Petewp
Reged: 12/04/06
Loc: Connecticut - central western
Patrick Moore -[who clearly isnt one of my favorite authors] claims that an 8" telescope can resolve 1.1miles on the moon. that is, a crater half filled with shadow. Too, he goes onto continue and sais the finest rille is 1/10 that resolution - linear.
He bases his claims on his 33" refractor observation of a 500 yard crater resolved - half filled with shadow.
what do you guys think of his claims?
Pete
-------------------- SEEKING LUNAR/PLANETARY NEW ENGLAND OBSERVING NIGHT - all welcome. Contact me at tidalid@aol.com
8" F/9 Parks Reflector
70mm TeleVue Ranger
Previous owner of Parks 10"F/5,
David Knisely
Reged: 04/19/04
Loc: Beatrice, Nebraska
Pete
From my own limited studies using the old LAC charts, I found Moore's estimates to be fairly accurate, although they might be a tad on the conservative side, especially for those doing high-contrast lunar imaging. Just using the formula d = 9/D, where d is the crater diameter in miles and D is the telescope aperture in inches tends to give results similar to those in Moore's table. Clear skies to you.
-------------------- David W. Knisely
Hyde Memorial Observatory
http://www.hydeobservatory.info
Tom Faller
Reged: 08/07/06
Loc: Atlanta, GA, USA
Going out on a bit of a limb, I've got an 8" Dobsonian with a pretty good mirror set and when I get good skies, I can count several craters in Plato's floor I've heard described as being a mile across. Linear features are tougher to estimate because you can pick out lines easier than dots, but it may be difficult to tell if the contrast is the same as with a crater. Still no flag or boot prints...
-------------------- Tom Faller
80mm StellarVue Nighthawk refractor
127mm Orion Maksutov-Cassegrain
200mm homebuilt Dobsonian with Discovery optics
10x50 Carton Adlerblick Binoculars
12" homebuilt truss Dob with Discovery optics
David Knisely
Reged: 04/19/04
The central craterlet is 1.7 miles across, while two others are 1.5 miles across and another one is 1.3 miles in diameter (the "Big Four"). There is a smaller one near the western edge of the floor that is 1.2 miles across and another one near the eastern edge that is about 1 mile in diameter. After that, things get somewhat harder . Clear skies to you.
Thunderhead
Reged: 08/27/05
Loc: Melbourne, Australia
I have seen 8 Plato craterlets with my 10" dob, and seen craters about 2km across near the Straight Wall.
Edited by Thunderhead (04/18/08 03:18 AM)
Petewp
Reged: 12/04/06
Hi Dave,
You know, that limit that describes 1.1 miles for an 8" aperture assumes a half filled crater -so REALLY - arent we just seeing HALF mile crrater at that point. Said another way, suppose we have a crater as wide as a half mile across but otally filled with shadow save for its rim walls. Than is could be said the smalled crater an 8" aperture can resolve is .55 miles across. True?
Im not trying to be funny Dave. Honest - if its only half filled, at that threshold level, we are only making out that half of the crater which forms that speck, or "pepper spot" if you will. Are we really seeing that other half of lit crater detail or does it just blend into everything leaving us that most minute speck of a shadow to call a crater?
I guess my upshot here is that perhaps if we observe close enough to the terminator where craters are virtually all black inside, we can actually reduce the actual size of the crater we call a "limit".
Pete PS: Funny enough with plato - i find the full moon isn't such a bad time to go looking for those "famous four" as they appear like white specks.
