sarastro
Reged: 08/12/04
Loc: Seattle
Which flexible focuser should I get for my ETX90? The CNC Supply (Scopetronix) or one of those available on the bay for half the price? Any input would be most helpful. Thanks, Roger
StarWars
Reged: 11/26/03
Loc: CyberSpace
Flexible Focuser Extender for Meade ETX $17.50
-------------------- Sony Digital Media player..
MX 460 earbuds
Celestron 2x Barlow Lens
Orion Collimation Eyepiece
Rigel Quick Finder
Assorted Bino's
DanishSky
journeyman
Reged: 05/21/08
Loc: Jutland, Denmark
I bought one on EBay for my ETX90PE. It is quite OK. Kind regards Niels jørgen
Reged: 07/06/07
I bought one of these for the 125. Works OK--like similar ones I've tried, turning the end knob causes the fleible shaft to twist as well as turn, introducing some backlash. I'd prefer a moto-focus, but this is a lot cheaper, and is certainly better than trying to focus without one when the tube as at higher elevations.
-------------------- Uncle Rod
Rod's New Book:
Choosing and Using a New CAT
Available now!
sarastro
Reged: 08/12/04
Loc: Seattle
Rod,
The Meade 1244 electronic focuser ends up being only a couple of bucks more than the CNC Supply flexible focuser. Maybe I should just go for that?
Roger
Reged: 07/06/07
Rod,
Roger
I probably would. Just make sure this focus motor is compatible if your ETX is a PE!
Rod's New Book:
Available now!
southmike
Reged: 11/22/04
Loc: Fayetteville, NC
some of the ebays are not bad.. but this is the best deal I have seen. http://www.meade4m.com/4mshop/07077.html
-------------------- group scope pic
my refractors
LX200 10"-St120
LX200 8" f6.3-Orion 80ed
LX200 8" f10-Orion 90 Mak setup pic
Meade 102ED LXD650
Sky Watcher 100 ED Triplet prototype
Nexstar 5
etx125
etx70's
rollout
Reged: 03/25/08
Loc: Broken Arrow, OK
Bought one on eBay. 1st one was "LOST" and after a couple of emails (with no response) the seller finally responded and sent out another that works just fine. The 1st one never did arrive. I left the seller a NEUTRAL feedback, and he left me NEGATIVE feedback for being "A Sore Old Buyer".....LOL
BTW, eBay is going to only allow sellers to leave POSITIVE feedback (or none at all) so buyers are not afraid of this type of retaliation from a seller.
Make sure it comes with an allen wrench (mine didn't) or you still have the ones that came with your scope, or a really small one in your toolbox, as you most likely will need to remove your focuser knob and put it on the flex wire.
Bill
-------------------- Meade ETX-125PE
Purchased 4/7/8...I am a newbie
tjmck
Reged: 10/06/07
Loc: Winnipeg, Manitoba, Canada
Built one using a electrical binding strip barrel as the focus shaft to vinyl coated aircraft cable connector and installing the Meade focus knob on the end of the aircraft cable. Had the binding strip in my electronics supplies, aircraft cable available locally (less than $1 for the 10" required). Assembled and installed in 10 minutes. The specifics are on Mike Wiesners site.
tjmck
-------------------- And at night the stars they put on a show for free
- James Taylor
