EdZModerator
Professor EdZ
Reged: 02/15/02
Leupold Yosemite 6x30
      #2489452 - 06/29/08 10:20 AM
I picked up a pair of these because they have an extreme narrow IPD setting. That's something I always need for students. I usually have one or two that need very close IPD binoculars and most 8x40s/10x50s don't get close enough for a young 10 year old with eyes only 52-54mm apart. The measured IPD of the 6x30 Yosemite is 49mm to 71mm. That reaches the narrowest of any binocular I've ever seen. Of those I've tested, I can count only 5 binoculars that have IPD closer than 55mm, and only 1 closer than 53mm.
First impression - very nice.
Some of these measurements will confirm those I've read posted here and elsewhere by Henry Link and Patrick (Swedpat).
Center focus, porro prism design.
Exit pupil and Loupe test both confirm effective aperture is a bit small. I measured 28mm. I wouldn't disagree that it might be 27mm.
On axis resolution is very good, I measured a definite at 13.64 arcseconds and suspected 12.12. That's an apparent resolution of 82 arcseconds, suspected 73. Generally, I would list that in my file as avg 78 arcseconds. That places this little binocular among the best measured. With only few can I see below 80 arcseconds.
Resolution does fall off fairly quickly. By 50% out from center it has deteriorated. By 75%-80% out it is rather poor.
Most of the off-axis aberration seems to be curvature. While not so good for astronomy, this actually facilitates a better deep field view for terrestrial use. I noted while center was focused at 125 feet, about 50% out was very clear resolution at near 70-80 feet and 90% out showed clear resolution at about 50-60 feet. So this little binocular has a very broad near image depth of field across the fov.
Coatings appear to be very good. Exit pupils are perfectly round and centered.
FOV stated as 8.0°. I measured it at 8.1°
Point alignment merged perfectly. FOV overlap at close focus is 83% of total FOV. FOV overlap at 125 feet only off by 2 inches, nearly perfect, less than 5 arcminutes.
Light beam tested with laser is very well balanced. Laser also shows effective aperture is 28mm.
Several measures of exit pupil show 4.8mm to 4.85mm. With an effective aperture measured at 28mm, these values would give magnification of about 5.8x.
Close focus exit pupil was measured at 4.7mm, giving a magnification of just about 6x at close focus.
Mine measures a close focus of 13 feet (4 meters).
It has long eye relief easily accomodating my eye glasses. I measured total er at 18-19mm and with eyecups in it has 14-15mm usable.
I did not notice any stray internal reflections. Views of tree tops pointed as near as a dared get towards the direction of the Sun showed no stray color and no stray reflections on the insides of the barrels.
It's waterproof, and weighs only 17 ounces (480g.) on my kitchen scale.
I did notice a short flat spot when changing focus from in to out. Other than that focus was very positive and did not slip.
Right eye diopter was quite stiff, but was easier to get a grip when the eyecups were extended. IPD axle was not overly loose, but every time I tried to change the right diopter it moved the IPD axle. Minor annoyance.
Overall, I'm impressed with the build quality. The eyepiece bridge has NO rocking movement at all. Compared to all other $60-$100 porros that I've tested, this one has far better build quality and better mechanical function.
Of all those I've tested, I can't think of a better binocular to recommend for young children.
This 6x30 Yosemite cost me $90 shipped from Eagle Optics. It comes with a limited lifetime warranty.
edz
Wes James
Reged: 04/12/06
Re: Leupold Yosemite 6x30 new [Re: EdZ]
      #2489639 - 06/29/08 12:28 PM
Great review, EdZ- and I think it would be an excellent bino for a lot of people who query about a suitable bino for younger children; seems like there's been a few queries lately about that issue, so a very timely review.
Wes
ngc6475
Fearless Spectator
Reged: 03/02/02
Loc: Northern Sierra Foothills
Re: Leupold Yosemite 6x30 new [Re: Wes James]
      #2489664 - 06/29/08 12:42 PM
Thanks for the report, Ed! Steve (mooreorless) has been enthusiastic about the quality of his Leupold Yosemite binocular and it has gotten quite a bit of positive attention on BirdForum, too. It sounds like you get is a lot of bang for your buck with this binocular.
Walter
"Always do right. This will gratify some people and astonish the rest."
-Mark Twain
Swedpat
Reged: 02/18/05
Loc: Boden, Sweden, Scandinavia
Re: Leupold Yosemite 6x30 new [Re: ngc6475]
      #2489914 - 06/29/08 03:37 PM
Thanks Ed for your review, which is more technically based than what I have been able to write about them.
I can see that I was close in my attempt to measure the effective aperture, I estimated 26-27mm by using a transparent mm-ruler.
