HandyAndy
Reged: 01/11/08
Loc: West Midlands and around
The 'Best' telescope and eyepieces
      #2491862 - 06/30/08 03:47 PM
After setting 'Best Planetary Refractor' 'Off-track' it seems to me that KISS is best.
Which means the fewest optical components? If we count a lens or corrector plate as equivalent to a good mirror with Dielectric coating:
Newtonian @ F8
Maksutov Newtonian @ F8
Doublet Refractor and Star Diagonal @ F15
Triplet Refractor and Star Diagonal @ F9
Maksutov and Star Diagonal @ F15
And of course of sufficient focal length to not need any further correction of the output focal surface.
Perhaps we should expect to pay more for some types of telescope to get the potential quality out of them?
Cheers. Andrew.
10mm F2
Monarch 8x42
Zeiss 10x50 WA
Pentax 60mm
V 5" F9.45+1.6x & I 8" VISAC > (14" F4.2 Vixen CC)
(V Revelation 20x100)& I 6" F5 MPCC
V 7" MN78+1.6x & I 10" F6.3 PC Fullerscopes MK4
V 16" F5 Dobo ParaCorr (Solid to Truss)
V -
55mm Televue Plossl
B&L 32 Plossl
Clave's 25, 8, 6, 2x
Nagler 9+1.25"0.5x, Meade 14 4000 UWA+0.5x
I & V -
Hyperions 5, 8, 13, 17, 24, 31, 31+2"0.7x
UO Pretoria 28mm
Don WModerator
Reged: 05/19/03
Loc: Wisconsin, USA
Re: The 'Best' telescope and eyepieces new [Re: HandyAndy]
      #2491892 - 06/30/08 04:02 PM
I seem to have missed your point. Is there one?
Don Wyman
Obsession 18" f/4.5 #1166
W/Argo Navis DSC and Torus Primary
William Optics Megrez 90
Coronado PST
HandyAndy
Reged: 01/11/08
Re: The 'Best' telescope and eyepieces new [Re: Don W]
      #2491923 - 06/30/08 04:26 PM
Perhaps there is a lack of good quality Newtonians.
10mm F2
Monarch 8x42
Zeiss 10x50 WA
Pentax 60mm
V -
55mm Televue Plossl
B&L 32 Plossl
I & V -
UO Pretoria 28mm
Biff
Reged: 09/04/05
Loc: Courtice, Ontario
      #2492354 - 06/30/08 08:29 PM
There is?
My chinese 8" has beaten up on a few refractors easily costing more. Apperture can make up for a lot of evils and no CA is nice too.
Ryan
Antares 200mm f/6 Dob & 130mm f/5 Travel Dob.
Projects on the go...
- a couple 80mm SS refractors on the back burner.
- a few small mirrors awaiting polishing
- 260mm f/7.15 mirror... still polishing
Member of DRAA
My house.
DRAACO
HiggsBoson
Reged: 02/21/07
Loc: Kal-li-fornia
Re: The 'Best' telescope and eyepieces new [Re: Biff]
      #2492756 - 07/01/08 12:54 AM
By your criteria there the Newtonian would win easily as it contains only 2 optical components.
Michael
ATM: 6" F/9 Newtonian Travel Scope
ATM: 12.5" F/4.5 Real Soon Now...
Houdini
Reged: 07/13/07
Loc: Europe
Re: The 'Best' telescope and eyepieces new [Re: HiggsBoson]
      #2492997 - 07/01/08 07:31 AM
Combined with a Huygens eyepiece.
Robert
16" f/4.9 motorized alt-az, 25" f/5 Dobson, 43" f/4 alt-az in construction
Mirror Edge Support Calculator
mark cowan
Vendor (Obsidian Optics)
Reged: 06/03/05
Loc: salem, OR
      #2494636 - 07/02/08 01:32 AM
But you left out the Herschelian. You can get down to 3 surfaces total if you use what I think is called a "Tolles" design, single piece of glass...
