Observing >> Lunar Observing
LivingNDixie
Lord of Ferrets
Reged: 04/23/03
Loc: Hoover, AL
Help with Orientale new
      #2485096 - 06/26/08 07:01 PM
Are the inner Rookes the mountains one sees against the very edge of the Moon sticking up? I am pretty sure I could make out the outer Rookes, they looked like a bright white line similar to the Appenines under high sun angles.
Just wondering, I was taking a peek this morning and the picture pretty much matched up with the S&T picture from the May issue. Maybe someone could take a peek on one of the Lunar Mapping programs
Preston
Celestron 11" Nexstar GPS XLT
Lunt LS60T/Ha 60mm f/8.33 (on order)
It’s not finishing something when your tank is empty that makes you a stronger person. It’s brushing yourself off and refacing the foe that defeated you with the same determination and willingness to fight that you had when you began your journey.
Carol L
Reged: 07/05/04
Loc: Tomahawk, WI 45N//89W
Re: Help with Orientale new [Re: LivingNDixie]
      #2485478 - 06/26/08 10:40 PM
Hi Preston, by "outer Rookes" do you mean Montes Cordillera, or do you mean the area of Montes Rook which is between Lacus Autumni and Lacus Veris?
I was out visiting Luna with the 8" SCT at about 2:30am CDT (June 26) and saw:
(in order, going towards the limb)
Montes Cordillera
Lacus Autumni
Montes Rook
Lacus Veris
and very good glimpses of Crater Kopff which is right on the rim of Mare Orientale.
*Step-by-Step Lunar Sketching*
CN Gallery
Photo Gallery
8"SCT ~ 120achro ~ 90Mak ~ 80ST ~ 11x70s ~ 22x100s
Jim Mosher
Reged: 05/22/06
Loc: Newport Beach, CA
Re: Help with Orientale new [Re: Carol L]
      #2486478 - 06/27/08 02:06 PM
Carol -
I think Preston is referring to the May 2008 column "Hide-and-Seek Basin" by Charles Wood, which is illustrated (on p. 64) by LPOD photos of Mare Orientale from George Tarsoudis and Paolo Lazzarotti. On those, the "Outer Rook" Mountains are labeled as you indicate -- between Lacus Autumni and Lacus Veris -- while the "Inner Rook" Mountains are labeled on the limb. The IAU name Montes Rook has a long and complicated history, and it was even dropped for a few years. It was reinstated in 1964 when rectified Earth-based images made it appear that Orientale had two main rings -- the name Montes Rook being assigned to the inner one. But Lunar Orbiter views soon made it apparent that there were at least two inner rings, and hence the names "Inner" and "Outer" have been in informal use for at least 30 years.
The following image (using LO-IV-187M as a background) illustrates where the limb lines would have been at the time of your June 26, 2008 observation at 07:30 UT compared to where it was at the time of Paolo's image (Jan. 1, 2005 at 02:25 UT) and also an LPOD Photo Gallery image by Howard Eskildsen in which the part taken at 11:45 UT on that same day would have almost exactly matched your view.
If Preston was looking just before sunrise he might have seen Orientale very slightly farther onto the disk than in any of these.
Although the lighting in the Lunar Orbiter view is quite different from these high Sun views, if you use the pattern of the dark mare as a guide, and the limb lines for orientation, it's possible, with a little effort, to correlate the things recorded in the Earth-based photos (where the mare are seen with extreme foreshortening) to the corresponding features in the LO view. The Inner Rook ring is actually seen from Earth in at least four places: in the foreground (where it is seen just beyond the dark ribbon of Lacus Veris), to the north where it crosses over the limb line, and then again to the south where it comes back to the limb line, and possibly in between where some of the highest mountain tops may be visible as a thin bright line on the horizon.
Judging from Howard's photo, the "bright white line similar to the Apennines under high sun angles" that Preston saw may have been the Earthward-side of the Inner Rook ring (just beyond Lacus Veris, especially bright to the left of where "Inner" is printed under "Orientale" in the LPOD mouse-overs). As the LPOD labels indicate, the ellipse of the Inner Rooks curves back around to the right becoming visible on the limb at a point a little to the right of where "Inner Rook" is printed in the sky. A bit of the Outer Rooks is also visible on the limb just to the north of these (under the "Outer Rook" LPOD mouse-over label). The Cordillera ring seems quite difficult to see under a high sun, although in Howard's photo it produces a distinct step on the limb (beyond Schlüter).
The most prominent limb peak in Paolo's LPOD image (the one to the left of the "Inner Rook" in the LPOD sky -- or by following the "Lacus Veris" arrow in Howard's image) actually seems to me to correspond to the elevated region just above Maunder in the Lunar Orbiter view shown here. This, like Kopff, is right on the edge of the Mare proper, and is well inside what I believe is generally taken to be the "Inner Rook" ring. The Inner Rooks themselves are not really visible at this point on the limb: they are well beyond the limb and hidden by foreground elevations like this.
-- Jim
Edit: reference feature identifications on LPOD image to mouse-over labels -- the titles previously used move depending on the window size
Edited by Jim Mosher (06/28/08 11:26 PM)
LivingNDixie
Lord of Ferrets
Reged: 04/23/03
Loc: Hoover, AL
Re: Help with Orientale new [Re: Jim Mosher]
      #2488083 - 06/28/08 02:13 PM
Carol,
What did the Montes Rook part look like for you? I could see a brighter white region closer to the darker mare area of Orientale proper (I don't know what else to call it). I am pretty sure I could see the area of Montes Cordilla, but I really did not see any relief to the area beacuse of the high sun angle. The view looked just like the pictures that are in Modern Moon.
I think the mountains I was seeing on the rim were actually crater Kopff, I had thought that they were the Inner Rookes....
Preston
LivingNDixie
Lord of Ferrets
Reged: 04/23/03
Loc: Hoover, AL
      #2488088 - 06/28/08 02:15 PM
Jim,
That picture by Paolo is great you posted, wish it looked that good in the scope.
Preston
Special Ed
Reged: 05/18/03
Loc: Greenbrier Co., WV 38N, 80W
      #2489808 - 06/29/08 02:19 PM
Jim,
Thanks for this informative post--the variety of links and pictures really help to identify some of these difficult to pin down features. It made me realize that I did see the Rooks in the foreground back in 2005. I couldn't see any detail and just rendered them as bright areas near the lakes in my sketch. Comparing the sketch to Paolo's image, the bright areas match.
Preston and Carol, sure glad you got a look at MO when the libration was so good--I love reading anything about it and I wasn't able to look this time.
Michael Rosolina
8" f/10 Orange Tube SCT
4.25" f/4.2 Astroscan Reflector
SVP 3.6" f/13.6 CA Reflector
40mm PST f/10
APM Germany HD 15x70 binoculars
Canon 12x36 IS II binoculars
Mark I Eyeball
My CN Gallery
LivingNDixie
Lord of Ferrets
Reged: 04/23/03
Loc: Hoover, AL
Re: Help with Orientale new [Re: Special Ed]
      #2490268 - 06/29/08 06:21 PM
So when is the next good shot at Orientale?
Preston
Carol L
Reged: 07/05/04
Re: Help with Orientale [Re: LivingNDixie]
      #2493141 - 07/01/08 09:48 AM
"The view looked just like the pictures that are in Modern Moon."
Yep, that was pretty much my impression too.
CN Gallery
Photo Gallery
2 registered and 0 anonymous users are browsing this forum.
Moderator:  desertstars
Home
