HANTO
Reged: 08/24/07
Loc: Unterallgäu, Bavaria, Germany
a tough job entering against all those marvelous Jupiters.
But it´s still there and got more and more interesting: Saturn and his storms.
First a contrasted overview, showing at least 3 dark respectively light spots in the STrZ. Instrument: 8-inch Newtonian.
Smoothly processed.
And a bit more sharpened.
Hope it got your interest too, best regards
Torsten
Stathis
Reged: 10/05/07
This is an excellent picture Torsten! I just got the dmk and took some avis of the moon tonight. Saturn looks amazing, and at all of your pictures you can see the storm, the big one.
Edited by Stathis (05/15/08 07:06 PM)
Mike Phillips
Reged: 02/21/06
Loc: Swift Creek, NC - 35.682 N, 78...
Last one is AWESOME! Not sure I count all three, but I'm very impressed for an 8" How'd you rate the seeing?
-------------------- New home:
http://maphilli14.multiply.com/
Older Astro Photos:
http://picasaweb.google.com/maphilli14
HowTo: Planetary Processing Routine v7
http://maphilli14.multiply.com/journal/item/37/Michael_A._Phillips_Planetary_Processing_Routine_version_7.0
Mare Nectaris
Reged: 03/09/08
Loc: Toijala, Finland
Hi Torsten! Very professional achievement on those storms! And the overall presence of the Saturn is excellent on your pics!
Congrats!
Be well - and thanks for sharing these with us!
-------------------- Share - and you shall have it all
Timo Keski-Petäjä
CtheMoon
Observation shelter KuuMaja (MoonHut)
TAL 250K*Celestron C8-N*SkyWatcher Skymax 150 Pro*TAL1(Mizar)*EQ6 Pro SynScan*Celestron Advanced GT (CG-5 GOTO)*Baader Hyperion Clickstop Zoom 8-24*17 mm UWA-70*TeleVue BIG 2x Barlow*Celestron 2x Barlow Ultima SV Series
john D
All you have to do is ask!!
Reged: 08/05/07
Loc: Midlothian, VA
great shots Torsten! that look great!
-------------------- Meade ETX-125
Meade LXD55 mount
Philips SPC900NC webcam
Seymour Solar filter
Backyard Observatory
-Midlothian VA
--Land Of The Free Because Of The Brave--
HANTO
Reged: 08/24/07
Stathis, Mike, Timo and John
many thanks for your kind replies.
Best regards
Torsten
Edited by HANTO (05/16/08 01:48 PM)
HANTO
Reged: 08/24/07
Mike, many thanks for your comments.
I guess it´s been a 5-6/10. There were some moments, when you could see the CD quite clear in the red channel. In contrast the CD was hardly visible in the blue channel.
As an example, I attached a slightly sharpened stack of the blue channel out of app. 200 frames. You also can compare this one with a slightly sharpened stack of the red channel in the next answer.
Regards
Torsten
Edited by HANTO (05/16/08 02:07 PM)
HANTO
Reged: 08/24/07
Stack out of app. 600 frames of the red channel.
Talstarone
Vendor (Inner Planetary Products)
Reged: 09/12/06
Loc: Benson, North Carolina
Outstanding Work Indeed.The images are extremely impressive.Job well done!
-------------------- Todd C.
Celestron NexStar 4SE(102mm F/13)Maksutov-Cass
Meade ETX-80AT(80mm F/5)Achro Refractor
Meade ETX-60BB(60mm F/5.8)Achro Refractor
www.innerplanetaryproducts.com
Meteorites and More....
"Outer Space at Down to Earth Prices"
HANTO
Reged: 08/24/07
Many thanks to you, Todd!
Regards Torsten
HANTO
Reged: 08/24/07
Below, a first impression of the storm area 1 week earlier.
The images are composed out of 2 videos (R and G channel).
A few sharpening variations of each stack were added and those results added again.
Due to bad seeing, with no information in the B-channel concerning the storm, I didn´t try an RGB.
Well, I believe in the inverted vision there are 3 dark spots visible.
Regards
Torsten
Edited by HANTO (05/17/08 01:03 PM)
siriusc
Reged: 04/03/07
Loc: Racine, WI
Hi Torsten, if your storm is confirmed we'll all have to call it "Tropical Storm Torsten"! BTW, excellent composites! cheers, Dan
HANTO
Reged: 08/24/07
Hi Dan,
thank you for your comment!
Regards Torsten
HANTO
Reged: 08/24/07
Hi all,
I made an animation out of the observing session containing 7 pics R+G composed.
Time intervall: 19:48 UT - 20:55:30 UT.
A smaller sample:
Please click here for a more detailed version.
Regards
Torsten
Edited by HANTO (05/20/08 07:36 PM)
gazerjim
Reged: 02/12/04
Loc: About where I thought I was......
Torsten, Beautiful work! The animation is especially awesome.
-------------------- Jim Fisher
If you're not part of the solution, you're part of the precipitate.
Henry J. Tillman
HANTO
Reged: 08/24/07
Jim, many thanks to you. I appreciate this very much!
Best regards Torsten
HANTO
Reged: 08/24/07
Hi all,
data processing is going on. Here´s the latest effort on the data from May 14.
The videos about half an hour before showed fair to good seeing and the storm area between the CM.
I also made an enlargement, trying to show some structure in the storm area.
It would be nice if anybody could confirm this!
Edit: In the raw images archive of the Cassini-Mission I found 2 non-processed images (so called not validated/calibrated images), which show the storm region on 05/19/2008:
--- Cassini pic 1 - storm
--- Cassini pic 2 - storm.
The varied structure of the storm region is obvious. Unfortunately there are no images from 05/14/2008. The reason is, that the cameras were viewing the ring system.
Regards
Torsten
Edited by HANTO (05/23/08 05:04 AM)
HANTO
Reged: 08/24/07
Hi all,
in search for recent images of the storm region, I found 2 non-processed images (so called not validated/calibrated images) in the raw images archive of the Cassini-Mission, dating 05/19/2008:
--- Cassini pic 2 - storm .
Regards
Torsten
Edited by HANTO (05/23/08 05:12 AM)
solshaker
Reged: 06/06/06
beautiful shots, Torsten.
-------------------- My Gallery
HANTO
Reged: 08/24/07
Thank you!
Regards Torsten