Best,
Mark
nytecam
Reged: 08/20/05
Loc: London UK
      #2494660 - 07/02/08 02:23 AM
How does this thread satify ATM What are you making
Nytecam 51N 0.1W
Meade 30cm LX200+ETX-70+DS-2090+C8+Ha+CaK PSTs SBIG SGS+homebuilt spectrographs
Starlight SXVF_M9/Lodestar/Canon 300D DSLR/Fuji E550
My observatory build-ETX-70 imaging-spectro page
HandyAndy
Reged: 01/11/08
      #2494738 - 07/02/08 05:21 AM
Thanks for being 'On track'.
Cheers. Andrew.
10mm F2
Monarch 8x42
Zeiss 10x50 WA
Pentax 60mm
V -
55mm Televue Plossl
B&L 32 Plossl
I & V -
UO Pretoria 28mm
HandyAndy
Reged: 01/11/08
Re: The 'Best' telescope and eyepieces new [Re: mark cowan]
      #2494741 - 07/02/08 05:23 AM
I did think about the Hershelian but it needs to be quiet large and of long focal length not to need a corrector for off-axis observing.
Cheers. Andrew.
10mm F2
Monarch 8x42
Zeiss 10x50 WA
Pentax 60mm
V -
55mm Televue Plossl
B&L 32 Plossl
I & V -
UO Pretoria 28mm
HandyAndy
Reged: 01/11/08
Re: The 'Best' telescope and eyepieces new [Re: nytecam]
      #2494742 - 07/02/08 05:29 AM
This seemed the best general thread. You get moaned at if you do a cross telescope type post in a specific thread.
Perhaps there needs to be a 'comparison' thread.
Perhaps you need to build your own Newtonian to get a 'A10' MN and refractor killer?
Do you know of a supplier who can produce a 8" F8 mirror and 2" flat to a real 1/16th wave and get them dielectric coated? And how much would they cost.
Also any old mirror maker whos mirrors can be relied upon in the SH market.
In the UK Jim Hysom, David Hinds, John Nichol and David Sinden seem to be consistent.
Cheers. Andrew.
10mm F2
Monarch 8x42
Zeiss 10x50 WA
Pentax 60mm
V -
55mm Televue Plossl
B&L 32 Plossl
I & V -
UO Pretoria 28mm
HandyAndy
Reged: 01/11/08
Re: The 'Best' telescope and eyepieces new [Re: Houdini]
      #2494743 - 07/02/08 05:30 AM
I forgot the eyepiece bit.
I think at least a RKE is needed or maybe a good Plossl or Orthoscopic.
Cheers. Andrew.
10mm F2
Monarch 8x42
Zeiss 10x50 WA
Pentax 60mm
V -
55mm Televue Plossl
B&L 32 Plossl
I & V -
UO Pretoria 28mm
DAVIDG
Reged: 12/02/04
Loc: Hockessin, De
      #2494906 - 07/02/08 09:38 AM
If you want the "best" telescope, it should be unobstructed for the highest possible contrast. Have a f-ratio of 8 or greater, so it does cause problems with the choice of an eyepieces. Have the least amount of surfaces. Have surfaces that are spherical for easy testing to achieve a perfect null. Be diffraction limited over 1/4 degree of view and have flat or nearly flat focal plane.
Given the above one should consider a Schiefspiegler, since the two mirror design can use two mirrors of equal radius and spherical surfaces. Just a bit more difficult to make then a standard newtonian, since the tool for the mirror becomes the secondary. In my opinion it's easier since all the surfaces are spherical and you can easily test for a null. Plus it is unobstructed system which is critical for the achieving the highest contrast.
Then there is a Schupmann medial refractor which is made from two pieces of the inexpensive BK-7 crown glass, and is perfectly color corrected, much better then a APO. It also has a version with all spherical surfaces. Has very close to a perfect MTF curve for ultra high contrast. It can be diffraction limited for all colors over 1/2 degree field of view and of course is unobstructed.
