PrestonE
Reged: 04/29/05
Loc: Houston,Texas
Hi Guys and Gals...
This will evolve slowly...
We have the optics set...
We have the design...
We are building...
And we have taken pictures...
The group will likely benifit from this thread...
OTA to be completed within a few months...
Pictures coming soon...like tomorrow..of the start...
Best Regards,
Preston
-------------------- A few I enjoy,
and a few more in the works ;<)
PrestonE
Reged: 04/29/05
Loc: Houston,Texas
Ok...
Everyone has ask me to start this thread...
and now I have...
Tomorrow I'll post pictures of the machining of the bits and pieces...like the tube ends...the tube end capture blocks and the spherical ends in Invar....
You will love the details....I hope...
Best Regards,
Preston
PrestonE
Reged: 04/29/05
Loc: Houston,Texas
Hi guys...
This started as one of my projects....and then lingered...
Far TOO long..
I offered the optic set on Astromart...and it was quickely picked up...We are a team of 5 currently...they will take the OTA and finish the Robotic build somewhere to be determined...and they have looked at Australia...
From there I offered to both design and build the OTA...
That was 2 years ago...
And to day we are seeing the back plate, collimation plate and mid rings being machined....Finally....
I know this sounds like a fairy tail...
But it is the total truth...
Please follow our path...
Preston
Edited by PrestonE (05/02/08 07:42 PM)
PrestonE
Reged: 04/29/05
Loc: Houston,Texas
Ok, some pictures of the start of the tube ends and capture blocks in 6061 T6 aluminum.
All done manually 32 tube ends and 16 capture blocks and capture plates...
Enjoy,
Preston
PrestonE
Reged: 04/29/05
Loc: Houston,Texas
Drawing of the capture block.
You will notice the use of lots of holes for lightening.
We are trying to keep the entire OTA with optics, focuser, filter wheel, and camera under 100 pounds. The optic set weighs in at 53 pounds for the primary and secndary.
The tube ends premachining weighed 170 grams or 6 ounces and after machining weighted 28 grams of 1 ounce for each tube end. Quite a savings and well worth the time.
Each step was completed on all 32 ends and then the next step was machined...in toll 18 hours to machine the 32 ends.
By the end, I was really wishing for a CNC lathe...as one starts to get very bored doing the same thing 32 times with 15 differant machining steps...
Preston
PrestonE
Reged: 04/29/05
Loc: Houston,Texas
One of the 16 Catch Blocks getting the bevel that will hole the ball end that fits into the Tube End.
Thats, enough for now.
Thanks and enjoy,
Preston
PrestonE
Reged: 04/29/05
Loc: Houston,Texas
Ok, well do the ball turning with the 0.500 inch diameter Invar and call it a day.
First pic of machined pieces in two differing stages. Left after first turning and right ready to turn the ball.
PrestonE
Reged: 04/29/05
Loc: Houston,Texas
And turning the radius of the ball to 0.375" diameter.
This was the first real test of my Hardinge toolroom lathe since getting it home.
Edited by Don W (06/14/08 10:37 AM)
PrestonE
Reged: 04/29/05
Loc: Houston,Texas
A close up of the finished ball ends.
The bear
Reged: 02/11/08
Loc: rushville, indiana
this is very nice i love the machine work wish i had one would make some awesome stuff also. i will watch this thread religiously thanks PrestonE for your doing this build. i would hope you will do it from start to finish from this work to the electronics involved with this for the benefit of all especially me... doc
-------------------- Longitude -85.42786 Latitude 39.59153
when all else fails use duct tape "works for me"
PrestonE
Reged: 04/29/05
Loc: Houston,Texas
Thanks Bear,
I'll do my best. We fell way behind when a shipping company that I hired to move my new to me CNC mill last April and dumped it over in the truck while changing trailers here in Houston...total loss and I'm still working on trying to rebuild the control system.
But thanks to Kerry aka "The Captain" here on CN, we have contracted someone to do the really large mid rings, upper ring, back plate and collimetion plate...
That should all be here next week and then I can recheck the lenght of pvc tubing being used to simulate the lengths of carbon fiber tubing...before cutting the CF tubing.
The mirror spacing is fairly critical between the primary and secondary in a RC so we will be trying to hit it within .020 inches or plus or minus .010" at least that's the plan.
Preston
The bear
Reged: 02/11/08
i would say that is cutting it close for sure but if you are going to do it right that is the way to go. i am learning about RC through several threads here very interesting design for sure. thanks for your work doc
PrestonE
Reged: 04/29/05
Loc: Houston,Texas
Thanks Doc,
We are trying to get this OTA completed ASAP...within reason...
Here is a shot of the Capture Plate being chamfored for the ball end...
PrestonE
Reged: 04/29/05
Loc: Houston,Texas
And then the capture block and plate being radiused...
fixture and then assembly
PrestonE
Reged: 04/29/05
Loc: Houston,Texas
Assembled Capture block ready to machine the radius...
PrestonE
Reged: 04/29/05
Loc: Houston,Texas
Ok this was roughed on the mill in a rotary table and then finished on tha lathe in the same fixture...
Edited by PrestonE (05/02/08 11:02 AM)
PrestonE
Reged: 04/29/05
Loc: Houston,Texas
Finished piece after turning on the lathe...
Sky Captain
Scope Builder
Reged: 11/07/04
Loc: Seattle Washington
Thats looking great Preston! I'm really happy the machine shop I use will be able to handle your larger project too. Do you know when they will get the aluminum plates?
-------------------- Equipment Overload!
http://scopebuilder.webs.com/
Kerry.
PrestonE
Reged: 04/29/05
Loc: Houston,Texas
Thanks Kerry,
The plates are being shipped from 2 locations as we had already purchased the 18.5" diameter x 1.25" thick cast aluminum tooling plate Being machined for the collimation plate. It shipped Wednesday and I'll have to get the tracking number from Speedy Metal. I can say that Speedy Metal was $750 for everything and Jim $1100...so we went with Speedy.
I'll find out and let you know. Thanks again for the introduction to Jim the owner of the machine shop doing the work.
Best Regards Preston
PrestonE
Reged: 04/29/05
Loc: Houston,Texas
Ok, next let's take a look at the collimation plate...CAD rendering. I'm working on attaching the Rendering, not like attaching a picture
It has 3 two point pivots to suspend the mirror, with 1" diameter pads at the ends that sit on ball ends so that there will not be any binding...
Included is the mirror support tube in the center, this goes out the back and is centered in the mirror back plate with a metal o-ring to keep it centered in the back plate when collimating...
Notice the second slots from the ends of the three arms...these have an oilite bronze incert that can rotate slightly during collimation. These will be the tightening cap screws that oppose the push secrews that will push against the back side of the outer 3 holes on the arms...
The diameter at the edge of the arms is 18.5" and the thickness of the cast aluminum tooling plate is 1.25"
This collimation plate will likely be the first to get machined early next week.
Preston
Edited by PrestonE (05/02/08 02:27 PM)
