Privacy Policy |
Please read our Terms
of Service | Signup and
jupiterzkool
Reged: 05/08/06
Loc: Pasadena, CA
This will be "cool". Or should I say "hot"?
http://messenger.jhuapl.edu
-S
-------------------- Scott G. Edgington, Planetary Scientist
Cassini-Huygens: Mission to Saturn & Titan
Yes, Asia, John Wetton Fan
llanitedave
Humble Megalomaniac
Reged: 09/26/05
Loc: Amargosa Valley, NV, USA
Hot or cool, it will be great!
Will we have to wait until actual orbit is achieved before we get pictures of the poles?
"S.O.E." (Sauron's Other Eye) 16" Royce conical mirror: A permanent work in progress.
10" Homebuilt dob, old Coulter mirror
Next Project: The "Eye of Sauron" Observatory!
hm insulators
Reged: 01/22/07
Fantastic! I'll have to keep my eye on this over the next couple of days!
jupiterzkool
Reged: 05/08/06
Loc: Pasadena, CA
This is just a flyby. Orbit insertion comes at a later time (I forget exactly when).
-S
Hermie
Reged: 04/20/05
Loc: On the way to SYD
Messenger won't achieve Mercury orbit until March 2011:
http://sse.jpl.nasa.gov/missions/profile.cfm?Mission=MESSENGER
I am just amazed that anyone can launch a probe and miss the target by a mere 200km after nearly a year of flight. I know it has made corrections, but it is still a huge technical feat. It is also interesting that it takes 4 years to get down the gravity well to Mercury, while it only takes about 6 months to get something to Mars.
Looking forward to the pictures and the science that will follow.
-------------------- APM 105/650
Pedestal
Reged: 03/11/06
Loc: Smoggy Bottom, Baytown,Texas
I -think- the idea is to let gravity do the work, small rocket/less fuel=more payload. Hubert
-------------------- www.smoggybottom.org
groz
Reged: 03/14/07
Loc: Duncan, BC
It's all about the cost per kilo of payload delivered to destination. Mars is a bit of a unique destination in that it has an atmosphere, so, aero-breaking can be used to apply a significant amount of the delta-V to a vehicle headed there, which translates directly to 'less fuel carried'. The lifting capacity of the launch vehicle is fixed, so, every kilo of fuel you can get off the thing, means another kilo of payload that can be delivered to destination. Mars landers are yet a more special case, since they are going to do all the breaking in one quick go, they 'arrive' quickly. Mars orbiters using aero-breaking tend to arrive in the vicinity just as fast as a lander, but, then spend up to a year fussing with various passes thru the upper atmosphere lowering an orbit before the final orbit is achieved. Again, it's all about the most cost effective way to apply a required delta-V to the vehicle.
It is interesting to compare a mars lander with a lunar lander when doing the math. If you assume the same launch vehicle in both cases, then you have an all up launch weight maximum value, and an empty weight of the launcher. Load the launcher with enough fuel to achieve a Hollmann trajectory for mars, and call that X1. Conversly, load it with enough for a lunar trajectory, and call it X2. Max launch weight minus X = the payload enroute. For the Mars case, figure out the weight of a heat shield and a parachute, call that Y1. For the lunar vehicle, figure out how much fuel is required for a soft land, plus the weight of the rocket it'll be run thru during the process, all that Y2. Max - X1 - Y1 = Z1 where Z1 is the resultant final payload delivered to destination in the mars case. Max - X2 - Y2 = Z2, where Z2 is the resultant final payload delivered to the soft landing on the lunar surface. When you grind all the numbers, the surprising result is, Z1 is MUCH larger than Z2, an the conclusion is, for a given cost of launch using the specified vehicle, a far larger scientific payload can be soft landed on mars than can be soft landed on the moon.
For an orbiter, the math gets a little more complex, it's going to require some sort of propulsion for final orbit adjustments, but again, it can get a lot of the delta V reductions thru aerobraking, and in the end, the result is similar. For a given launch vehicle, a larger payload can be placed in a mars orbit than lunar orbit, by making use of aerobraking for a big chunk of the delta V adjustments. All of this assumes the use of chemical reaction rockets. Ion propulsion enroute changes the math some, but, as we see farther down, it dramatically increases the time component, which has other effects.
The tradeoff is ofc now time, doing multiple aerobraking passes will take time, and to maximize the payload, very large eliptical orbits will be achieved on the first pass, with a lowering of apogee on subsequent passes. When the target orbit is 'almost' achieved, then a firing of the motors to raise perigee back out of the atmosphere will finalize orbit insertion. This whole process can take a very long time.
