Privacy Policy |
Please read our Terms
of Service | Signup and
bigdob24
Reged: 04/19/08
Loc: Central Illinois
I'm at the Heart Of America Star Party with my new MC, having a great time. Getting allot of the WOW factor. Also may have done my part in at least 2 sale coming up in the future:-) Looking at all the best objects, M 57, 51, 82,16 Trifid, Swan, several galaxy clusters. Have had very good results except with objects like the cats eye, the veil nebula with 52 Cyg. Seems bright objects seem to burn out and over expose. I have all the settings like the examples recommend. I have adjusted the gain with no results. I'm just using 7 , and 14 sec exposures, with a 24" StarMaster scope. Any ideas and recommendations would be helpful on this type object , I know its just something I'm overlooking;-) We will be here 2 more nights so if the skies permit I can give it another try. Thanks Dan
greg
Reged: 01/25/05
Loc: Central Ca.
You might try the Gamma setting.
Greg
-------------------- 30" F/4.5 Truss
12" LX200 GPS
Orion ST120mm F/5
Celestron 102mm F/5 Finderscope
2" 26mm 70* Illuminated Reticle
26mm T5 Nagler
20mm T5 Nagler
13mm ETHOS
Pentax XW 10mm
MallinCam Color Hyper Plus
9" Speco HighRes. Color CRT Monitor
Light polluted Backyard
10' Home Dome
MallinCam Deep Space Observatory
Great Darksite 1.5 Hrs. Away
Jack Huerkamp
Vendor - Waning Moon
Reged: 10/13/05
Loc: Louisiana
For brighter objects, you can lower the AGC (gain) to keep from over-exposing them. Conversely, for dim objects, increase the AGC.
For objects like the Cat's Eye, eliminate the focal reducer to increase the power. This will also reduce the burning in of the center of the planetary. This also will work well on the Ring.
Jack
-------------------- Orion ED80
Coulter CT-100
Celestron 6" f/8 Refractor
8" Newtonian/Cassegrain on Byers 812 Mount
Classic C-8
Celestron 11" CPC 100 with HyperStar
Tricked-out 17.5" AstroSystems TeleKit
Life Member and ALCOR - PAS New Orleans
Waning Moon II Observatory
bigdob24
Reged: 04/19/08
Thanks for the suggestions. I did experiment with the gamma setting with no luck. Also went through all the settings on the AGC, tonight I will try removing the focal reducer, looks like 2 more good nights :-) Also how do you use the ( freeze image ) setting in the options menu?? Thanks Dan
Moderator: Chris Schroeder
