Mattbtn
Reged: 02/08/06
Loc: Chattanooga, TN
Dual-Core or Quad-Core?
      #2423866 - 05/28/08 12:00 AM
I'm finally putting together a new system, and I think I've got just about everything figured out except for the 'durn processor.
I don't really keep up with what programs currently utilize what technologies, and I really don't have much idea where things are going down the road. I mainly run Photoshop CS3 and Lightroom, along with a few other photo programs and things like Office, Acrobat, etc... In a nutshell, I multi-task like crazy and hate being bogged down.
So, if you only upgraded machines every few years, would you suggest a Quad-Core processor or a Dual-Core processor?
I've boiled it down to 4 different processors:
E8400 - 3.0ghz Dual Core
E8500 - 3.16ghz Dual Core
Q9300 - 2.5ghz Quad Core
Q9450 - 2.66ghz Quad Core
Thoughts? Comments?
"Computers help us solve the many mysteries of the universe. They also help us make the same mistake many times, really fast."
Tom LModerator
Reged: 01/07/04
Loc: Sunny Oregon
Re: Dual-Core or Quad-Core? new [Re: Mattbtn]
      #2423879 - 05/28/08 12:08 AM
I went dual core mainly based on price. The quad was twice the price. If money were no object I would go quad, but a minimum of a dual core.
12" f/5 DSO Dob
Tele Vue 102mm f/8.6 on an EzTouch
Vixen 80mm f/5 A80SSWT on a grab-n-go mount
rboeAdministrator
Numbfinger
Reged: 03/16/02
Loc: Phx, AZ
Re: Dual-Core or Quad-Core? new [Re: Tom L]
      #2423904 - 05/28/08 12:22 AM
I got a killer deal on a Dell with a quad core in the Dell Outlet store (Optiplex 755 small form factor). After using it I think you are better off with a faster dual core - not much software has any clue what to do with more than two cores.
I have the Q6600 running at 2.4GHz; but right now it's running at 1.58GHz, sometimes even slower - it's just not that fast. Even when running Photoshop or Elements. I'm using XP so the OS is not really optimized for the 4GB of ram or the four cores either but I have not tried Linux yet.
So at this point it seems to me having a quad core is being a wee bit ahead of the curve and the world is not really ready for it yet.
Ron
NS11GPS
Pronto
16" dob
15X70 Obies
Rusty
Reged: 08/06/03
Loc: Brooker, FL
      #2423919 - 05/28/08 12:35 AM
Adobe is likely to be the first to implement multi-threading for quad cores, so if you use Photoshop much, the quad is the way to go (although rumors I've heard is that full-quad support will require CS4 - but they're that - rumors; there may be an affordable upgrade for CS3 - which can utilize quad-core).
Adobe is one of the very few companies which has actually implemented multi-core support, AFAIK.
If you want to be on the "bleeding edge", the Q9450 on an X48 mobo (DDR3 RAM)would be the way to go, and the longest delay to obsolescence (maybe as much as 3 months ). Note that the Q9300/9450 and E8500/8400 are spec'd to run with 1333 FSB, and DDR2 would be tough to bump that high.
I'm facing the same choice before too long, as I'm slowly accumulating parts to replace my 5 year old PC...mobo, processer, heatsink, and RAM are the final choices, and I'm gravitating towards an X48 mobo, 4 GB DDR3 RAM, and the E8500 (maybe the E8400) - as I intend to overclock (as I've always done).
In any event, I'd also recommend an aftermarket HSF - the excellent Zalman CNPS 9700 LED is on sale at NewEgg, here for ~$54.00.
N11GPS Fastar
TOA-130S
MK66 Std
Vintage C5
Megrez II 80mm ED Triplet APO
SolarMax 40
NJP Temma II
Sirius EQ-G
ST8XE/CFW-8 (LRGBHa)/AO-7/DF-2/STV/ST237a/350D (Unmodded)/Mallincam Color Hyper Plus/DSI III Color
Two not-spoiled Golden Retrievers - Maggie and Casey
Sometimes I think we're alone in the universe, and sometimes I think we're not. In either case the idea is quite staggering. - Arthur C. Clarke
spoolboyy
Reged: 08/01/05
Loc: Lewiston, Idaho
Re: Dual-Core or Quad-Core? new [Re: Rusty]
      #2423980 - 05/28/08 02:32 AM
Just to qualify my comments (not to say "look at me I'm a smart guy!", I am a software developer.
