Anonymous
Unregistered
Do you have a tip for Questar users? Some simple piece of advice that will make using the scope easier? Post it here!
Anonymous
Unregistered
Even a small scope like the Questar can take a while to cool down (or warm up) to outdoor temperature. If there is a significant temperature difference, allow an hour for the scope to adjust before you start serious observing. You can speed cooling a bit by removing the eyepiece and aiming the scope slightly downward. Also remove the star chart/dew shield, replacing it when you are ready to start observing.
Anonymous
Unregistered
The next time you look into the eyepiece at a telescope, try centering your eye and look directly in. You may find that the eyepiece has a "sweet spot" where the image suddenly becomes very sharp. This spot may be very small, but it's worth finding. Otherwise, you are not getting all the performance your scope is delivering.
Anonymous
Unregistered
Buy the Questar Astro Pier. Rock solid, beautiful workmanship and well worth the price.
Rat8bug
Reged: 01/07/05
Loc: Michigan
http://www.barrie-tao.com/questar_life.html
Ciao....Barry
-------------------- Nikon D40/D50/D70 DSLR
WO 105mm Triplet APO
WO Zenithstar 66SD APO (Black 'n Blue)
WO 8 x 45mm APO Bino
UO 20 x 80mm Bino
Vixen 80SS Refractor
Orion 127mm Apex Maksutov
Vixen GP-DX with Skysensor 2000
SBIG STV and e-finder
RRavneberg
Reged: 12/02/05
Loc: Columbus, OH
Ever have trouble reading the declination circle at night with all those reflections and lines going every which way?
I simply placed a small piece of tape over the index and it's much easier to read.
-------------------- Ron Ravneberg
Anonymous
Unregistered
I had Questar mod my Standard so that the RA/azimuth knob is "in back" rather than in front. The advantage is that I am less likely to block the finder when turning the knob. The disadvantage is that there is less clearance for any accessory attached to the axial port.
Antares
Reged: 03/20/04
Loc: Chicago area
If you would prefer your Questar's R.A. knob to be on the near end of the base rather than the far end (or vice-versa), you can easily do it yourself. Here is the procedure that has been posted elsewhere but bears repeating:
1. Remove the eyepiece. 2. Make sure the focus knob isn't backed out too far. 3. Move the diopter adjuster (i.e. the finder focus ring) counterclockwise so that it clears certain protuberances on the base of the main tube when you perform Step 4. 4. Rotate the main tube about its long axis so the eyepiece tube points down when the main tube is horizontal. 5. Swing the main tube (in elevation, that is) so that the control box passes down between the fork arms and emerges on the other side.
Voila; the RA knob has switched ends.
-------------------- Questar 3.5"
10" f/4.5 Newtonian reflector
Coronado MaxScope 40 (double stacked)
4.25" f/10.5 Edmunds-style Newtonian reflector
Tasco 60mm refractor
Twin variable aperture organic imaging devices
dholko
newbie
Reged: 05/20/08
Loc: PSL,Florida
Post deleted by dholko
dholko
newbie
Reged: 05/20/08
Loc: PSL,Florida
OK, let me try that again.
The Meade deluxe field tripod, slightly modified with a hole saw, makes a excellent tripod for the Questar. It is solid enough and light weight enough to carry anywhere with easy latitude adjustment. Tall enough for a standing position or short enough for sitting next to when observing for long periods.
1 registered and 0 anonymous users are browsing this forum.
Moderator: spaceydee, Clive Gibbons
