, I guess.
How do I determine the limiting magnitude where I am observing? I think there are certain star groups that depending on which stars are detected by naked eye, the LM is determined?
Pentax PCF WP 8x40
EdZ
Professor EdZ
Reged: 02/15/02
see the Best of thread on NELM and use some o the labeled charts in the links.
edz
member#21
RussL
Reged: 03/18/08
Loc: Cayce, SC
Well, thought I'd give a try at counting tonight with my Ultima DX 10x50s. My sky is pretty light polluted, so I didn't expect to see many stars, but I did the best I could, also using averted vision. The biggest problem I had was trying to count while hand-holding the binos. So, I took a long time staring with my head leaning back against my truck cab. That helped some, but things were still fairly shaky. Without overestimating, I'd say I could make out about 20, maybe 25 stars of various magnitudes. That's also guessing at the field indicated on the chart in the link as I didn't have a printed copy with me. The sky was clear and the air was fairly steady, although there was some haze to the east. How far the edges of that haze reached I couldn't tell for sure. I'll try again another night to see if I can see more.
-------------------- --Russell
"Akita mani yo." Observe everything as you walk. (--Lakota)
Celestron Celestar 8 Standard SCT, f10
Celestron 80mm Wide View ref., f5
Criterion RV-6 Dynascope, Newt., f8, (c. 1962)
Sears Discoverer 60mm ref., f7, (c. 1973)
Celestron Ultima DX 10x50, 6.5 TFOV
Tasco 7x35 wide
Several mediocre eyepieces
BobinKy
Reged: 04/27/07
Loc: Country road
EdZ--
This is an excellent observing thread. Thank you for leading us through the process and sharing your experience.
I do a similar exercise using the SkyHound 2 observation planning software. First, at the computer, I select an area to view, draw FOV circle(s) centered upon the brightest star for each of the various binoculars I will be using, and set the star magnitude for each chart.
When I print out the custom star charts (one for each binocular per target area), I have on paper the stars/DSOs that should be visible within my eye cups.
In the field, I mark those stars/DSOs on each instrument's custom chart.
An added caveat, sometimes I go back inside and click on the marked stars to identify their designation. Knowing a star's designation or name is often just a catalog number, however, I have a label for each star/DSO that appears in my eyecups. Similar to carrying a bird or wildflower field guide on a hike in the woods in order to identify what you stop and observe.
-------------------- Bob
38° Kentucky, USA
RussL
Reged: 03/18/08
Loc: Cayce, SC
The sky tonight was not quite as clear in some areas, but I gave it another go in my 10x50s, counting 15 or so of the brightest stars. This may sound strange, but during three tries at counting I began to notice a configuration that oddly reminded me of the shape of the Hyades. Once I saw it I could in no way avoid interpreting it as such as I tried to count again. I was facing southwest basically so as to be "in front" of the cluster. This was at 9:45pm. I tried to orient myself on the chart, but due to the large number of stars on the chart I was unable to discern the shape I was seeing. Nor am I able to tell if the chart is oriented as if facing southwest. Of course , I have never scrutinized the Beehive this much and so I am quite unfamiliar with it's geometry to such a degree. I tried lying on the ground, but it was no better than leaning on my truck or back in a chair. Perhaps the Hyades-like configuration I saw was an effect of my limited sky conditions, or perhaps merely something my brain translated as such. Nonetheless, it proved to be a tool by which I counted stars time after time. An abbreviated chart might help me tell just which stars I am seeing. Interesting.
Tasco 7x35 wide
EdZ
Professor EdZ
Reged: 02/15/02
I know the configuration about which you speak. It's about 2" below the center on my chart. It points to the right on the chart. It could be described as the Hyades. I call it Cepheus.
There is also a Cassiopeia figure on the M44 chart, but it is only seen in it entirity when using 100 binocular telescope.
edz
member#21
Rich N
Reged: 09/22/04
Loc: San Francisco Bay Area, Calif...
Hi Ed,
Very intereting list of star counts and the binoculars used.
Sorry if I missed it, but are you doing these counts with all the binoculars mounted or hand held?
Thanks, Rich
EdZ
Professor EdZ
Reged: 02/15/02
mounted. handheld the counts go down considerably. Mounted this is essentially a test of limiting magnitude, although i don't have this chart labeled as to magnitudes, obviously more stars is fainter. Refer to the original link in this thread for all other observations using this M44 chart, Cr399 (50-60 mags labeled), and M45 (250 mags labeled to mag13.0).
edz
member#21