- Dave
Homemade 'scopes 8"f/7,6" f/5", 6"f/4, 4.25" Schief. 60mm Coronagraph,60mm H-alpha system, 4.25" White-light Solar Newtonian,solar spectroscope, 4.5" f/16 Schupmann Medial refractor, 14 Stellafane awards 7 in optics
Engineering = Taking what you have and making what you need.
Chriske
Kijkerbouw Urania
Reged: 08/15/04
Loc: Boechout, Belgium
Re: The 'Best' telescope and eyepieces new [Re: DAVIDG]
      #2494928 - 07/02/08 09:50 AM
I'd say the same, schiefs are *very* good, build a few of them myself. Schupmann on the other hand, did not build one...yet. But I trust Dave on that one as he won a few awards with his Schupmann-scopes in the past...
Chris
mark cowan
Reged: 06/03/05
Loc: salem, OR
      #2496768 - 07/03/08 01:03 AM
You're maybe thinking of the way it's often depicted, a normal paraboloid (or even long FL sphere) tilted. To make it properly it should be an off-center paraboloidal section and then it makes into a nice instrument, albeit a flat helps to fold it back to where the viewer is. Gary Fiskhorn made one of these, you can find it in WillBell's The Best of Amateur Telescope Making Journal Volume (or in the magazine if you have it.)
So add one more surface, that's 4 total with the Tolles EP. (I don't know if it would actually work for the Herschelian though!!!)
Best,
Mark
mark cowan
Reged: 06/03/05
Loc: salem, OR
      #2496776 - 07/03/08 01:16 AM Attachment (9 downloads)
Perhaps there needs to be a 'comparison' thread....Perhaps we should expect to pay more for some types of telescope to get the potential quality out of them?
Out of morbid curiosity I hunted down the thread you're referring to...where it starts to say No one makes a "Premium" 6" Newt. Ah, yes. No one makes one, so you can't buy one, but since no one can buy them, it appears there's no market for one...which means no one will make one. Aside from making your own (which the refractor crowd almost never does) then there's no option to compete, nothing with fine tooled mechanicals to drool over, nothing with SOTA reflective optics in a minimal optical configuration that does that one planetary thing so well (and those who make their own planetary 'scopes know what I'm talking about). It's hard to say if this is a chicken-and-egg problem. The small slow newt market went away a long time ago. But if people are really interested in them it surely could come back...
For small mirrors (6-8") the production techniques differ, but that's not really a problem. What is a problem is that small mirrors never command much price in the market, and the time it takes to make them is similar to what it takes to make much larger optics, for which the price is higher. And you'd have to fight uphill all the way against the vast glut of off-shore entry-level optics, which realistically is the de facto standard of comparison at this time. Dismal prospect, that.
OTOH complete systems might find a small but ready market. Especially if they were, oh I don't know, Roddier tested to verify overall quality...
To answer a couple of the unexpressed issues and maybe a couple suggestions: You may (?) be looking for a large enough illuminated field for widefield Naglers in a longish FL 8". Your 2" secondary suggestion is overkill then, what you need is a minimal distance from the OTA center to the focal plane, not a big honking secondary for visual use. A sled focuser would accomplish all this and have the benefit of allowing various accessories to be plonked into the light path without calling for excessive focuser travel. An 8" f/8 can have no more than about a 1.5 degree true FOV (by my crude BOTE calculation) if it's feeding a 42mm diameter focal plane (the maximum entrance pupil for a 2" EP). For planetary alone this makes no difference, but the point is that full (100%) illumination of that 42mm focal plane, when it's located 5" from the optical axis, occurs with a minor axis secondary of 1.42", which leaves your 8" f/8 working at a secondary obstruction of less than 18%. This system will equal or beat any 6.5" unobstructed (be it APO dripping with exotic glasses, or unobstructed mirror design, or some combination thereof) in contrast transfer of planetary detail, though it will give up some ground on off-center abberations for highly corrected designs. OTOH it will have no spurious color and the center of the field will have zero aberrations.
Perhaps somebody could check the calculations (though they seem in the ballpark to me)?
