Privacy Policy |
Please read our Terms
of Service | Signup and
asaint
Reged: 04/25/03
Multi-Reticle Finder
Alan K
Reged: 09/21/05
Loc: Atlanta, USA
Ray,
Nice article. I have been noodling over the purchase of a Rigel Quickfinder. I wonder how it would compare?
Alan
-------------------- Meade LX90 (8" f/10 SCT), Orion StarBlast (4.5" f/4 Reflector)
Tom Trusock
Reged: 02/26/02
Loc: Alternate Reality (TM)
Well, IMO, even the first setting on this finder - at least the WO version (as on most RDF's) is a bit too bright. The rigel gets much dimmer, pulses and provides a calibrated ring for star hopping.
However - if I were picking one for a refractor, I'd get the MRF (or other RDF). A big dob the telrad, a small or medium dob or SCT the Rigel.
my .02 cents.
T
-------------------- There are two theories to arguing with my wife. Neither one works.
rob cos.
Reged: 03/11/04
Loc: Plymouth,Ma
How does one align this finder?
Even with my refractor, i've continued to use the telrad. Can't help it, I just love using the big guy. I take it off the Dob and pop it on the refractor.
-------------------- Rob
Antares 10"f/4.9 Dob w/ DBA Birch Base and Sky Commander
Antares 1529 6" F/6.5
UA Unistar Deluxe w/encoders
LXD75
ETX125PE
Eyepieces:
University Optics
Harry Siebert
TMB/Burgess
Alan K
Reged: 09/21/05
Loc: Atlanta, USA
Thanks Tom,
I can see how size would make a big difference on a small refractor, an an advantage for the MRF. The Rigel QF seems about right for an SCT (I think the hieght to see over the OTA would be a bonus).
Alan
Anonymous
Unregistered
I bought my MRF [edit] for quite a good price. The all metal construction is attractive and gives the impression of quality and it is much much smaller than a Telrad. My window has some sort of reflective optical coating (I guess to bounce the LED light) which does reduce transmission. Trouble is I still haven't mounted it onto my NightHawk as the dovetail is due to arrive from Burgess who sells it for a mere $9.
Armand
Edited by shankandbrisket (11/21/05 10:53 PM)
Chris Schroeder
Reged: 12/11/04
Loc: N.E. WI Sky Glow
I own the WO's version, I like the MRF and find it easy to use, it could use a dimmer setting though. On the dimmer stars or DSOs, the MRF at it’s lowest setting is still to bright and washes out the target, although it gets me close enough when using a low power EP in my scope.
-------------------- Chris
Mallincam Color Hyper Plus
10" DSH with SC DSC, CPC 800 XLT
M102ED S.V., ZS 80FD 10th Anniv, ZS 66SD, PST
POD XL3 http://POD.SchroederCity.com
Anonymous
Unregistered
I have had a Telrad on my 6" f8 newt. for years and have no complaints.
I recently purchased the Rigel finder, which I use with my 15x70 binos.
Bottom line, I much prefer the Telrad. I am using the Rigel simply because the Telrad is too big for binoculars. The Rigel at least has a circle instead of a dot like some of the other smaller finders I looked at.
doug76
Reged: 12/05/07
Loc: SE Louisiana
After my Telrad, I really like these type finders. My 1st one came with my Lightbridge, and when I replaced it with the Telrad, I mounted it on my grandnephews ETX-90, which helped that scope immensely. After acquiring the AT66ED, I bought the Burgess MRF to mount on it. Perfect finder for this small scope. I have even mounted it on my air rifle to take out turtles on my pond. Works good for that! Doug
-------------------- Doug
The Truckstop Astronomer
Meade 12" Lightbridge/Dob Driver II
Celestron C6 SCT
Celestron C6R/Moonlight focuser
Celestron XLT150
Astro-Tech AT80EDT
TOWA 60/700 (under construction)
Celestron CG5-ASGT, CG-4
Celestron Nexstar SE (large)
Meade SWA 34mm
Televue Panoptic 24mm
Pentax XW 10mm, 7mm
Astro-Tech AT66ED
Celestron Nexstar SE (small)
Televue Plossl 32mm
Smart Astronomy Solar System 14.5mm
BO/TMB Planetary 9mm, 7mm, 5mm, 4mm, 3.2mm, 2.5mm
2 registered and 6 anonymous users are browsing this forum.
Moderator: asaint, spaceydee
