Other >> Science of Astronomy & Space exploration
LateViewer
Reged: 11/17/05
Loc: Westchester NY
Double Slit Experiment new
      #2324528 - 04/13/08 04:15 PM
Is it possible to do the famous double slit experiment in my basement?
I need to see this for myself.
Al
12.5" Discovery String Truss Dob
DSV-1 Alt-Az Mount
WO 66mm Petzval
Orion 127mm Mak with WO 2" Dielectric Diagonal
Celestron CG-5 GoTo
8.8, 14, 18, and 24mm Meade UWA Series 5000 EP
32, 40mm Orion Optiluxe EP
photonovore
Moonatic
Reged: 12/24/04
Loc: tacoma wa
Re: Double Slit Experiment new [Re: LateViewer]
      #2324664 - 04/13/08 05:53 PM
Yes.
Here is the college version of Young's experiment and here is the high school version.
Mardi
4" achromat, ETX-70.
Whitepeak Lunar Observatory Website
Jarad
Reged: 04/28/03
Loc: Atlanta, GA
Re: Double Slit Experiment new [Re: photonovore]
      #2324923 - 04/13/08 08:24 PM
To put into amateur astro talk, use a barlowed laser collimator as your light source. Take a cheap back-silvered flat mirror out of a makeup set, and use 2 razor blades held against each other to scrape out 2 parallel slits from the silvering in back (the slits should be very close together). Shine the barlowed laser on the slits, and put a white piece of paper in front of the mirror, and turn out the lights. Voila - Diffraction!
Jarad
Dane B
Reged: 02/23/08
Loc: Seattle, Wa
Re: Double Slit Experiment new [Re: Jarad]
      #2325196 - 04/13/08 11:00 PM
Interesting, but what I'd really like to see in person is the diffraction pattern from photons or electrons sent one by one through the slits. And even better, the loss of diffraction upon creating a means of detecting which slit each particle passes through.
That sounds a bit more high-tech than can be done as a DIY project - hope I'm wrong though.
Meade DS-2130AT w/ GOTO
Nikon 12x50AEs
Without judgement what would we do? We would be forced to look at ourselves...
-Death
matt
Vendor (Scopemania)
Reged: 07/28/03
Loc: Chaville, France
Re: Double Slit Experiment new [Re: Dane B]
      #2325527 - 04/14/08 03:45 AM
well, the laser or sunbeam experiment shows you photon diffraction. Electron diffraction requires an electron "gun" and an "electron screen" (basically the business end of a TV tube), which would still be available to an enthusiastic amateur physicist (if we could do it in high school, I guess it can be done in a basement) but might be a little beyond what you can buy at Radio Shack.
Matt
CI700 mount with various scopes on top.
LateViewer
Reged: 11/17/05
Loc: Westchester NY
Re: Double Slit Experiment new [Re: matt]
      #2325789 - 04/14/08 08:45 AM
Well I did the experiment with a laser and a card and certainly saw the interference pattern at the short distance of two feet from the card to the wall.
Cool.
The show at my theatre, Gypsy with Patty Lupone, has a bunch of kids in it. Over the weekend I showed them a small motor I made with a battery, paper clips, some wire and a magnet. I think I will show them this demonstration next.
Al
Edited by LateViewer (04/14/08 08:46 AM)
AleX`G
Reged: 05/29/06
Loc: Scotland UK
Re: Double Slit Experiment [Re: LateViewer]
      #2328709 - 04/15/08 12:25 PM
Yer sure you can but I think it might be harder using electrons you would need quite a high resolution imaging system with bright lights.
http://www.upscale.utoronto.ca/GeneralInterest/Harrison/DoubleSlit/DoubleSlit.html
As im sure you most likely know although this effect appears to be a contradiction of our particle-wave theory it is in fact explained by the uncertainty princible in quantum dynamics.
Alex
Celestron/Vixen 102 f9.8
Vixen GP
Canon EF300mm f4L USM (non IS)
Canon 300D
Never express yourself more clearly than you think. - Niels Bohr
0 registered and 2 anonymous users are browsing this forum.
Moderator:  llanitedave
Home