70mm TeleVue Ranger
David Knisely
Reged: 04/19/04
Hi Dave,
What I see as a "resolved" craterlet is a tiny pit with both a bit of internal shadow and a clear form of visible rim (not a "single pixel" dot). This is where I use the 9/D formula and find it to be fairly accurate for giving a reasonable crater resolution minimum for a given aperture with the appearance constraint mentioned above. I can see the very tiny white dots of the "big four" Plato craterlets in my 90mm Mak-Cassegrain under a high sun angle, but I cannot resolve them into the true pits that they are. They simply aren't there when the sun is low, making Plato's floor look blank (I can sometimes see the central one as a light dot, probably from light reflected from the raised ramparts). In my 10 inch, under halfway decent seeing and low sun angle, I regularly resolve the "big four" and at least two more as pits depending on the shadow length near the east or west walls of Plato. My own personal record is around 10 or 11 craterlets visually, although images and some processing tend to bring out a few more that are difficult to see. Here is an older "map" of the craterlets of Plato:
A = 1.7 miles (2.7 km) B = 1.5 miles (2.4 km) C = 1.5 miles (2.4 km) D = 1.3 miles (2.1 km) W (on west-northwest wall) = 2.0 miles (3.2 km)
e = 1.2 miles (1.9 km) f = 1.0 miles (1.6 km) g = 0.94 miles (1.5 km) h = 1.4 x 0.8 miles (2.2 x 1.3 km)
i = 0.7 miles (1.2 km) j = 0.6 miles (1.0 km) k = 0.7 miles (1.3 km) l = 0.6 miles (1.0 km) m = 0.7 miles (1.1 km) n = 0.7 miles (1.1 km) o = 0.7 miles (1.1 km) (double craterlet) p = 0.7 miles (triple craterlet) q = 0.6 miles (1.0 km) (double overlapping crater)
Mare Nectaris
Reged: 03/09/08
Loc: Toijala, Finland
Hi David,
what would you say of a pic that overprocessed reveals the eastern wall even slightly?
How "real" a resolvement could this be said to be - or am I just seeing things on this?
I only found this feature out by overprocessing my previous pic as I was hinted by Brian Albin that this section of Plato was in the pic looking first like a tiny amount of snow on the wall of the crater Plato... See this thread for the original and the hint I was given (the original pic is in the 2nd set of thread and this link gets you directly to the beginning of the 3rd, so go back a bit from there if you want to see the original pic):
http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Board/Imaging/Number/2254407/page/1/view/collapsed/sb/5/o/all/fpart/3
Please, note all that this pic in here is INTENTIONALLY OVERPROCESSED very hard to get out the detail Brian suggested!
Be well all!
-------------------- Share - and you shall have it all
Timo Keski-Petäjä
CtheMoon
Observation shelter KuuMaja (MoonHut)
TAL 250K*Celestron C8-N*SkyWatcher Skymax 150 Pro*TAL1(Mizar)*EQ6 Pro SynScan*Celestron Advanced GT (CG-5 GOTO)*Baader Hyperion Clickstop Zoom 8-24*17 mm UWA-70*TeleVue BIG 2x Barlow*Celestron 2x Barlow Ultima SV Series
Edited by Mare Nectaris (04/19/08 06:13 AM)
Petewp
Reged: 12/04/06
You know it would be interesting to see progressive images - even in theoretical diagram of what would happen to a crater as it progressively passed the dawes limit. We know doublestars elongate [I think they just overlap], but craters have their own nifty way of fuzzing out. Itd be neat to see the progressive examples of this.
Pete
70mm TeleVue Ranger
Petewp
Reged: 12/04/06
Dave whats that scope behind you in your pic? Looks like a 7" mak - am i right?
Pete
70mm TeleVue Ranger
Jim Mosher
Reged: 05/22/06
Loc: Newport Beach, CA
Patrick Moore ... bases his claims on his 33" refractor observation of a 500 yard crater...
