Observing >> Deep Sky Observing
GlennLeDrew
Reged: 06/18/08
Loc: Ottawa, Ontario, Canada
IC4592, a HUGE reflection neb in Scorpius, seen!
      #2492311 - 06/30/08 07:53 PM
Here's an object I never expected to ever see visually, as I'd assumed it was a photographic target only. Last year, for some strange reason, I decided to try for it anyway, using a friend's home-brewed 20X100 binocular. This bino uses the objectives from a 22X100 Oberwerk-like bino (but with the Antares brand emblazoned upon) and the body/eyepieces from a Tasco model 124 7X50 having 80 degree AFoV eyepieces. (The original, weak focal reducer lenses, which increased the field of view, were removed.) The TFoV is about 3.5 degrees.
The transparency was a bit better than moderately good, with my SQM reporting 21.2-21.3 mag/arcsec^2.
After studying all the nearby OB associations over the past few years, I was already intimately familiar with the nebulous clouds in Sco OB2, a.k.a. the Upper Scorpius sub-group of the huge Sco-Cen OB association. Sco 2 contains virtually all the luminaries which comprise the Scorpion's Claws and Heart, as well as the rho Oph dust complex and star-forming region.
IC4592 is a *huge* reflection nebula, and of those visible to human eyes, only the Witch Head is of similar size. The illuminating star is nu Sco, located at the north edge of the Claws. The nebula's surface brightness is highest in the vicinity of nu, and along its southwest edge, where the brightness drops off precipitously. Toward the northeast, the brightness falls more gradually. The nebula is elongated in the northwest-southeast direction, and the maximum length is about 3 degrees (!).
In spite of the fairly low maximum elevation of 25 degrees as seen from latitude 45N, I was shocked to see about 1.5 degrees of the nebula's length! But it was not what I'd call an easy observation, by any stretch. I tried to glimpse it in a 10" dob with a 30mm eyepiece, but to no avail. In those conditions it was definitely a binocular object only, meaning both eyes were necessary to differentiate the feeble signal from the sky glow.
Because of this object's large size, it doesn't require more than low power to magnify it to well past the point of detection, even given its very low contrast. Moreover, it has a better chance to be glimpsed when framed by a reasonably generous expanse of surrounding sky. Big 'scopes may fail to reveal anything because the nebula will fill or even spill beyond the available field. Or if anything is seen, perhaps only the "sharp" transition along the SW edge near nu will stand out.
Of course, for those fortunates who live well south of my latitude, a higher elevation should make spotting this cloud even easier if the sky is nice and dark.
Finally, after catching IC4592, I naturally had to see if nearby IC4601 would reveal itself. In spite of the triplet of stars enmeshed within, it was actually a little easier.
Needless to say, I'm anxious to see what the view of this part of the sky will be like when one of those all-too-rare superb nights happens, when the troposphere is clear and dry, and the airglow intensity is low.
Here's a neat, annotated picture of the region. Roll your mouse over the image to see labels. Note that north is to the right.
Home-made 11X50 right angle bino, 8.1 deg. FOV
Modified 26X100 bino, 3.5 deg. FOV
Mediocre minds discuss people. Good minds discuss events. Great minds discuss ideas.
stevek
Reged: 04/16/06
Loc: west michigan
Re: IC4592, a HUGE reflection neb in Scorpius, see new [Re: GlennLeDrew]
      #2492558 - 06/30/08 10:38 PM
Good post!
Steve
DSO 8" f6 DOB w/ 8x50 RACI & 2"Crayford
1958 Sears Discoverer 76mm Refractor
GSO SV 30mm 2",21mm Hyp,13mm Strat,BO/TMB ver2-6mm & 4mm
1.25"Filters: DGM-NPB, 25%ND
1.25" plossls: 25mm,20mm,15mm,9mm
Orion 2X Shorty Barlow
Garrett Gemini LW 11x56mm binocs
BTG-10 4.0mW green laser pointer
"What is that burning in the sky? Tell me y'all..." Jeff Beck/Jan Hammer
tatarjj
Reged: 04/20/04
Loc: Auburn, AL
Re: IC4592, a HUGE reflection neb in Scorpius, see new [Re: stevek]
      #2493135 - 07/01/08 09:45 AM
I'll echo Steve: Great post!
More importantly, great observation! I've seen those reflection nebulae on my star charts before, but I had thought, like you, that these particular objects, being reflection nebulae that can't have filters used effectively on them, would probably near impossible to observe visually. You make me want to get a big pair of binos!
I would argue that most likely, the reason your bigger scope failed to reveal it was, as you mentioned, you were using TWO eyes in the binos, with that purported 40% gain in contrast. I'd think that a 16" binocular scope would work as well, if not better. While you cannot frame the entire object at once with the background sky with a bigger scope(s), you CAN sweep back and forth across it rapidly and detect the change in sky brightness. That said, I've never extensively tested the rapid sweep technique directly against a smaller scope that can just barely frame an entire low surface brightness object along with background sky. I must say, however, that my 18" scope did reveal the very huge Sh2-216 (1.5 deg diameter PN) and Sh2-264 (Meissa nebulosity) better than my 4" refractor, but not by a huge amount.
John T.
Auburn, AL
25" f/4.2 Dob
18" Obsession #701
4" Stellar Vue Achromat
8X56 Binos
GlennLeDrew
Reged: 06/18/08
Re: IC4592, a HUGE reflection neb in Scorpius, see new [Re: tatarjj]
      #2505005 - 07/07/08 08:37 PM
UPDATE:
This past Thursday, July 3/4 was beautifully clear. SQM reading: 21.3 mag/arcsec^2; nelm 6.4.
Using my home-made 11x50's (no filters), I could see both IC4592 and IC4601, though quite faintly. IC4603, just south of rho Oph, was *easy*. Within the large Sh2-29 nebula complex just east of M8 (all of which lies within the larger Sgr OB1 association), the small emission/reflection nebula NGC6559 was relatively easy to see.
Higher up in the sky, the two brighter patches of the IC1318 nebula complex, those northwest of gamma Cyg, were astoundingly obvious.
Cruising the massively sprawling Prancing Horse dark nebula complex engaged me for the better part of an hour! The huge field simply pulls me in, and the detailed structure is astonishing. The contrast between the billowing haze of background stars and the inky depths of the denser clouds makes for an incredible 3-D effect.
And sweeping all along the milky way northward to Cepheus revealed seemingly countless dark clouds, some familiar, and others that I've yet to put catalog designations to (not being plotted on any atlases I know of.)
2 registered and 2 anonymous users are browsing this forum.
Moderator:  matt, Olivier Biot
Home
