Privacy Policy |
Please read our Terms
of Service | Signup and
Bradley B
Reged: 05/14/07
Loc: Sacramento, California
Might be a question for Charlie Hein: in a post last year, was listed a link (http://www.sfaaa.com/board/viewtopic.php?t=219) to fixing a loose polarscope. That link no longer works:
phpBB : Critical Error
Could not connect to the database
Might someone have a new link for this information?
BB
-------------------- Celestron C8
William Optics ZS66
It is error only, and not truth, that shrinks from inquiry. - Thomas Paine
Charlie Hein
Reged: 11/02/03
Loc: 26.06.08N, +80.23.08W
Back by popular demand...
Yes, if you have one of these things, we all do it - sooner or later, we loosen our polar scope recticle too much and it falls out and rolls around inside the polar scope. This makes polar alignment impossible - but it's very easy to fix! The trick is in understanding how the polar scope is put together... let's take it apart for a look.
The polar scope will easily unthread from the mount. Once it's out, hold it vertically with the "eyepiece" side facing up and the "objective" side facing down, like so:
The "eyepiece" end of the polar scope unscrews. Remove it, and you will expose the loose recticle. At this point you can just empty it out into your hand if you'd like to have a closer look at it, although it's not necessary to completely remove it in order to fix your trouble unless for some reason the glass recticle lens itself has fallen out of its holder. More on this in a bit.
Here's a picture of the recticle itself:
Note that there's a larger "outside" ring that is the "holder" for the glass recticle, and a smaller ring that screws into the larger ring to secure the glass recticle lens in place. In the very unlikely event that this holder assembly has come apart, just drop the glass lens in place as shown and tighten the smaller ring into the larger ring with a small "jewelers" screwdriver until the recticle lens is snugly held in the metal "framework". Be careful not to over tighten the inside ring as you could shatter the recticle glass!
Just so you have an idea of what it looks like, here's a look at the back side of the recticle:
Now, the whole reason we're taking this thing apart in the first place is probably because we loosened one or more of the adjustment screws too much and the recticle assembly fell out as one piece. Fortunately this is an avoidable problem. The recticle is designed with a flange (or slot, or channel - pick the word you like) that will retain the recticle in place if we don't loosen it too much:
If you look down the disassembled polar scope towards the objective, it might look something like this:
In this case, note that one adjustment screw is way out (unscrewed) and one is not. This one screw was loose enough to allow the recticle to just fall right out. Notice that if it had not been loosened so far, the recticle would have still been held in place by the flange. Keep this in mind when you are adjusting the recticle for accurate centering later on.
However, now that the recticle *is* out, it might be prudent to loosen the other two adjustment screws so that they do not extend into the area that the recticle needs to fall into.
These adjustment screws require a 1.5mm allen key, by the way.
Once you've unscrewed the adjustment screws enough to clear the opening, just drop the recticle into the polar scope with this side facing you. Now that nothing is in the way, it should be pretty easy to get it right:
Now, tighten the adjustment screws up until the recticle is roughly centered in the housing. They should be tight enough to hold the recticle firmly in place, but definitely not "cranked down hard"! You could ruin your recticle if you over tighten it in this "holder"!
Once it's in place, it should look something like this:
Now that the recticle is back in its holder, you can thread the "eyepiece" back in, looking through the "eyepiece" and continuing to screw it in until the recticle is in sharp focus. Then just thread the whole polar scope assembly back into the RA axis of your mount. Problem solved!
Once the recticle is re-installed and we have the polar scope re-installed in the mount, we will definitely need to re-align the recticle to the RA axis of the mount. Accuracy is the name of the game at this stage - the more accurately the recticle is aligned, the better your chances are of getting really good polar alignments using the polar scope.
At this point, I could go through a discussion of the whole procedure for accurately lining up your recticle to the RA axis of your mount, but instead I'll direct you to one of the best descriptions on the web for how to do this that I've ever found:
Instructions for aligning your polar scope recticle
Good Luck and Clear Skies!
Charlie
-------------------- "He's dead, Jim - I'll get his wallet, you get his tricorder." - Leonard "Bones" McCoy
Weston CSC:
Bradley B
Reged: 05/14/07
Thanks so much! (That's why it's in popular demand.)
William Optics ZS66
Charlie Hein
Reged: 11/02/03
It's my pleasure! I had been meaning to post this here for a while and your post motivated me to go find the old website on The WayBack Machine, copy out the text and repost it here.
Charlie
Weston CSC:
jarska
newbie
Reged: 04/29/07
plz someone tell me,how i get polar scope out from the mount?
Jari Ylioja
-------------------- Haapavesi,Finland
alienux
Reged: 02/17/08
Loc: Dayton, Ohio
Jari Ylioja
It should just unscrew counter-clockwise out of the mount.