This is a big part of the reason why the one-way robotic mission to mars has such a following in the scientific community today. The cost of such a mission is actually within the reach of the handouts, errr, I mean grants achievable today.
The economics change entirely if you start to include silliness such as return trips into the equation. If you do the math, and include 'sample return' into the initial specification, everything changes, and a lunar mission gets signficantly less expensive. If you add in 'life support consumables' enroute, then the time factor is no longer 'free', and costs run up exponentially yet again. Such missions quickly reach cost projections such that the grants can no longer absorb them, so they remain interesting diversions on the drawing board, but, not gonna happen anytime soon.
In the case of the mission in and around mercury, it's a one way robotic probe. There is no allowance for return fuel, and, time is not the big expense. The mission uses gravitational forces 'enroute' to modify trajectory for the most part, minimizing the fuel requirement, therefor allowing a maximum scientific payload. It's a tradeoff, will take longer to get the data, but, there will be more data once it all arrives. If there was a compelling reason to go look 'right now', more fuel could be loaded onto the probe, at the expense of scientific instruments, and it could take a less optimum, and much quicker, trajectory to 'go look'.
imjeffp
Senior Space Cadet
Reged: 09/30/03
Loc: Cedar Park, Texas
So what you're saying is, it's relatively easy to get there, but not so easy to stop once you're there?
Orbital mechanics makes my head hurt.
-------------------- Blog
ST80 • AT80EDT/LXD650
ETX-90/DS-2000 • 10" LX200 Classic ("The Quarter-Meter Telescope at the Heritage Park Observatory")
SPC900NC • DMK21AF04 • Digital Rebel XT
jupiterzkool
Reged: 05/08/06
Loc: Pasadena, CA
The Messenger Project has started releasing images.
http://messenger.jhuapl.edu/gallery/sciencePhotos/index.php
matt
Vendor (Scopemania)
Reged: 07/28/03
Loc: Chaville, France
I've seen sharper Moon images in the Lunie Bin
Is it me, the photo processing applied or is this hemisphere smoother than what we saw on the Mariner images, and with more ray craters?
-------------------- Matt
CI700 mount with various scopes on top.
Shadowalker
Reged: 11/23/04
Loc: Carriere, MS, USA
Well, looks like the moon. But we're seeing things never before seen. That is amazing to me.
An aside: I saw the launch of Messenger while on business at the Cape a few years back. Nice to see this followup.
This is going to be an interesting mission!
-------------------- Tom Nicolaides
http://www.first-light.org
Dan Luna
Reged: 07/07/04
Loc: UK
What a nice looking planet. It's wonderful to be able to see the first images of previously unknown landscapes.
The close up released Jan 16 was still from 11,000 miles away, so there should be plenty more detail to come yet. I expect the imaging team are being very careful though to make sure there are no alien cities visible on the images before releasing them to public gaze.
"This is no world for men," he said. "And yet in a way - it appeals."
llanitedave
Humble Megalomaniac
Reged: 09/26/05
It's not the cities that bring unwanted attention so much as the amusement parks.
Pedestal
Reged: 03/11/06
Very interesting: For no good reason, I had expected the surface to be less cratered than the Moon. Hubert
Shadowalker
Reged: 11/23/04
Oh wow... Follow the link. A whole new world we're exploring!
David Knisely
Reged: 04/19/04
Loc: Beatrice, Nebraska
Those were long-range images before close approach. The new ones are *incredibly* sharp and detailed. Older craters and the overall landscape looks almost "softened" in form when compared to the crisp sharp outlines of the newer craters and the numerous secondary impact craters. I guess sitting for century after century at only 36 million miles from the sun has take its toll on the rocky landscape. Clear skies to you.
-------------------- David W. Knisely
Hyde Memorial Observatory
http://www.hydeobservatory.info
rustynailz911
Reged: 01/30/08
Loc: Nova Scotia
The pics are amazing always cool to see another world up close like that mercury is a interesting planet which only the biggest scopes can even see so for us guys without 48 inch reflectors it is amazing.Who could have figured we would witness a massive avalanche on Mars i didnt think i would see anthing like that im my lifetime.36 million miles from the sun hope they put some SPF 1 billion on that probe
0 registered and 0 anonymous users are browsing this forum.
Moderator: llanitedave
