Carlos Milovic
Reged: 09/07/04
Loc: Santiago, Chile
Hi all
I'm working with a RCX, and it is frozen... the handcontroller says "downloading" but nothing else happens. Nothing works. What cab I do? Is there any "brutal" reset?
Thanks!!!
-------------------- Regards,
Carlos Milovic F.
// Astro & Photo - CMF
// http://www.astrophoto.vze.com
JAT Observatory
Space Freak
Reged: 02/20/05
Loc: Eastern PA
Try pressing 999 before it says "Initializing". You can then connect to the Autostar update software and continue the download. It is also recommended that you do a "Garbage Collect".
-------------------- -Marcus
The problem with free speech is even the stupid have a voice.
http://jatobservatory.org
12" LX200R on a Paramount ME
Reged: 07/06/07
Hi all
Thanks!!!
Were you trying to update the HC, or did this happen by itself. If the former, the 999 trick might work. Otherwise? Likely you will be callin' Meade, I'm afraid.
-------------------- Uncle Rod
Watch for Rod's New Book:
Choosing and Using the New CATs--coming soon!
Carlos Milovic
Reged: 09/07/04
Thanks for the answers.
No, we just plugged the mount (usb port) through several extensions... also there may be a problem because we had -11ºC that night. Anyway, thanks to the 999 suggestion we where able to install the firmware again and the mount was recovered. The bad news is that when we tried the usb extensions, again it entered that frozen state. After recovering the mount again (999+...), worked for a limited time very well, and then again was frozen by the same message, this time without any usb plugged at all! The funny thing, is that I tried to power off the mount, connect it to the laptop, and this time it worked flawless while the laptop was connected (no message at all). A few minutes after I unplugged it, it was frozen again.
Carlos Milovic F.
Pess
Reged: 09/12/07
Loc: Toledo, Ohio
This problem sounds like a bad connection somewhere. Since it worked flawlessly connected to the laptop, you were likely not touching or jiggling around the hand controller wire, I would look there first.
It is possible the hand controller has a sticky key as well.
Usually cold weather doesn't bother the RCX with the exception that the hand controller display stops working till it is warmed back up.
I would work on the assumption that something is making an intermittent contact somewhere and try and reproduce it by jiggling stuff.
Try getting it working and then walk away. Does the problem crop up when the scope is not being touched or does it only appear when you manipulate the handbox?
Pesse (Meade now offers a deluxe 16oz can of RCX Gremlin remover in aerosol form.) Mist
-------------------- 12" RCX400
WILLIAM OPTICS 110mm APO ZENITH STAR refractor
Custom Wyorock focuser for refractor
SBIG ST2000XM
CFW-10
Astrodon Series I LRGB
Douglas Schwan DC
Befuddled visual observer, bewildered astrophotographer, bemused tinkerer.
Purveyor of cognitive dissonance.
Todays Quote: "Never let the imagination of someone else limit you."
2 registered and 3 anonymous users are browsing this forum.
Moderator: Joad
