Pages: << 26 | 27 | 28 | 29 | 30 | 31 | 32 | 33 | 34 | 35 | 36 | 37 | 38 | 39 | 40 | 41 | 42 | 43 | 44 | 45 | 46 | >> (show all)
PrestonE
Reged: 04/29/05
Loc: San Miguel de Allende,Mexico
Re: 20 inch RC Robotic Build...a TEAM Effort.... new [Re: PrestonE]
      #2766512 - 11/23/08 04:56 PM Attachment (67 downloads)
And as long as it's still in the collet we'll tap it now instead of adding an operation and trying to tap it later.
We also made the 1.5 inch by .250 inch rods that are drilled and tapped for 4-40 screws on both ends...
Here's slitting the 10-32 adjusting screws.
Edited by PrestonE (11/23/08 04:59 PM)
PrestonE
Reged: 04/29/05
      #2766520 - 11/23/08 05:01 PM Attachment (74 downloads)
So finally we can trial assemble all of the pieces and see how it looks and functions.
Here is a side view.
PrestonE
Reged: 04/29/05
      #2766522 - 11/23/08 05:01 PM Attachment (69 downloads)
A view from above.
PrestonE
Reged: 04/29/05
      #2766525 - 11/23/08 05:03 PM Attachment (72 downloads)
Mounted on the end of the Collimation Tube...now you can see why I posted the uncluttered views...
It's starting to get a bit cluttered.
PrestonE
Reged: 04/29/05
      #2766529 - 11/23/08 05:04 PM Attachment (55 downloads)
A side view of the Primary Baffle on the adjuster.
We will setup to drill the mounting/adjusting holes in the CF Baffle tomorrow.
PrestonE
Reged: 04/29/05
      #2766536 - 11/23/08 05:07 PM Attachment (75 downloads)
And finally a look down inside the Baffle Tube Mounted on the Adjuster...
For as simple as it looks, I would never have guessed that it would take the better part of 3+ days to get to this point...Those one off setup are a time Killer
Hope You enjoy the progress...
Best Regards,
Preston
ps, we will most likely be making another Primary Baffle Tube without the wrinkles at some point
Edited by PrestonE (11/23/08 05:09 PM)
rwiederrich
Goldfinger
Reged: 11/17/05
Loc: Always Dark skies of Belfair W...
      #2767785 - 11/24/08 12:58 PM
Amazing....show stopping amazing!
Rob
Mert
Reged: 08/31/05
Loc: Spain, Pamplona
Re: 20 inch RC Robotic Build...a TEAM Effort.... new [Re: rwiederrich]
      #2768170 - 11/24/08 04:17 PM
It just keeps attracting me to read on and on
Must be the CF material, like a black hole, strong
atractor!
Good job Preston,
PrestonE
Reged: 04/29/05
Re: 20 inch RC Robotic Build...a TEAM Effort.... new [Re: Mert]
      #2768231 - 11/24/08 04:50 PM
Rob and Mert thanks for you always kind words and support...
Things are progressing...I think that I solved my design issue with being able to adjust the Secondary Baffle last night while DREAMING me Please
No really and I've started work to that end today...pics tomorrow, but I had really been dreading this one and the design is so simple I cannot believe that I did not think of it earlier...
Hopefully the aluminum order comes today for the material needed for the Squaring Plate/Field Rotator...and hopefully the team member that has the Paramount VersaPlate got it shipped to me today...
Best Regards,
Preston
ps...also got an idea for a Primary Mirror Cover that will close over the mirror like flower peadles when the scope is not in use now if I can only find some more time...
PrestonE
Reged: 04/29/05
      #2779039 - 11/30/08 08:18 PM
Well the Thanksgiving weekend gave me at least 36 hours of machine time on things...got the Primary Baffle drilled for the Collimation Jig...now need to redo the Baffle to rid us of the wrinkles...
Thus, had to fill in the groves in the mandral from sawing the Baffles to lenght and then drilling the mounting holes...there has to be a better way
Moved on to the Field Rotator/Squaring Back and have progressed nicely without any errors
When you see the drilling pattern you'll understand my happyness....
Pics will be posted tomorrow...I've been going from about 8am to 5pm for the past 4 days and couldn't think about sizing pics and then posting...
Until Tomorrow,
Best Regards,
Preston
PrestonE
Reged: 04/29/05
      #2785085 - 12/03/08 08:38 PM
Errrrrr the left brain was not talking to the right brain
We had a slight problem corp up but have fixed it and that is the sign of a good machinist....and the fix is elegant... for a fix....
The mind does strange things some times...like assuming that the radial distance and the offset from that radial to a point to the side would be where you would spot the event....
No, we should have rotated the Rotary table 12 degees instead of doing the offset...
More tomorrow...and I promise to update more often...
Best Regards,
Preston
PrestonE
Reged: 04/29/05
      #2786403 - 12/04/08 02:57 PM Attachment (48 downloads)
Ok so who wants to see more pictures of the past weeks work
Well here goes nothing>>>>>>>>>>>>>>>>>>>>>>>
We made the little adjusting pads out of gray teflon and then bonded them to the slotted SS adjusting screw.
These will allow us to adjust the Primary Baffle to the secondary baffle.
PrestonE
Reged: 04/29/05
      #2786405 - 12/04/08 02:58 PM Attachment (43 downloads)
The is a shot down the ID of the Primary Baffle showing just how the Adjusting Pad is working.
PrestonE
Reged: 04/29/05
      #2786408 - 12/04/08 03:00 PM Attachment (38 downloads)
And from the OD only the slotted end of the thread shows...we will blacken it although it is in the shadow of the secondary.
PrestonE
Reged: 04/29/05
      #2786419 - 12/04/08 03:02 PM Attachment (49 downloads)
Now we go to the Field Rotator/Squaring Plate and the beganning of CNC milling of the Rotator back plate.
PrestonE
Reged: 04/29/05
      #2786428 - 12/04/08 03:06 PM Attachment (41 downloads)
The plate blank is 13 x 14 x 0.50 inches for referance and we will end up reducing it's weight by better than half.
Here we have finished up all of the lightening pockets and the ID through hole and are working on the outer cut through.
Thus you can see the outline is just a triangle with the tips rounded.
PrestonE
Reged: 04/29/05
      #2786434 - 12/04/08 03:08 PM Attachment (48 downloads)
And the Rotator Back plate just out of the CNC looken pretty nice
PrestonE
Reged: 04/29/05
      #2786437 - 12/04/08 03:09 PM Attachment (46 downloads)
So since we fresh with programming the cnc we went straight to the Rotator Ring next.
Here we are at the end of shaping it on the CNC.
PrestonE
Reged: 04/29/05
      #2786442 - 12/04/08 03:12 PM Attachment (46 downloads)
Our CNC router is not as stiff as the one that Kerry had our other CNC made on but sure saves a lot of time for roughing out parts and lightening pockets.
Here we are turning the OD of the Rotator Ring after havinb bored the ID out to clean up the rougher edges.
PrestonE
Reged: 04/29/05
      #2786446 - 12/04/08 03:16 PM Attachment (40 downloads)
Now we need to bore the ID hole in the Rotator Back so that we can chuck it up on the Rotary Table and drill and mill the needed holes and slots to hold the bearings for the Rotator Ring and aligning bearings.
Here we are boring the central hole.
7 registered and 30 anonymous users are browsing this forum.