-------------------- Brian
Orion SkyView Pro 127mm EQ Mak
Meade 60mm Push-To TeleStar
Phillips SPC900NC
Mert
Reged: 08/31/05
Loc: Spain, Pamplona
Now, that's surely a very nice write-up you made Charlie!
Also the images included into the same text clarify
totally the whole item, well done
Regards and thanks as well!
Mert
42º49"N 1º38"W
3" Polarex refractor
6" F12 SW Maksutov,CS2-S
EQ6 + EQMOD
SPC900NC/DFK21AU04.AS
My web-page don't laugh, I should make it better!
Edited by Mert (04/29/08 05:22 PM)
tog
Reged: 01/17/05
Loc: Front Yard
Now, that's surely a very nice write-up you made Charlie! Also the images included into the same text clarify totally the whole item, well done
Another well done from me too! I like learning about these mounts. tog
jarska
newbie
Reged: 04/29/07
Unscrew that clockwise?
and what are those screw's?
Edited by jarska (04/30/08 02:00 AM)
WarrenS
Reged: 03/04/08
Loc: Orange County New York
A side question on the Atlas polarscope. Looking at Charlies' photo of the polarscope reticle it brings up what I see through my own. To me it seems that the positions of NCP and Polaris are somewhat reversed. On my star maps, Polaris is more on the Cassiopeia side and the NCP more on the Ursa Major side. This would obviously affect precise polar alignment. I've started to do drift aligning so the point may be moot but am I missing something here?
-------------------- Warren
Astro-Tech 127EDT
Celestron Onyx 80ED
Astro-Tech Field Flattener
C8 (circa 1983 Orange Tube)
Atlas EQ-G, Orion SSAG
Canon 135mm F2.8
Canon 40D, Astronomik CLS clip filter
Leica, Minolta binos
Tim in GA
Reged: 02/06/06
Loc: Buford, GA
If I remember correctly (it's been way too long since I used my equipment) the polarscope reverses the view.
-------------------- There are some who call me...........Tim
Canon 5DMKII, 30D, 350D
Canon 17-40L, 45 TS-E, 100 Macro, 135L
SMC Takumar 50mm f/1.4
http://www.flickr.com/timscreations
Skylook123
Reged: 04/30/05
Loc: Tucson, AZ
Yes, the constellations are shown as they appear in the sky to the naked eye, while the Polaris (little circle) is shown reversed and inverted (flipped in both axes) as it will appear in the polar scope.
What I usually do is look at one of my planetarium programs (Cartes du Ciel, Earth Centered Universe, etc.), center on the NCP, and see the location of Polaris for the time I'm setting up. Then I just flip the image horizontally and vertically and stick Polaris at that point on the big circle. I don't pay any attention to anything else etched on the reticle.
The recent addition of the Polaris information in the hand controller removes the need to check the planetarium program and lets me go right to putting Polaris in the correct spot on the big circle.
And I agree, great work putting together the pictures and discussion. Note that the Atlas (Charlie's picture) and EQ6 (white mount picture) polar scopes are different in that the EQ6 has a graduated facing, while the Atlas has a plain, unmarked facing. Confusing when you read the mount manual.
-------------------- Jim
A Bad Night With A Telescope
Beats A Good Night Doing Anything Else
Tectron 18" Truss Dob/Sky Commander DSCs, "Derrick"
Meade 10" LX-5 SCT/Atlas-G "Ol' Blue Eye"
Orion 90mm refractor,
Meade 10" Starfinder Newt/JMI NGCMax DSCs,
Celestron 10x50 Ultima Pro
Charlie Hein
Reged: 11/02/03
The piece they're in is basically a "nut" that holds the RA axis together - the screws lock it down so that it cannot loosen.
Charlie
Weston CSC:
RandallK
Reged: 11/10/06
Loc: Nanaimo, B. C. Canada
To save Charlie's tutorial, highlight everything with your mouse and if you have a word processeor such as MS Word, just copy and paste and save it as a .doc file.
-------------------- Scopes: Meade SC-8AT w UHTC
Orion ST-80 Refractor (Autoguiding)
SkyWatcher 5" F/5 Reflector
SkyWatcher 127mm MAK
Mount: HEQ5 Pro
Cameras: Orion Starshoot DS Colour Imager V.1
Imaging Source Webcam DMK21AU04.AS
Canon XSi 450D Unmodded
Palm TX PDA w Astromist and Bluetooth wireles control.
Bradley B
Reged: 05/14/07
And Charlie also stickied it in the "Best Threads in Mounts" post.
William Optics ZS66
3 registered and 9 anonymous users are browsing this forum.
Moderator: Charlie Hein, lineman_16735