The biggest question here is what OS will you be running.
XP is NOT optimized for quad cores. It will barely utilize them because the OS is designed to handle at most two processors (or cores in this case).
Vista (or Linux for that matter) can handle a quad core and actually get some use out of it. MS Windows Server 2003 can handle 8 cpus/cores, but isn't an ideal desktop operating system.
Photoshop in Vista (but not XP) will take advantage of the quad core for graphical rendering since your operating system is what distributes resources for your applications, not the other way around.
Quad cores also help with video rendering immensely over a single core.
All that said, I'm picking up the parts for MY new system at the UPS depot tomorrow, and I purchased a dual core CPU. That's what I recommend you get if you intend to run windows XP. The quad core may help you if you choose to run Linux or Vista but rboe hit it right on the head when he said that most applications out there are fairly clueless on how to optimize all four cores at this point.
I hope this helps somewhat!
//ADAM
Celestron 'Hopper 6"
spoolboyy
Reged: 08/01/05
Re: Dual-Core or Quad-Core? new [Re: rboe]
      #2423985 - 05/28/08 02:35 AM
The OS is exactly the problem here. XP is basically unable to take more than intermittent advantage of more than just two of the cores.
with Linux or Vista running a graphics program or executing a CPU test you'd see the CPU running at 100% of its clock speed.
with regard to ram, XP (32-bit XP, the version 99% of XP users run) does not have enough addresses to assign to all 4 gb of ram, so it also only sees 3.x gb of ram when you run direct x diagnostic or check under My Computer, Properties. The RAM is all there, but the OS has no way to index all 4 gigs, so it uses what it can. When running XP, 2 gb is the sweet spot, but more will not hurt performance.
for now he's ahead of the curve, but thats not necessarily a bad place to be, other than his CPU is running well under its most effective speed.
-adam
daev
Reged: 03/10/04
Loc: On the edge of the desert
Re: Dual-Core or Quad-Core? new [Re: spoolboyy]
      #2424009 - 05/28/08 03:06 AM
With non-multi threaded apps, you'll get more bang for the buck with the dual. It will have a higher clock speed for the money spent. As apps become more multi-thread capable this will lean towards the quad. If you plan on upgrading again in a couple of years, satisfy yourself with a fast dual.
dave
"Yes, I know it's flat here. When the seeing is good you can stand on your toes and see Chicago...."
Mattbtn
Reged: 02/08/06
Re: Dual-Core or Quad-Core? new [Re: daev]
      #2424109 - 05/28/08 07:23 AM
Thanks for the input everyone!
I'm leaning towards Vista Business 64-bit as my OS, simply because I'm fairly confident that things will work just fine for now. I've still got a few jitters moving away from XP Pro, so I'm going to just have to work past them!!
The Quad Core that I really want is the Q9450, but it's roughly twice the price of the E8400 Dual-Core and I'm not so sure the performance boost will be there right now, and might even be worse in certain applications.
I'll post updates when I get everything finalized, but it looks like Dual Core will be my choice and again, I really appreciate all of the advice!!
spoolboyy
Reged: 08/01/05
      #2424579 - 05/28/08 12:26 PM
good luck with your choices!
//ADAM
rboeAdministrator
Numbfinger
Reged: 03/16/02
Loc: Phx, AZ
      #2424724 - 05/28/08 01:27 PM
When you go with the Outlet store your choices are a bit limited. I'm hoping to grow into mine. Should feel about right just before I have to upgrade - again.
Ron
NS11GPS
Pronto
16" dob
15X70 Obies
o1d_dude
o1der than dirt
Reged: 10/03/07
Loc: The Big Tomato, California
      #2424729 - 05/28/08 01:30 PM
The E8400 is a good choice for anything less than a "God Box".
Vista on the other hand is a bit more problematic. I'd be more inclined to stay with a proven OS rather than go with an OS not many are supporting or choosing. YMMV.
