Astrophotography and Sketching >> Film Astrophotography
stefanc
Reged: 10/24/07
Loc: indiana
what else do i need???? new
      #2331933 - 04/16/08 05:19 PM
i have an 8" zhumell dob and a minolta x 700. i would like to try my hand at some photos but not sure what i need to adapt the camera to the scope. i know i need the t ring but is there anything else.
ClownFishModerator
Reged: 04/26/05
Loc: Islamabad, Pakistan
Re: what else do i need???? new [Re: stefanc]
      #2332020 - 04/16/08 06:12 PM
ah.. so you have an Alt/Az mount. That's going to make faint objects (DSOs) virtually impossible to capture.
You will have the best chance imaging the moon, when it's not full. A full moon shows no craters. The moon will work because it's so bright that you do not need to track in equatorial mode.
To attache the camera you will need a T-Ring and a T-Adapter.
- The T-Ring attaches one end to the camera and has a universal T-Thread on the other end.
- The T-Adapter attaches the T-Ring/Camera to your scope's focuser.
You will also need a cable release.
CF
Learn all about POLAR ALIGNMENT with my Drift Method Tutorial and simulator!! Or visit my Foreign Service Blog!
stefanc
Reged: 10/24/07
Loc: indiana
Re: what else do i need???? new [Re: ClownFish]
      #2332267 - 04/16/08 08:24 PM
thanks for the info, I also have a meade 70az on a eq mount. would that be a better scope to setup with.
ClownFishModerator
Reged: 04/26/05
Re: what else do i need???? [Re: stefanc]
      #2332950 - 04/17/08 02:05 AM
Not really, the long focal length (F10) is way too slow for film, and the mount is not even close to the quality needed for long exposure astrophotography through a telescope.
Now IF the MOUNT is the ADS version, which is an EQUATORIAL MOUNT then may be able to use it for something. The Meade 70AZ comes on both Alt/AZ mounts and an EQUATORIAL one. The Alt/AZ mount will not work for long exposure astrophotography. You COULD use your camera in Piggyback fashion with a 50mm lens and use the EQ mount as a glorified "Barm-Door" mount and get some decent wide field shots.
For film imaging of faint nebula and galaxies, you need:
- An Equatorial Mount
- A fast (short) focal ratio lens, less than f/6
CF
Moderator:  Suk Lee, Charlie Hein, knuklhdastnmr, ClownFish
Home