Pete,
I'm curious to know where you found Patrick Moore's statement about being able to see a 500 yard (460 m) crater half filled with shadow using a 33 inch refractor? Did he mention the occasion, or which crater he is referring to? This sounds like it might be related to the table mentioned by David, which in turn sounds like it might be related to the one appearing in an Appendix to Wilkins and Moore, but which doesn't refer to observations by Wilkins or Moore. And, as Mardi has pointed out, despite claims of this sort, few of the detailed drawings in that book, including the many said to be made using the 33 in Meudon refractor in Paris show any reliable detail beyond about 2 km. That includes Wilkins and Moore's drawing of Plato , which shows no craterlets that can be identified with certainty beyond ~2.0 km diameter (David's "Big Four"). One possible exception is Wilkins' detailed (and almost incomprehensibly cluttered) plan drawing of Ptolemaeus which might, charitably, be supposed to show occasional real details at the 1.1-1.2 km level in small areas.
I don't know what Moore might personally be able to see with an 8" telescope, but as explained in some detail in the other thread, a skilled imager, like Bob Pilz, photographing with a blue filter, and using the latest image processing techniques on sequences obtained under conditions of good seeing can fairly consistently detect craterlets in smooth mare under favorable lighting conditions down to around 1.1 km. So that agrees with Moore's number, but implies reliably detecting something like 16-18 craterlets on the floor of Plato, which from David's comments is a bit unrealistic for a visual observer using the same aperture.
Correction: 1.1 km doesn't agree with Moore's number. I'm constantly getting confused in switching from miles to kilometers. Moore (following Whitaker) is giving a 1.1 mile or 1.77 kilometer visual limit for an 8" telescope, which corresponds to about 6 Plato craterlets. That indeed seems reasonable for an 8" aperture. 500 yards (0.5 km) for visual observations with a 33" probably is not, at least based on Wilkins and Moore's own much less impressive results: a 0.5 km limit would imply being able to reliably plot a couple of hundred Plato craterlets, something they certainly did not achieve.
Your suggestion that the increased amount of shadow at low sun might enhance the detectability of small craters is an intriguing one. Some of the Apollo images certainly give that impression. Tiny fresh pits can also be seen with higher sensitivity at very high sun because of their brightness, but it's impossible to tell, in that case, which of the tiny dots are craters and which are dusted hills. As you say, it's not clear the best angle for detecting small craters has been studied in a quantitative way. Things aren't always as we assume (or as they appear to be).
-- Jim
Edit: correct 1.1 miles --> 1.77 km
Jim Mosher
Reged: 05/22/06
David,
Inspired by the fine work of you, Mardi and Chuck Wood in preparing crater sequence charts like this, I posted some new measurements of the Plato craterlets on the-Moon Wiki. The main diagram gives the kilometer-diameters of all the circular craterlets to a diameter of 0.9 km, while a text file gives the positions and diameters of 111 Plato craterlets, ranked by size, including all larger than about 0.7 km.
Regarding "Moore's table" and his "d = 9/D" formula, in which of his many books does this appear? As I mentioned to Pete, it sounds very closely related to the formulas and table appearing in an Appendix to Wilkins and Moore. But the latter is not the work of Moore or Wilkins, but rather that of Ewen Whitaker, who contributed that Appendix on Lunar Photography. Despite the title, at least as it appears in their 1961 edition, the table expresses Whitaker's own very definite views on the limits of visual observations (which he apparently thought of as the ultimate goal which photographs might someday approach, but not exceed), which I think are based on his own experience, rather than Moore's.
The table is simply a listing based on the following principles which Whitaker says he established experimentally for visual lunar observations through telescopes having an aperture of D [inches]:
(1) The diameter of the first dark ring of the Airy pattern = 10.9/D arc-sec. (2) The apparent diameter of the central disk is 0.8 of this diameter (one doesn't see quite to the ring) = 8.7/D arc-sec (3) The lunar image can be thought of as a myriad of tiny detail elements. These elements are 3/8 the diameter of the dark ring = 4.1/D arc-sec. (4) The true diameter of the smallest crater that can be detected as such (by juxtaposed light and shadow) is 9/10 of the Airy disk diameter = 7.8/D arc-sec. (5) The true size of the smallest "line of shade" that can be detected is 1/20 the Airy disk diameter = 0.44/D arc-sec; but as seen in the telescope it will appear up to 8 times larger than this.