Kit
"There's only two things that excite a man, expensive toys and real expensive toys." - Red Green
* A bunch of old ATM stuff that cost me next to nothing
* A bunch of new commercial stuff that cost me an arm and a leg
Mattbtn
Reged: 02/08/06
Re: Dual-Core or Quad-Core? new [Re: o1d_dude]
      #2424775 - 05/28/08 01:56 PM
Well, I placed the order a short bit ago on Newegg...I went with:
- DFI LP LT X48-T2R LGA 775 Intel X48 ATX Intel Motherboard - Retail
- Vista Business SP1 64-bit
- (2) Corsair 4GB (2x2GB) DDR2 800(PC6400) Memory
- Intel Core 2 Duo E8400 Wolfdale 3.0GHz LGA 775 65W Dual-Core Processor Model BX80570E8400 - Retail
- (2) Western Digital Caviar SE16 WD4000AAKS 400GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
- ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler - Retail
I've already got an ample Case, Power Supply, Video Card, Sound Card, etc..., so I think all of the above will make my system much more suitable for what I'm doing on a daily basis.
Now I've got to figure out this Windows Easy Transfer and make sure all of my stuff is properly backed up before I make the switch and wipe my current machine clean.
Edited by Mattbtn (05/28/08 07:36 PM)
Tom LModerator
Reged: 01/07/04
Loc: Sunny Oregon
      #2425391 - 05/28/08 07:30 PM
Good luck and nice selection!
12" f/5 DSO Dob
Rusty
Reged: 08/06/03
Loc: Brooker, FL
      #2425900 - 05/29/08 12:35 AM
You're on your way! The only thing I'd question is the choice of RAM (DDR2 800) when the CPU is designed to run at DDR3 1333, and the X48 mobo supports it...but if you intend to overclock the memory, the Corsair is one of the better...
But my current choice for mobo is the same as you selected.
N11GPS Fastar
TOA-130S
MK66 Std
Vintage C5
SolarMax 40
NJP Temma II
Sirius EQ-G
Mattbtn
Reged: 02/08/06
      #2426156 - 05/29/08 07:43 AM
Rusty, I mainly went with the DDR2 800 memory because it's suppose to be a good performer and is 3-4 times cheaper than DDR3 memory, plus the board itself was quite a bit less. According to the documentation I've seen I believe I can overclock the memory to 1066, so I'll probably try that and see what kind of stability and performance boost I can get by doing so.
I actually still can't decide which MOBO I want to use, which is why I've got two coming. Both are very similar boards, except one uses the X48 Chipset and the other uses the P35 chipset. I think I'm going to stick with the X48 chipset since the board itself is better equipped for future upgrades, but I'm going to do some reading over the next few days and try to make a decision before I put everything together.
On that note, do you know much about chipsets and the pros/cons of each?
Rusty
Reged: 08/06/03
Loc: Brooker, FL
      #2428263 - 05/30/08 01:00 AM
A little - much less than when I built Peecees. Assuming you don't want to run two video cards in harmony (SLU or Crossfire), then the core logic maker isn't an issue. The X48 is Intel's latest (Except for the P45, which is cheaper, and has less upgrade headroom), then the X38/35; the nVidia nForce 790i is its flagship, with the 780i slightly cheaper. IMHO (and remember, I've not any first-hand experience with any of these chips), the X48 is the way to go, as it doesn't command the prices of the 790i, and the P35 is really yesterday's technology.
As to mobo makers, I've used boards from Biostar (a PC with a Biostar mobo I built in '94 - I think it has a P1-233 - is still running as host for an office's backup drives), Soyo, MSI, DFI, Asus, Abit, Gigabyte, and had only one failure, that on an Abit (call from the customer 4 PM the Wednesday before Thanksgiving) due to blown capacitors, an eventually known defect. Lately, I'm inclined towards Asus and DFI. This DFI mobo (what you just ordered) is also my current fave; the only thing I find puzzling is the floppy disk supplied for the Southbridge and RAID, but no FDD header (they're a thing of the past, anyway). I have an external USB 3.5" FDD, which I suppose will work.
As for the power supply, depending on what you have now, you may need adaptors for the mobo and the video card (What will you use? - I caught an EGVA 8800 GT on sale), or, worst-case, a new P/S. I ratholed a PC Power&Cooling 750W Silencer.
N11GPS Fastar
TOA-130S
MK66 Std
Vintage C5
SolarMax 40
NJP Temma II
Sirius EQ-G
Mattbtn
Reged: 02/08/06
      #2428453 - 05/30/08 06:24 AM
Now that you mention it, I'm not sure how I'm going to deal with the floppy disk issue if that's really what it takes to load the RAID drivers. I guess I can use my existing machine to copy the contents onto a CD and see if that will work.
