mattyfatz
Reged: 12/27/06
Loc: R E N O
What can you tell me about this camera ? Or would you recommend something else in this price range? Is it better to get a color or monochrome camera? can the frames be captured and stacked to create images? thanks for you help
-------------------- *****MATTY******
All sorts of stuff
mclewis1
Thread Killer
Reged: 02/25/06
Loc: Colorado
What kind of imaging do you want to do?
Solar system objects
DSO
- extended objects (nebulae/clusters)
- galaxies
- globular clusters
- planetary nebulae
Live view DSO
Through which of your scopes?
Edited by mclewis1 (05/29/08 01:51 PM)
BrendanF
Reged: 12/04/07
Loc: Los Angeles, CA
The MFG page says the frames can be captured.
My impression is that these high-frame rate cameras are best for planetary (bright small things) imaging where the frame rate allows capturing the good seeing moments and filtering out the bad. If that is what you want to do, it will probably work. There are a number of other choices for planetary imaging, such as those offered by Orion and web-cams.
More helpful answers are probably contingent on what your answers are to the questions posed by mclewis1.
mattyfatz
Reged: 12/27/06
Loc: R E N O
Marc I guess I'm thinking about imaging a little of everything. For starters I'd hook it up to one of the newts and put it on the CG5 mount. Then maybe a little Dob work with a monitor to impress people  For planetary work I'd use the c6. I am attracted to the relatively low entry price of these things. Matty
All sorts of stuff
Astrojunk
Reged: 11/02/06
Loc: Australia
Matty, you may be better getting advice in the astrophotography section. Imaging source cameras are world class imaging devices used by the very best planetary astrophotogtaphers (and some not so good ones too !)
The sort of camera we use here are more suited to real(ish) time, in the field work rather than imaging. In particular, all the cameras here can be used without the need for a computer - i.e AV out. You can image, and I've had some nice results with mine, but something as simple as a meade DSI II will blow them out of the water in that regard.
But give us a dark sky and a tv monitor, and we will win every time for instant gratification!!!
-------------------- Astrojunk
20" f5 Alt Az Newtonian
smokin oakum
Reged: 09/24/07
Loc: Wilmington, NC
Yes, these are great planetary cameras, but if you're going for DSOs in real time to impress freinds, you might end up getting the golf clap. For planetary imaging they can't be beat.
If I were you, I'd just go over to the planetary forum, and ask your question there.
Neil
-------------------- Broadcasting live views of the night sky @
Sparkcast
C11 CGE / Hyperstar
MallinCam Hyper Plus Color
Orion 12" XTi f/4.9
MoonLite Focuser
Round Table Platform
12" Parralax rings
Cape Fear Astronomy Club
dvb
Reged: 06/18/05
I just picked up the Philips 900 webcam from local computer supply store (NCIX) and the nice CNC nose-piece adapter from "Modern Photonics" -- total price $130.00. Haven't had a chance to try it yet, but it seems to be a rig lots of people are having success with.
-------------------- Skywatcher 10" f/4.7 Newt on Matilda
Skywatcher 10" f/4.7 Collapsible Dob
Meade 8" SN f/4
Celestron C8 SCT
Celestron C6 SCT
Skywatcher ED100
Skywatcher ED80
EQ6 Pro "Matilda"
AT Voyager
Skymaster 15x70
Mallincam HyperColor Plus
mattyfatz
Reged: 12/27/06
Loc: R E N O
Are any of these Video-Camera's suitable for DSO's? As far as the Imaging Source camera goes, it uses a fire-wire connection, so I don't think its meant for a moniter, but rather a PC or laptop. I guess I should have phrased my original post better. Has anyone used the DFK 21AF04AS and what were your results.
All sorts of stuff
smokin oakum
Reged: 09/24/07
Loc: Wilmington, NC
You can use these cameras for DSOs, but you'd be better off with a DSI II. It will blow the socks off of the DMK on DSOs. The DMK is meant for high frame rate capture, and not really for long exposure. For DSOs on a monitor, you can't beat the MallinCam hands down!
Neil
By the way the camera of choice for planetary is this...
http://www.astronomycameras.com/en/products/usb-cameras/mono/dmk21au04as/
Edited by smokin oakum (05/30/08 09:14 AM)
Astrojunk
Reged: 11/02/06
Loc: Australia
Lester uses one here: http://southcelestialpole.org.au/forum/index.php/topic,8042.0.html
This URl may work better: http://tinyurl.com/5svnwd
Not too bad ...
Edited by Astrojunk (05/30/08 09:11 AM)
Rusty
Reged: 08/06/03
Loc: Brooker, FL
And the Mallincam can record direct to a DVD recorder...then the track converted to .avi, then separated by frame (I'm told).
-------------------- N11GPS Fastar
TOA-130S
MK66 Std
Vintage C5
Megrez II 80mm ED Triplet APO
SolarMax 40
NJP Temma II
Sirius EQ-G
ST8XE/CFW-8(LRGBHa)/AO-7/DF-2/STV Dlx/ST237a/350D (Unmodded)/Mallincam Color Hyper Plus/DSI III Color/DSI II Pro
Two not-spoiled Golden Retrievers - Maggie and Casey
Sometimes I think we're alone in the universe, and sometimes I think we're not. In either case the idea is quite staggering. - Arthur C. Clarke
Rusty
Reged: 08/06/03
Loc: Brooker, FL
Duplicate post deleted by Rusty
TOA-130S
MK66 Std
Vintage C5
SolarMax 40
NJP Temma II
Sirius EQ-G
mattyfatz
Reged: 12/27/06
Loc: R E N O
thats great stuff Rusty, Thanks for the advice everyone. I think what I will end up doing is getting one of the less expensive models for use at star parties and get togethers. I'll hook it up to an old moniter or TV and worry about serious imaging at a later date.
All sorts of stuff