Moore's claim of a detecting a 500 yard crater (0.25 arc-sec at the Moon's average distance) crater with a D = 33 inch refractor is quite consistent with Whitaker's formulas (7.8/33 = 0.24 arc-sec); but one might wonder how Moore knew that the actual size of this marginally-resolved crater was 500 yards? He wouldn't have had any higher resolution photos to go by. His assertion that an 8-inch telescope will resolve less than that in the proportion 8/33 (i.e., 1.1 miles) is also in agreement with Whitaker's principles (and matches the value listed in Whitaker's Table), although Moore's claim (cited by Pete) about a 10X advantage in detecting rilles is less optimistic than Whitaker's (who estimates an 18X advantage).
Whitaker's table begins with a listing of a 9 mile crater threshold for a 1" telescope, which would seem to be the basis of Moore's formula (although Pete says it is based on observations with a 33" telescope).
Unfortunately Whitaker doesn't explain what sort of experiments he conducted. He might possibly have looked at the Moon through very small apertures and noted the appearance of objects whose true dimensions he knew from observations with larger instruments. Alternatively he might have looked at terrestrial targets of know size (e.g., threads or lunar photos) through a variety of apertures.
Whatever experiments were conducted, the table extends the results to visual observations with apertures as large as the 200-inch Palomar telescope (the largest of that day) on the assumption that the resolution will improve in inverse proportion to the aperture. But there is no disclosure as to whether any attempt was made to verify the results given in the table for any of the larger apertures listed there (and, as noted above, in the absence of high resolution space photos it would have been exceedingly difficult to know what size features were actually being detected and missed).
-- Jim
Petewp
Reged: 12/04/06
Moores books is titled: The Amateur Astronomer published by Norton. Below is the paragraph above the table where he makes his claim:
"The following table [based upon the work by E.A. Whitaker ]gives the approximate diamters of the smallest crater half filled with shadow and the narrowest black line certainly distinguishable. Obviously different observers will have different results but using the Meudon refractor in Paris during the pre apollo period, when i was engaged in moon mapping, I recorded a craterlet at the summit of a mountain near BEER that was only about 500 yards across"
-Patrick Moore (c)1990
There you go - now to find that mountain peak! It seems plausible as the same ratio applied to an 8" yields that 1.1 mile crater .
You raise good questions about how he could know the size of the crater he observed at that point in time. I dont think he could. BUT - the numers seem right in theory. For all we know he observed a crater a good 2/3's of a mile across.
Pete
Edited by desertstars (04/25/08 12:19 PM)
Petewp
Reged: 12/04/06
Jim,
Doesnt this all scream for someone to do some definitive test to settle this once and for all. For the life of me I thought about doing some land based kind of resolution grid with circles and strings and bars etc. But' itd never work. Even if the dots were say 1/4" and smaller, its still so far away that the turbulence over land would blot out all attempts of really getting to the bottom of anything. Its a nice idea that for now seems pretty impossible to really achieve - for the moment.
Pete
70mm TeleVue Ranger
David Knisely
Reged: 04/19/04
Well, there is so much noise in the over-processed image that it is difficult to see much, but overall, I would say no, there does not seem to be much in the way of any Plato craterlets in the image. The somewhat milder original image does seem to show a central brightening which corresponds to the ejecta blanket and craterlet in the middle of Plato (my "A" craterlet), but it is not resolved as a definite relief feature. Clear skies to you.
David Knisely
Reged: 04/19/04
Pete
It is the NexStar 9.25GPS (9.25 inch f/10 Schmidt-Cassegrain) which I reviewed for Cloudynights (and which I purchased after I got done reviewing it). It is a fine performer, especially on the moon with my binoviewer. Indeed, it was the addition of my binoviewer which really turned me back into a "Lunie". Clear skies to you.
