GeorgeNC
Reged: 03/26/07
Loc: Land of the Sky, North Carolin...
Used a 300mm f/4.0 lens on my Canon 40D a few nights ago to image a portion of the Virgo Cluster. Several subs ruined by passing satellites and planes, but got seven good 4.5 minute subs - stacked with three darks and two flats in DSS.
Decent final image, but pretty bad vignetting.
Was able to correct it somewhat in Photoshop CS3:
link to image
Notice of edit: maximum width for images on CN is 800 pixels - I have converted your inline image to a link to conform with CN policy. CH
Did some research with google - one possible source of vignetting is using the lens hood. I extended the built in hood to its maximum to lessen possibility of dew forming on the lens. Wonder if shooting with aperture maximum open (f/4.0) with a lens hood exaggerates vignetting?
Have a moderate light pollution proble in that direction so I use a Hutech light pollution suppression filter inside the camera. Can that filter cause the vignetting?
Anyone have any other thoughts?
-------------------- Celestron C11 on CGE Mount
Stellarvue 80mm Nighthawk II
W.O. Flt110 on CGEM
Canon 40D (Hap Griffin modified)
Orion StarShoot Autoguider
Edited by Charlie Hein (05/06/08 07:21 PM)
huckabuck
Reged: 02/18/07
Loc: statesboro, ga
hey george, i dont have any experiance with digital but with film you need to close the aperture down 1 or 2 stops with almost all lenses. i usually stop down 2 stops.
GeorgeNC
Reged: 03/26/07
Huckabuck, thanks for the suggestion. I'm going to stop down to f/5.6 next time out and use less of the slide hood and see if that makes a difference. You'd think that you wouldn't need to stop down with Canon "L" glass, but we'll see what happens.
Clear skies,
George
W.O. Flt110 on CGEM
calder
Reged: 12/13/05
Loc: Schuylkill County, PA
Hi George, I also use film but I agree with huckabuck that stopping down the lens one or two f-stops will help. You might consider using a post processing program such as PixInsight LE to help remove the vignetting. I did a very guick process on your original image with this program and have included the result below so you can see the difference it makes. I hope this helps a bit. I'm sure some of the digital people here can help you even more.
Robert
-------------------- Bob's Astrophotography
Meade 295 (dust collector)
B&L Criterion 4000 (grab & go)
Celestron 9.25 CGE (work in progress)
Stellarview 102ED FT focuser (sweet)
Stellarview 70ED (Waiting for first light)
Canon F1
Mamiya 645
Stiletto
weatherandsky
Reged: 12/27/06
Loc: Ontario, Canada
HI George I get some degree of vignetting on all my lenses including the L zoom and Canon100mm @ f2.8. For daytime it is not noticeable but for night, the more you stretch the image the more vignetting you will see. I like shooting wide open so I just take flats to correct the problem.
-------------------- Kerry
* Weather and Sky Photography *
QHY-8, Canon 40D unmodded, Meade DSI-C
Meade 12" LightBridge
Astro-Tech 8in RC
Celestron C6-SCT
Sky-Watcher Equinox 80mm APO
Omcon 4.5" Newt
Celestron Skymaster 15x70
Canon 50 f1.8, 100 f2.8Macro, 100-400 f4.5-5.6L, Sigma 17-70, 18-50, 28-300
CGE, CG-5 GT
D_talley
Reged: 07/07/05
Loc: Richmond VA
Were you shooting raws and did you take your flats with the hood out and the filter in place? Normally the flats will take care of any vignetting.
-------------------- Dwight
SBIG ST2000xm
TEC 140 APO #74
Meade LX200 14 OTA
Orion 12.5 DOB
Celestron C8+
Celestron 102AZ
Losmandy G11 Gemini
Argo Navis
Canon 350D self mod
Hyperstar
ST-4 Guider
STV Guider
weatherandsky
Reged: 12/27/06
oops sorry George, I just saw that you said you took flats... I would ask the similar Qs as Talley then re the hood and filter.
Astro-Tech 8in RC
Celestron C6-SCT
Omcon 4.5" Newt
CGE, CG-5 GT
WarrenS
Reged: 03/04/08
Loc: Orange County New York
I wouldn't blame the lens hood especially if it's an attached sliding hood. The camera/lens makers have this well figured out to avoid vignetting. The length of the hood on a telephoto lens should be at least a little longer than the clear diameter of lens to block stray light and still not vignette . I don't own the Canon 300mm so I don't know how long the hood actually is.