My OCZ Power Supply is starting to become a bit dated, but I think should work just fine with everything I'm doing with this build. My video card (EVGA 7900 GT) is also becoming a bit dated, but again should be fine for most of the programs I'm running.
My next big upgrade will be a monitor. I've been using this Sony 19" LCD for several years now, and it just isn't anywhere near the quality of a lot of these new ones on the market, not to mention that I'd LOVE to get my hands on a nice 24"-26" Widescreen.
Elektronkind
Reged: 06/10/07
Loc: Silver Spring, MD
      #2429055 - 05/30/08 12:20 PM
I'd vote that you stay away from the hardware RAID that's built in to consumer boards. If anything, use the software RAID facility in the OS you plan on using, and especially so if all you're going to do is mirror drives.
The reason being is that the hardware RAID that's implemented in the SATA controllers chip on the motherboard ties your RAID'd disks to that particular implementation. This can come back to haunt you later if your mobo dies and you cannot find a replacement with the right SATA chipset. You might as well have a wiped drive in some cases.
If you use the RAID functionality in Windows or whatever your OS us, you will not run into this problem as the usefulness of your disks is not tied to whatever your motherboard's RAID controller happens to be.
/dale
Orion XT10i + Telerad
WO Megrez 90 APO
Astro-Physics Mach1GTO
WO EZTouch mount (AYO version)
TeleVue Nagler 3.5T6, 7T6, 22T4
Coronado PST (Hα)
Canon Digital Rebel XTi
Peter Argenziano
Watcher of the Skies
Reged: 11/11/03
      #2430116 - 05/30/08 07:55 PM
I recently got a Dell XPS420 that uses a Q6600 Quad Core. I'm running a 32-bit Vista OS, so I went with 3 GB of RAM, for the reasons articulated earlier. It also has a 500 GB RAID 1 setup and a decent ATI Radeon graphics card. Nothing real fancy, but I've been really pleased with the system.
Frankly, I don't understand why many people are so reluctant to go with Vista. I also bought 2 laptops recently, both 32-bit Vista OS - and have had zero problems.
On my desktop system I run all kinds of applications: Sky Tools, The Sky, Megastar, Microsoft Worldwide Telescope, Lunar Map Pro, Astroplanner, Photoshop CS2, Illustrator CS2, InDesign CS2, Acrobat Pro 8, Dreamweaver MX 2004, Fireworks MX, Flash MX, Visual C++, Visual Basic, UltraEdit 14, UltraCompare 5, PHP 5, SQL Server 2005, MySQL 5, MS Visual Web Developer 2008, Open Office 2.4, PitStop Pro, Apache Web Server 2.2, etc., etc.
Zero problems installing or running anything.
Peter
0.635 meter Obsession #620
80mm ED | Panoramic
We do what we have to do in order to do what we want to do.
Rusty
Reged: 08/06/03
Loc: Brooker, FL
Re: Dual-Core or Quad-Core? new [Re: Peter Argenziano]
      #2430771 - 05/31/08 02:40 AM
Having installed RAID (Raid 1 exclusively) on mobos using onboard controllers for the last 15 years, I disagree, although that MIGHT apply to RAID 0 and 0+1. A solo HDD running RAID 1 doesn't know it is, and it can be migrated to another mobo with a different controller, and its "slave" mirrored with the new controller. At least every instance I've encountered can, even when going from the early add-on cards (ARCO-RAID) to an onboard controller, whether IDE, EIDE, or SATA.
Software RAID 1 (under Win-whatever) in my experience is both slow and unreliable, but that's not saying that an app under Linux would be also.
Every RAID controller I've encountered treats the Primary as a normal BIOS-enabled HDD,and deals with the secondary, as a mirror.
While you may have reasonable experience to favor software RAID, I submit only this: No hardware RAID I've installed has ever produced the BSOD...
N11GPS Fastar
TOA-130S
MK66 Std
Vintage C5
SolarMax 40
NJP Temma II
Sirius EQ-G
2 registered and 5 anonymous users are browsing this forum.
Moderator:  desertstars, Tom L
Home