David Knisely
Reged: 04/19/04
Jim Mosher posted:
All I had was the Lunar Orbiter images from the Digital Lunar Orbiter Photographic Atlas of the Moon:
http://www.lpi.usra.edu/resources/lunar_orbiter/
plus a few take by Maurizio Di Scuillo using a CCD camera on a ten inch Newtonian optimized for high resolution planetary work (which showed between 25 and 30 possible craterlets). At the time I did this, I had to just assume an east-to-west rim-to-rim diameter of 60 miles for Plato (a commonly-quoted figure) and go from there. Without a highly accurate scale on the Lunar Orbiter images, it was difficult to obtain any precise figures for the craterlets, which is why in my earlier postings on the subject, I give an error bar of +/- 0.2 miles (+/-0.32 km). There were a few high-resolution images take of sections of Plato by the Clementine probe, but I have had difficulty in getting scale figures for those either. Linne (2.4 km across) has always been (at least to me) slightly easier to resolve than the central craterlet "A", so I don't know what that says about the diameter of the "A" craterlet (might have to do with the lack of foreshortening with Linne as well as its bright ejecta blanket which would help with the contrast). In any case, I think that figures for the craterlets on the Wiki should be stated *only* to +/- 0.1 km, as going finer than that is probably stretching any measuring accuracy a bit too much.
The 9/D formula is one I derived Patrick Moore's book AMATEUR ASTRONOMY (c. 1968 W.W. Norton & Co.) from a table (Appendix XI) on page 224. The first few entries are:
1 inch aperture: smallest crater: 9 miles...Narrowest cleft: 0.5 mile
2 inch aperture: smallest crater: 4.5 miles...Narrowest cleft: 0.25 miles.
3 inch aperture: smallest crater 3 miles...Narrowest cleft: 0.16 miles.
This goes on to where he hits 10 inches and a 0.9 mile crater diameter figure, then going on to 12, 15, and 18 inches of aperture. This sequence of aperture diameter vs. crater diameter is where the "9/D" formula basically comes from. Under the table, Moore states:
"The smallest craterlet that I personally have recorded is probably that on the summit of a mountain peak near the crater Beer. The instrument used was the Meudon 33-inch, and the diameter of the summit depression cannot have been much more than 500 yards."
As a youngster (in the autumn of 1969), I was given an early version of the LAC-76 chart of the Raphaeus Mountain Region by my uncle who got it from a cartographer he had hosted on board the carrier USS Enterprise. It showed craterlets down to just under one mile across, and from using my 8 inch on that region of the moon, I found that with difficulty, I could get close to one mile resolution. This was consistent enough with Moore's table that I was satisfied that the 9/D formula probably was a realistic one. Clear skies to you.
photonovore
Moonatic
Reged: 12/24/04
Loc: tacoma wa
When i was interested in this subject, during sessions i would examine a given area for the smallest features that i could identify as craterlets and made detailed locational notes and/or sketches then used those to locate the features on the Bowker & Hughes LO images and measured them. I also used B&H at the eyepiece on numerous occasions to ID such features and measure them as i went along.
Using a 5" f/9 achomat with binocular viewer under seeing that was sufficient to reveal it's diffraction limit (1>1.5" and even this an utter rarity at my location), i found the threshold to be at ~2km. On an inch/mile relationship this works out to between 6-6.5/D.
However, if an 8" were to be considered as operating at its diffraction limit, this would require noticably better than 1" arc median seeing, taking into consideration the seeing's moment to moment variability to a better figure (those transitory good seeing moments).
The paucity of sub arc second seeing at the vast majority of amateur home observing sites, combined with a lack of serious useage of smaller aperture refractors (which reach diffraction limited performance in much less optimal seeing conditions) of the serious lunar observers of this era (mid 20th century--they always favored the largest aperture they could lay hands on as a sort of policy it seems) who authored these tables, would probably account for the more conservative 9/D craterlet resolution figure, IMO. IOW, 9/D is a number one would expect using larger apertures (8-12inches) which are nearly always actually used short of their diffraction limit due to persistent seeing limitations.