OK I checked the calculations as something didn't sound right - brain malfunction! According to TeleVue the max field stop for a 2" is 46mm (not 42mm) and for a 1.25" it's 27mm. Reworking the above correctly I get a diagonal minor axis of 1.96" to FULLY illuminate a 2" EP, and a minor axis of 1.15" to do the same for a 1.25" EP. 1.96" (or 2") is thus correct for the stated application, if that's what wanted, and the obstruction would be 25% which is fairly high. For the 1.25" the obstruction would be (using an available 1.3" instead) 16%, quite reasonable. Running SEC I get the following illumination graphs. They don't agree with my calculation and since I've never actually used the program beyond looking at it I'll just have to leave that for others.
Sure (PM me if you're really interested). But the dielectric on the primary would not be wise, as the stress is quite high - to ensure the maintenance of the figure the primary would be much thicker than would be ideal. A high-quality enhanced coating won't stress the primary and will work quite well.
Best,
Mark
ps Edits in blue
Edited by mark cowan (07/03/08 08:07 PM)
mark cowan
Reged: 06/03/05
Loc: salem, OR
      #2496783 - 07/03/08 01:30 AM
On my short-list, too. Can be made from refractive quartz if available (as it is now ).
Best,
Mark
jpcannavo
Reged: 02/21/05
Loc: Long Island New York
      #2496947 - 07/03/08 07:36 AM
Best,
Mark
Mark
That is the first explanation along such lines as to why dielectrics are not used on primaries...I have always wondered about this, and have never been entirely satisfied with the "if you make a mistake they are to hard to strip off" explanation, although this is probably true as well.
Also glad to hear you affirm the qualities of the on-axis performance of the paraboloid. I always wonder why certain implicit notions to the contrary don't go unchallenged.
Consider this one: It needs to be a Mak-newt to compete (on-axis) with an apo.
Why should this be so?
1) For a given focal ratio/field illumination the central obstruction is the same.
2) Yes, spherical surfaces are easier to make – but equally good aspheres are being made
by the likes of a couple of guys named Mark, and a few others.
3) Sure, there are no “visible” diffraction spikes – but this is a non-MTF-altering cosmetic issue.
4) And getting back to the spirit of this thread – two more optical surfaces, and a closed tube to boot.
Now none of this is to suggest that MNs are not outstanding planetary scopes – they are. But they should be no better on-axis than a simple newt of equal aperture/f-ratio, and equal wavefront error.
And then there are those Tak Mewlons – don’t get me started...
Joe
Joseph Cannavo
16" F5 Zambuto - Front collimating mirror cell nearly complete!
10" F5 Dob
Mid 70's RV-6
4" Orion 100mm ED
Mr Keeyoots (My Cat)
Fiske
Reged: 03/14/04
Loc: Missouri / United States
      #2496949 - 07/03/08 07:37 AM
Mark:
It would have been lovely to have your participation a week or so back on the "Aperture Rules" thread over in refractors. A bunch of APO fanciers claiming a 6-inch APO will outperform any reasonably sized reflector... In fact, touting their resolution advantage over 20-inch reflectors. I realize rational arguments make no difference under such circumstances. It still would have been fun.
Fiske Miles
Nikon 8x42 LX / 12x50 SE Binos
Mini Borg 60ED, TV-101, AT80Ach, XT-8, C11/CI-700, 22-Inch Dob
Way too many Nagler eyepieces
http://www.fiskemiles.blogspot.com/
www.fiskemiles.com
Chriske
Kijkerbouw Urania
Reged: 08/15/04
Re: The 'Best' telescope and eyepieces new [Re: Fiske]
      #2496975 - 07/03/08 08:02 AM
Hi Fiske,
J. Daley wrote a book on Schupmann telescopes. As I understand it (I did not read the book from A to Z and did not build one myself yet) Schupmann scopes are by far the best concerning color correction outperforming any Apo.
I think this scope is a winner.
Chris
5 registered and 14 anonymous users are browsing this forum.
Moderator:  Don W, Joe Cipriano
Home