-------------------- Warren
Astro-Tech 127EDT
Celestron Onyx 80ED
Astro-Tech Field Flattener
C8 (circa 1983 Orange Tube)
Atlas EQ-G, Orion SSAG
Canon 135mm F2.8 Nikon 180mm F2.8 ED
Canon 40D, Astronomik CLS clip filter
Leica, Minolta binos
GeorgeNC
Reged: 03/26/07
Thanks all - some good ideas:
I took them with the filter in place, but didn't have the hood extended. Next time I'll extend the hood.
Your post processing of my image looks pretty good - I'll look into that software.
It is a built on sliding hood - you'd assume the Canon people would have designed it correctly. As I said above, I'm going to slide only partially (I don't have much stray light at my location) and will make the flats with the hood in the same position.
Clear skies all,
George
W.O. Flt110 on CGEM
Andrew Welsh
Reged: 03/28/06
Loc: Rochester, NY
Inverse square law, my friend. I get vignetting on the 300/2.8 - a $3900 lens!!!
You'll get vignetting on any f/4 lens. Don't waste your time stopping down. It's not your lens hood. Stopping down to f/5.6 means you'll double your exposure time / halve the light gathered / halve your productivity. Shoot at f/4 if the lens is sharp (and it should be) at f/4 and correct with flats + in software.
Here's a stack from the 300mm f/2.8 @ f/2.8 with no flat applied-- terrible vignetting!
-------------------- LX200 8" classic, f/10, Meade eq. wedge, .63x FF/FR
Canon 40D and 5DMkII, unmodified
Canon EF 200/2L IS, 300/4L non-IS, 100/2.8 Macro, 50/1.4, 85/1.8, 35L, 24L, 16-35L and Peleng 8mm fisheye
Orion Apex 102mm (4") Mak-Cass
Pimped out with accessories and bling
My DSLR Astrophotography Webpage and photo bucket with full equipment list
soreneck
Reged: 04/01/06
Loc: Toronto, Canada
I second Andrew's experiences. I got significant vignetting on a Canon 70-200mm f4 lens at 200mm for a variety of stops. Flats corrected most of the vignetting. (I'm trying to find one of the original captures to illustrate, but they aren't on this PC.)
-------------------- Adam
TMB 130SS / WO 66 Triplet
QHY9 for sale (PM me if interested)
STL-11000M (new to me!)
Modified Canon 450D
SkyWatcher EQ-6 Pro
Urban backyard roll-off observatory
One small but fearless dog (observing companion)
DrGolds
Reged: 04/06/08
Vignetting, while stacking, is cumulative. You may not see much vignetting on a single shot, but, once you stack up a bunch of images, it becomes a lot more noticeable. When I did some experiments with my 100mm f/2.8 macro, I found the vignetting at f/4 to be acceptable. Doubling exposure time to increase quality isn't so bad: f/4 is still very fast in the astro world. Using flats reduces the effects of vignetting at the expense of extra noise in the outside areas.
-Jeff
-------------------- Meade 10" LX200-GPS
Stanford, CA
GeorgeNC
Reged: 03/26/07
Just FWIW, I shot the same area of the sky last night with the Canon 200mm f/2.8L lens at full f/2.8 aperture - very slight vignetting with that lens (did make better flats to use - maybe had something to do with it).
link to image
W.O. Flt110 on CGEM
Edited by Charlie Hein (05/06/08 07:24 PM)
Kentari
Reged: 11/19/06
Loc: Belgium
It would amaze me if the hood causes vigneting this bad. This lens is designed for full frame camera's and any vigneting will be worse on those. Are you sure the flat was actually applied to the image?
It is easy to check if the hood is responsible, even without processing: shoot two flats, one without and one with the hood. The histograms should be identical. If you see no difference you might compare them on the pc as well.
Koen
-------------------- Darkstar 355 f/5 Dobsonian
Orion UK 8" f/4.5 Newtonian and WO ZS 80 FD on Losmandy GM8
Canon 20D DIY mod with Baader filter
A bunch of lenses: 10-22mm f/3.5-4.5, 17-40mm f/4, 50mm f/1.4, 70-200mm f/2.8, 300mm f/2.8
www.koenvangorp.be