Also you confirm my experience of a very sharp image on-axis, but quite soon softening of towards the edges.
When I compared the Yosemite 6x30 to the Swarovski SLCnew 7x42 I noticed that the Yosemite 6x30 has slightly larger TFOV than the 7x42, though both are stated the same 8deg. 8deg may be correct number for the SLC 7x42.
I have earlier somewhere claimed that the Yosemite 6x30 likely is the best ever produced binocular in it's size and price range. I wouldn't be surprised if you agree.
Regards, Patric
*2,3x40 Constellation View Wide-Bino
*Leica Ultravid 8x20 BR
*Leupold 6x30 Yosemite
*Leupold Katmai 6x32
*Swarovski SLCNew 7x42B
*Bresser (Lidl) 10x50
*Oberwerk 11x70
*No name (Kunming) 15x70
*Scopos ED APO 66
*Celestron Accessory kit, Vixen LV 20,10,5mm
Psalm 19:2
EdZModerator
Professor EdZ
Reged: 02/15/02
Re: Leupold Yosemite 6x30 new [Re: Swedpat]
      #2490008 - 06/29/08 04:31 PM
Hi Patric,
Among others, I had read your's and Henry's reviews on Birdforum (where I did read what you stated again here. It is the only binocular of this size that I have, (other than the 6.5x21 Papilio, which is quite different), so I have no others to compare too, but I'm very happy to own this one. The build quality is similar to others quite a bit more expensive. None of the similar cost Chinese binoculars match the build quality of this one.
edz
Teach a kid something today. The feeling you'll get is one of life's greatest rewards.
member#21
mooreorless
Reged: 07/05/05
Loc: Cornpropst Mills,Huntingdon,Pa
      #2490145 - 06/29/08 05:29 PM
When I compared tested resolution in the Leupold 6x30 Yosemite to Brock's Fujinon 6x30 FMTR-SX centerfield was very close, where the Fuji pulled away was the edges of course.:-) I actually bought two of these Leupold 6x30 Yosemite binoculars. The first one I bought my Brother-in-Law took a long look through it and tried to trade me a Pentax reverse porro for it. I know the small Pentax cost more than the Yosemite, but I really didn't want the the Pentax. I sold it to him and posted on BirdForum saying I wish I didn't sell it. A nice fellow on there offered me his 6x30 Yosemite for about half price, this one was just as good if not better than the first one.
Regards,Steve M
"the eights are better" Jim Carmichel of Outdoor Life magazine
Rick
Reged: 04/12/05
Loc: Tokyo, Japan
Re: Leupold Yosemite 6x30 new [Re: mooreorless]
      #2490227 - 06/29/08 06:06 PM
Ed, can you inlcude some pics of the binocular? These "American" brands are generally not sold here, but chances are it might be available under a different name. Oh, and an appoximate price too?
thx,
Rick
www.japanastro.com
KennyJ
Reged: 04/27/03
Loc: Lancashire UK
      #2490231 - 06/29/08 06:08 PM
About a couple of years ago , a CN member I hold in the very highest esteem bought about TWENTY of these Yosemites for under privileged youngsters to use .
As I expected , given his enviable knowledge of the instruments , the member did notice a few minor technical faults with every one of them , but still felt he could have done no better for the intended purpose than choose this particular model , even though I think he may have actually had two or three of the pairs replaced .
I was pleased for him , and of course for the fortunate recipients of these fine little binoculars .
It is typical of the man that the very last thing he would want anyone else here to know , is of his incredible generosity .
An interesting and useful addition to your recently dwindled collection , Ed !
I hope you find the odd occasion to take another look through them yourself ! :-)
Kind Regards
Kenny
Two eyes and a preference to use both
Zeiss 7 x 42 BGAT
Captain's Helmsman 7 x 50
Nikon 10 x 42 Superior E
Swift Audubon Kestrel 10 x 50
Helios 15 x 70 Observation
Strathspey 20 x 90
Televue 76 APO
Zeiss 85 Diascope
Helios 102 f5 refractor
Swedpat
Reged: 02/18/05
Re: Leupold Yosemite 6x30 new [Re: Rick]
      #2490267 - 06/29/08 06:20 PM
thx,
Rick
Rick,
I have some pictures in my gallery:
http://www.cloudynights.com/photopost/showphoto.php?photo=14333&password=&sort=7&thecat=528
http://www.cloudynights.com/photopost/showphoto.php?photo=14334&password=&sort=7&thecat=528
http://www.cloudynights.com/photopost/showphoto.php?photo=14332&password=&sort=7&thecat=528
Regards, Patric
*Oberwerk 11x70
*Scopos ED APO 66
Psalm 19:2
10 registered and 22 anonymous users are browsing this forum.
Moderator:  EdZ
Home
