Privacy Policy |
Please read our Terms
of Service | Signup and
Philip Levine
Reged: 03/22/07
Loc: near Boston, MA
I am writing a term paper on Cepheid variable stars, specifically, on Henrietta Leavitt and her discovery of the period-luminosity relationship of Cepheids, used as a yardstick to measure star distances. What I cannot seem to find is information on how the intrinsic luminosity of a Cepheid was discovered, so that it could be used together with the apparent luminosity, in a distance modulus formula, to determine the distance in light years. I guess I am looking for how the math is done. I have done some reading and still cannot find specific information on how the instrinsic luminosity of a Cepheid was determined, either by parallax or by triangulation. All I find is a reference to Harlow Shapley calibrating the P-L relationship with a "statistical parallax method". Any help, or pointing to sources much appreciated. Phil
-------------------- _________________________________________________
Zhumell 10" Dob (modified with degree circle and Wixey inclinometer)
26mm 2" GSO eyepiece
9mm 1.25" GSO eyepiece
13mm Nagler T6
GSO ED Barlow
RACI 8x50 finderscope
Crayford focuser
DewBuster w/homemade heater strips
Nikon 10x50 EX binoculars
member International Dark-Sky Association
RLTYS
Reged: 12/18/04
Loc: New York (Long Island)
Philip
Have you considered contacting the AAVSO? I'm sure they can give you all the info you need.
Hope this helps. Rich (RLTYS)
-------------------- 10" F4.8 Refl.
4" F5 Refr.
80mm F5 Refr.
12x63 and 10x50 Binoculars.
Ben Mullin
Reged: 08/26/05
Loc: Lino Lakes, MN
There is some of what you are looking for in the AAVSO Variable Star of the Season article on Delta Cep.
http://www.aavso.org/vstar/vsots/0900.shtml
Philip Levine
Reged: 03/22/07
thanks very much for the suggestions. Phil
StupendousMan
Reged: 08/21/05
Sorry to be replying so late, but just in case you (or other readers) are still interested ...
The "statistical parallax" method is a classical technique for trying to estimate the distances to a set of (ideally) identical stars. The regular parallax technique involves taking pictures of a region at intervals of six months; as the Earth moves around in its orbit, the changing point of view causes nearby stars to shift relative to more distant ones. Unfortunately, stars must be very close for this method to work. The limit of the technique at the time of Shapley's work was probably around 100 parsecs, and very few or no Cepheids are that close.
So, what is "statistical parallax?" The basic idea goes something like this: first, identify a set of stars which are
a) nearly identical in their physical properties -- same color, same apparent magnitude, same spectral type. If you do this right, and all the stars really are similar in their intrinsic properties, AND in the apparent magnitude, then they should all be at roughly the same distance from you. Ideally, they will make a sort of hollow shell which surrounds you. You want to find the radius of this shell ... but how?
If you watch these stars over several decades, they will all move slightly in the sky relative to more distant stars. This "proper motion" is due to each star's particular motion as it orbits the center of the Milky Way, and due to the Earth's motion in its orbit. Now, if you have a large enough sample, and if the stars really are at the same distance from the Earth ... then their proper motions, considered as a set, should almost cancel out. That is, there should be roughly equal numbers of them moving left, and moving right; moving up, and moving down. If the Earth were stationary relative to the center of the shell of stars, you'd expect all the motions to cancel exactly.
But -- the Sun is moving in its own orbit through the galaxy. That means that the Sun is NOT motionless relative to this shell of stars. And that means that when you add up all the proper motions, you'll find a small left-over motion. This motion is really a reflection of the Sun's motion. If you know the direction and speed of the Sun's motion through the galaxy, relative to other stars -- which we do know, to some degree -- then you can use the apparent angular residual motion to determine the distance to the shell of stars.
A bunch of really, really luminous stars of apparent magnitude 10 would be very far away from us ... and so the Sun's motion through space would cause almost no residual motion. We'd measure almost no residual -- the motions of the different stars would cancel exactly.
A bunch of low-luminosity stars of apparent magnitude 10 might be within a few parsecs of us. The sun's motion relative to this group of stars would leave a very large residual when we average all the proper motions ... which would tell us that the stars in this group must be very close.
That's the basic idea of statistical parallax. You can find more detailed descriptions, with the math, in graduate textbooks like Mihalas and Binney or Binney and Tremaine.
I just checked the ADS, and don't see any papers written by Shapley during the 1910s or 1920s which deal with statistical parallax. Hmmm.
Charlie B
Reged: 03/22/08
Loc: Virginia
There is a good explanation in "Galactic Astronomy" by James Binney and Michael Merrifield, Princeton Series in Astrophysics, 1998
Charlie
-------------------- Meade SN-8, DS-90, AT-66
DSI Pro II (Schuler Filters), DSI-C, LPI, Canon XTi
AIP4WIN, Nebulosity, DSS, Registrax, GIMP
running on Dell 1420 with Vista
Philip Levine
Reged: 03/22/07
Thanks for the additional information, I'll pick up copies of the books mentioned. Much appreciated, Phil
13mm Nagler T6
GSO ED Barlow
Crayford focuser
Moderator: RLTYS