If, however, these larger apertures *were* used in seeing conditions which allow their diffraction limits to be actually reached on this sort of target, a 6-7/D figure would be more accurate IMO.
However, seeing being limited to about 1/2second of arc at the best sites in the world, one can easily see the aperture limitation for diffraction limited visual observation lies at about 12" of aperture. Past this point in aperture, optical contrast will increase (which can mimicor imply a resolution increase), but the finest resolution will remain limited to that allowed by the prevailing seeing. Only by using a different imager than the eye (digital & related post processing) can the effective seeing be reduced further, thus allowing the further increases in resolution we see in the best digital images. Even digital imaging (amateur) seems to top out at about 0.25"arc resolution or 500meters ground resolution. That I have seen to date, the best professional digital imaging has achieved (using fully adaptive optics plus digital imaging & post-processing) is 130m ground resolution on craterlets using ESO's VLT telescope. Note that *if* resolution were not limited by seeing, a 78" refelctor would offer the same visual resolution. Yet, as was discussed in yet another thread about lunar resolution, Kuiper, using a 61" reflector in an optimal observing location vis a vis seeing, found it difficult to break even the 1km threshold while observing visually.
So, i'd agree with David that Whitaker/Moore's 9/D represents a reasonable formula to use with apertures 8-12", but that for apertures =<6" a somewhat more liberal figure of 6-7/D, reflecting actual diffraction limtied resolution values, would be appropriate as these resolutions are more frequently allowed by the seeing most amateurs deal with.
-------------------- Mardi
4" achromat, ETX-70.
Whitepeak Lunar Observatory Website
Jim Mosher
Reged: 05/22/06
David (and Pete),
Thanks for clearing this up.
1. Moore's tables in Amateur Astronomy (1968) and The Amateur Astronomer (1990) sound like reprints of Ewen Whitaker's table from Wilkins and Moore's The Moon (1955/1961 - I haven't seen the 1955 edition, so I don't know if it had Whitaker's Appendix). The lines David quotes from the table are identical to those in the 1961 book (although Whitaker originally included at the end of the rows his values for the "Apparent Size of Smallest Cleft" as seen in the eyepiece, which he estimated to be 8 times the "actual" size). In view of where these numbers come from, it would seem to me that the "9 miles/D[inches]" threshold rule for visual observations should be referred to as "Whitaker's formula" (rather than Moore's). As previously mentioned, Whitaker's exact formula (which he presumably used to generate his original table) is "8.7 arc-sec/D[inches]". At an "average" lunar distance of 384,400 km (238,860 mi) that translates to 10.1 mi/D[inches], so Whitaker seems to have assumed a shorter distance -- something closer to 213,000 mi (343,000 km) -- for his table. That is, he seems to be trying to give the size of the smallest craterlet he thinks will be detectable when the Moon is at its closest approach to Earth.
2. The region around Beer was thoroughly photographed by Apollo 15 (1971), but if Moore made his statement about detecting a 500 yard (0.46 km) craterlet there as early as 1968, then I'm guessing he means that there is something on one of his drawings from the 1950's which, when checked against a Lunar Orbiter IV photo (1966) proved to be a 0.46 km crater. The problem with claims of this sort is, as Mardi has pointed out, there are numerous examples of Wilkins and Moore's drawings made with the 33" Meudon refractor in their 1961 book. But unlike the work of their more conservative predecessors, these drawings are invariably peppered with totally imaginary features. Little they show below about 2 km (actual size) has any obvious connection with reality. So Moore may indeed have drawn a hill with a 500 yard pit, but it's very hard to assess the significance of that since (absent the drawing) one has to assume he drew many others of that size that didn't exist. Last week I copied most of the drawings from the library's copy of Wilkins and Moore, but somehow missed Moore's drawing of Beer. As example of Moore's work with the 33" refractor, his drawing of Grove shows only what he records as a 0.5 km pit on the crater's north rim. This turns out to be non-existent, while he completely missed prominent 2, 3 and 4 km craters on the floor, as well as a 3-km diameter central peak. The drawing of J. Herschel, also attributed to him, is all but incomprehensible when compared to photos from space.
