Gailwrath
Reged: 06/01/07
Loc: Santa Cruz, Ca.
Auto guiding new
      #2332771 - 04/16/08 11:57 PM
Can the Mallincam be used as an auto guider as well
Meade LX200GPS-10"
Nikon D2H DSLR
Celestron C90 Guide Scope
Astrojunk
Reged: 11/02/06
Loc: Australia
Re: Auto guiding new [Re: Gailwrath]
      #2333053 - 04/17/08 04:23 AM
Yes.
Is it easy?
Depends!
You need a pc/laptop connedted to your camera (any will do), software like guidedog from barkosoftware (google it), and a way of connecting to your telescope (while you are at it, google 'shoestring astronomy'), and lots of luck.
Sometimes it just works but it took me an age to sort out autoguiding with ServoCat/Argonavis - but I did!
Astrojunk
20" f5 Alt Az Newtonian
ccs_hello
Reged: 07/03/04
Re: Auto guiding (analog timebase) new [Re: Gailwrath]
      #2333194 - 04/17/08 07:44 AM
If the question is using the same cam for image viewing and guiding at the same time, the approach is not recommended.
If the question is using the cam for guiding source, I'd strongly discourage it.
Reasons:
The guiding precision is determined by mapping discrete CCD photosites to absolute sky coordinate.
Analog processing, in its timebase, inside the cam (first variable), and
analog processing, in the derived timebase, inside the video capture card (second variable)
will be the main sources of guiding inaccuracy.
Proof: in night time, pointing an OTA, tracking off, to an artificial star then record the "autoguider" output.
Guiding needs PC software to calculate the necessary adjustment (except self-contained autoguider). If PC is needed anyway, there is no point using analog video as source for guiding. An inexpensive (using digital processing) CCD or CMOS imager would be the appropriate way to do.
Clear Skies!
ccs_hello
Astrojunk
Reged: 11/02/06
Loc: Australia
Re: Auto guiding (analog timebase) [Re: ccs_hello]
      #2335474 - 04/18/08 08:48 AM
I perhaps wouldn't be quite so dismissive. There is utility in autoguiding using a video camera even though there are issues.
For one, Using the GSTAR-EX with dual output, I can track and capture using the same device.
On the otherhand, if you use frame integration, then forget it! Lunar and planetary only please.
Astrojunk
0 registered and 0 anonymous users are browsing this forum.
Moderator:  Chris Schroeder
Home
