OldDeadOne
Reged: 09/09/06
Loc: West Virginia
What filter did you use to view the horsehead?.This is a object that is on my viewing list and I hope to eventually see this.I've been in the mist of a being a glutton on galaxies,but will be turning my attention back(somewhat,I'm not done with galaxy viewing,the glutton in me beckons!)to nebula viewing. My last session was one of the best I've had in spite of the moon,so I was thinking about the horsehead for some reason lol
-------------------- Bert O'Dell
PROUD GOTO USER
LX200 10" Classic
various meade plossi's eyepieces
Konig MX70 40mm" eyepiece
11mm T6
7mm T1
Insane under a full moon
I duck from Iron Skillets
Charleston WV clearsky
Achernar
Reged: 02/25/06
Loc: Alabama, USA
A hydrogen beta filter is the one to use on the Horsehead and the emission nebula it's in front of, IC-434. It will make it visible, but unless you are looking through a 16 or 18-inch telescope from a dark site, it will not be very prominent with or without the filter. In my 10-inch B-33 looked more like a vague dark shape that kinda looked like a horse's head. Without the filter, I had a hard time seeing just IC-434 with my 10-inch and that was from a dark site. The Horsehead really benefits from larger apertures, but it is not impossible to see if you have a modest telescope like most folks do. Unless the moon is absent and the sky very dark and clear, I wouldn't bother with this object. It's reputation for being tough to see is well placed.
Taras
-------------------- 10-inch F/4.5 Discovery Dob
6-inch F/8 Homebuilt Dob
4 1/4-inch F/4 Homebuilt reflector
BillFerris
Reged: 07/17/04
Hi Bert,
The hydrogen beta is, hands-down, the best filter for Horsehead hunting. The trick is to use a filter that enhances IC 434, the background nebula against which the dark nebula, B33 (Horsehead), is seen. IC 434 is a low-excitation nebula with almost no OIII emission. The OIII emission is so minimal that an OIII filter makes IC 434 almost impossible to see. And if you can't detect IC 434, the Horsehead is out of the question.
By contrast, a hydrogen beta filter will enhance IC 434, making it easier to detect. This in turn punches up the contrast between the Horsehead and IC 434. Good transparency is critical to Horsehead hunting. Dark skies are also a must but transparency is the real key. From the high elevation sites I use, I've never failed to see the Horsehead, unfiltered, with my 18 inch. I've seen the Horsehead unfiltered in a 6 inch from a site that isn't quite as dark but enjoys the same excellent transparency.
A UHC filter offers a slight enhancement of IC 434. It's only a modest improvement so, if you can see the Horsehead with a UHC filter in place, it will usually be visible unfiltered, too. And as mentioned above, an OIII filter is deadly; it's a Horsehead killer.
Bill in Flag
-------------------- Grand Canyon Adventure
Lowering the Threshold
18" Obsession
4.5" Meade 4500
10x50 Swift Audubon
Cosmic Voyage
David Knisely
Reged: 04/19/04
Loc: Beatrice, Nebraska
Well, it is getting a bit low and hard to see now (at least from the Northern Hemisphere), but in general, the H-Beta filter is the one to use. I have seen the faint band of IC 434 and just managed to glimpse the tiny notch of the Horsehead itself under dark skies using only my 100mm f/6 refractor (15x) when the H-Beta filter was in, although the view was somewhat marginal. There have been those at moderate to high altitude sites who have seen the Horsehead in scopes in the four to six inch range *without* using a filter, but this tends to be somewhat less frequent, as it requires excellent conditions and a little effort to get out a lot to try. The object is visible in larger apertures without filtration, but this again requires quite good conditions. It can be seen in my 9.25 inch SCT, but still is more of a vague slightly darker gap in the very faint nebulosity than a detailed figure (at least without a filter). Put in the H-Beta and, while it is still quite dim, the object stands out a lot more with hints of the "snout" using averted vision. The DGM Optics NPB filter has been known to help the Horsehead as well, although perhaps not quite as much as the H-Beta filter does. Clear skies to you.
-------------------- David W. Knisely
Hyde Memorial Observatory
http://www.hydeobservatory.info
matt
Vendor (Scopemania)
Reged: 07/28/03
Loc: Chaville, France
H-beta, UHC do it. If you have neither, I recommend investing a "UHC" (any narrowband filter with OIII + H-beta bandpass) - it will work for the Horsehead and a bunch of other nebulae. H-beta is a more "specialized" filter.
-------------------- Matt
CI700 mount with various scopes on top.
Never
Reged: 11/22/05
Loc: Finland
B33 was visible fairly easily from a high altitude site a few months ago with a 4.7" telescope @ 38x + UHC filter. It is not horsehead-shaped as with larger apertures but still visible. Also it was a lot easier see from the high altitude site in Spain than from a dark site in Finland even when using an 8" telescope.
/Jake
-------------------- Jaakko Saloranta - Some basic sketches.../
8" Orion DSE
4" Sky-Watcher
3" Konus RFT
OldDeadOne
Reged: 09/09/06
Loc: West Virginia
Thanks to all who replied,I see a H Beta filter in my future and probably will use shop n swap to get one.
PROUD GOTO USER
LX200 10" Classic
11mm T6
7mm T1
3 registered and 6 anonymous users are browsing this forum.
Moderator: matt, Olivier Biot