3. David, your Plato scale sounds correct to me. Plato looks like it initially had a nearly perfect circular form, now scalloped by slumping. 100 km (59 miles) seems a good estimate for the present inner rim diameter. An exact east-west rim-to-rim diameter, measured from what you've labeled the "west rim bow-in" to the opposite side is 99.5 km (58.9 miles). Features like the "mass of faulted rock" (once known as Plato Zeta) labeled in your illustration look like they've moved the rim-crest out by 5-7 km in places (of course, even the sections that look undisturbed may already have been moved out by collapses whose debris is now hidden under the floor). A sort of least-squares fit through the present rim scallops would probably give a "diameter" of around 104 km.
4. Regarding the accuracy (or lack thereof) of the craterlet diameters I posted on Chuck Wood's the-Moon Wiki, the high resolution USGS scans of the Lunar Orbiter images that have become available in the last few years are a considerable improvement over the LPI's scans from Bowker and Hughes. Also, using the LTVT circle drawing tool removes almost all uncertainty about the scale. By knowing the geometry in which the images were photographed, and by identifying the pixel locations of distant points at known lunar longitude/latitude, the scale is known to a fraction of 1%, and the circle tool permits a sort of visual least-squares-fit to the rim crest. Unfortunately, the definition of the rim-crest position (the transition from light to dark) is not always as sharply defined as one might hope, so there is a certain arbitrariness in how the circle is set that can be affected by magnification, contrast and room lighting. Plus there is my inherent sloppiness and human error. So your guess of +/-0.1 km accuracy is probably not unreasonable, although I feel they are a bit better than that. As a test, the diameters I posted on the Wiki were recorded on LO-IV-127H. Since it takes only a few minutes to do so, I just now re-measured the "Big Four" on LO-IV-127H, and then measured them for a first time on LO-IV-134H and on LO-IV-128H (much less sharp). The scale/geometry of each of these images was independently determined some months ago. Here the results (without editing or fudging -- my memory is too poor to remember the numbers from one photo to the next): Re-measured Craterlet Diameters [km]
# Wiki 127H 134H 128H Aver SD - ---- ---- ---- ---- ---- ---- A 2.44 2.47 2.49 2.47 2.47 0.02 B 2.09 2.05 1.99 2.09 2.06 0.05 C 2.22 2.29 2.23 2.23 2.24 0.03 D 1.98 2.05 1.99 1.91 1.98 0.06
The final two columns give the average and the standard deviation (scatter). It looks to me like +/-0.04 km would be a slightly better estimate of the actual experimental scatter in this particular image set. The difference in size between "B" and "C" looks significant to me. That between "B" and "D" may not be.
I didn't think to try to verify these numbers with the Clementine images. In general, their standard resolution is inferior to Lunar Orbiter IV, but if they took some in their Hi-Res mode they would be interesting to evaluate. As best I can measure them on the new (standard resolution) USGS Warped Clementine basemap (where there should be no doubt about the scale), the rim-crest diameters are: A=2.60, B=2.06, C=2.24, D=1.94 km. The diameter for "A" may be an overestimate because the Clementine lighting is from south to north and I'm including what looks like a possible image glitch (it looks like a double image in the mosaic) on the north rim.
It will be interesting to see what diameters Kaguya and Chang'e-1 obtain, but I doubt they'll be much different from these.
5. If one believes the list posted on the Wiki, Maurizio's 25-30 craterlets photographed with a 10" aperture corresponds to a detection threshold of 0.90 km. That can be compared with Bob Pilz' 18 possible craterlets (16 real), or 0.98 km, photographed with an 8" aperture. The rather modest gain (0.98 --> 0.90 km) in going from 8" to 10" seems in keeping with my earlier observation that the craterlet resolution threshold seems to improve only as the square root of the aperture, but Bob may have had some advantage from using a blue filter (shorter wavelengths give less diffraction) and newer image processing software. Even though the individual craterlet diameters given in the list may, as you say, be in error by up to +/-0.1 km, these are, for the most part, random errors; so the general trend expressed there (of numbers of craterlets in various size classes) should, I believe, still be valid. In other words, if, all else being equal and the performance of the telescopes being limited only by diffraction, an 8" scope can detect 16 craterlets ("0.97 km" in the list), we would expect a 10" scope to get to (8/10)*(0.98) = "0.78 km" in the list. "0.98 km" is between numbers 16 and 17 on the list, and "0.78 km" is between numbers 45 and 46. That implies that with "equal" performance, if one can detect 16 craterlets with 8" then it should be possible to detect 45 craterlets with 10", whether the individual craterlets listed were accurately ranked or not.
6. As to how the detectability of Linné compares to Plato craterlet "A", the rim-to-rim diameter of the bowl of Linné appears to me to be 2.23 +/-0.03 km. This was measured on the new medium resolution scan of Apollo AS15-M-0580 from Arizona State University registered to LTO-42A4. On lower resolution scans of AS15-M-0406 and AS15-M-0409 from the LPI, I get 2.28 and 2.24 km; and on LO-IV-097H and on LO-IV-098H I get 2.24 and 2.25 km. These are all independent measures on independently calibrated images. 2.4 km seems too large. My best guess is 2.24 km, which is significantly smaller than the 2.47 km (average) reported above for Plato craterlet "A", and about the same as Plato "C". If this is not convincing, the attachment shows Linné and Plato craterlet "A" in overhead views at the identical scale.
Since Plato "A" is 51.6° north of the Moon's equator versus 27.8° for Linné, there is a significant difference in foreshortening (the apparent north-south dimension of Plato "A" is compressed by a factor of 0.62 vs. 0.88 for Linné), so there would definitely be less total area of shadow to see in Plato "A". However, the east-west foreshortening which affects the separation of the bright-dark components (and therefore, one might think, is more important to the detectability) is not much different. Plato "A" is 9.1° west of the central meridian (on average) and Linné is 11.8° to the east.
I agree with you that the easier visual detectability of the bowl of Linné (if true – photographers may have the opposite experience) would be due to a combination of the larger visible shadow area (by a factor of about 1.3x from foreshortening alone, without even counting the greater hiding of the shadowed floor by the rim in the more northerly craterlet) and the greater contrast of the black shadow with the surrounding bright ejecta blanket.
-- Jim
Petewp
Reged: 12/04/06
Mardi and Jim,
I dont have experience with scopes over 10" of my own. Sure Ive looked through enough to think I even "adopted" and 18" dob, but really, I cant comment on whether or not seeing allows diffraction limited results for tele's greater than 12". I can say without pause that on good nights I see it with out a doubt on double stars. These nights are for me, say, one in a dozen. Maybe I can do it more often. Fact is I need to see a certain steadiness before I look at .5 doubles - wether or not lesser seeing will let it happen.
Mardi, the optimist in me wants to say you're wrong and that the diffraction limit is there for everyone regardless of aperture, you just have to be willing to put in your time to access it. I'm sorry, I see a politically correct sky LOL. I simply cant argue your point Mardi but everything in me wants to - like i said though my biggest scope was 10" so it'd be pure conjecture - which fills a lot of message boards as it is. It is a wise point though in that the scopes available to amateurs that often have the huge aperture also carry a huge central obstruction to say nothing of the fast f/ration coma distortions. Before they even start thats some things that a 12" f/7 for example just doesnt have to deal with.
JIM...
You wrote a terrific post but Mardi sapped my energy so Ill reread it tommorow!!
Pete
70mm TeleVue Ranger
Moderator: desertstars
