Privacy Policy |
Please read our Terms
of Service | Signup and
Steven Aggas
Reged: 04/15/08
Loc: Arizona
Several of my friends have commented at different times that at a similar magnification an eyepiece and barlow combo will show some Planetary's central stars much more clearly than an eyepiece by itself. I've seen this myself too a couple of years back, switching back and forth enough to say it was not atmospheric.
What makes this apparently work, does the barlow, by making an effectively longer FL system, reduce coma and therefore produce tighter star images, or what? Have others seen this?
Steven
-------------------- Mr. Wizard
Elements in Harmony I, an 8"f6 German Equatorial - Stellafane Winner,
II a 20"f4.2 Newt-Dob - Astrofest Winner,
III a 6"f3.5 Finder/Newt-Dob, and
IV a 36"f4.5 Newt-Dob - "If it's up there, it's in here."
www.DarkSkyObserving.com
David Knisely
Reged: 04/19/04
Loc: Beatrice, Nebraska
Steven
Barlows have little if any effect on coma. They do help reduce the off-axis astigmatism which some eyepieces generate when used in the steep light cones of short f/ratio instruments, but otherwise, they don't do anything for coma. On-axis, I have never really noticed much of a difference between Barlowed and unBarlowed systems as far as central stars are concerned, but I generally work at f/10, so the light cones are pretty shallow to begin with. Clear skies to you.
-------------------- David W. Knisely
Hyde Memorial Observatory
http://www.hydeobservatory.info
Steven Aggas
Reged: 04/15/08
Loc: Arizona
Thanks Dave. Two seasoned observers independantly commented this and I saw for myself with one of their scopes that it was an obvious difference in seeing the central star, the second commented over the phone just the other day so I figured I'd ask around here and see what others may have noticed.
If one has an eyepiece to reach a certain magnification I would guess they may not be likely to use a barlow, if they have one at all. I don't have one as it does not work with a Paracorr.
Anybody have any ideas on how an improvement in seeing a central star of a Planetary Neb when using a barlow/eyepiece over an eyepiece alone, given the same or similar magnification? I don't know what optics were used since they were not mine, but surely both these guys don't have the same eyepieces or same type of barlow.
Any input is appreciated.... Steven
David Knisely
Reged: 04/19/04
Well, there might be something going on with the coatings, as they tend to be more efficient when light is coming in more towards normal incidence. There also might be some light scatter issues, but other than this, I don't quite know what would cause such a difference. I will have to check on this in a couple of weeks at NSP and try some different setups to see when this kind of behavior happens. That might give some idea of what is really going on. Clear skies to you.
Fiske
Reged: 03/14/04
Loc: Missouri / United States
Steven:
I'm not sure why you say barlows won't work with a Paracorr adapter? I don't think there are any issues with combining them. I tend to use them separately because putting the two together represents a significant perpendicular stack. Adding a 2-inch Nagler on the end of that combo represents a serious collimation issue, IMHO. That's really the only reason I won't do it, honestly. I have combined them a few times just out of curiousity, and they seem to work fine together. Tele Vue even recommends a certain connection order. I don't recall if the Powermate/barlow is supposed to be inserted into the Paracorr or if it is the other way around. But the fact that Tele Vue even provides a recommended configuration suggests that they work together.
Fiske Miles
Nikon 8x42 LX / 12x50 SE Binos
Mini Borg 60ED, TV-101, AT80Ach, XT-8, C11/CI-700, 22-Inch Dob
Way too many Nagler eyepieces
http://www.fiskemiles.blogspot.com/
www.fiskemiles.com
Steven Aggas
Reged: 04/15/08
Loc: Arizona
Hi Fiske, really? I had read somewhere that the combo wouldn't work, maybe it was just with the tunable top and scratching the lens, so I never gave it a second thought about buying one (and probably bought another eyepiece because of it). Either I misread that or they've changed things... Either way, thanks for the update! Oh yea..., thanks for letting me know that there is yet another accessory to buy....
Steven
bicparker
Reged: 02/07/05
Loc: Plano, TX
Steven, Which planetary nebulae was this observed on? Some, like the Ring, have central star challenges due to the brightness of the internal nebulosity surrounding the star, making it more difficult to differentiate. I'm wondering if that has something to do with what you and your observing buddies saw.
-------------------- Bic Parker
17.5" f/5 dob
10" f/10 SCT
5" f/8 refractor
80mm f/6 refractor
66mm f/6 refractor
Plus a few others out of the rotation
Steven Aggas
Reged: 04/15/08
Loc: Arizona
The one my buddy saw, and I happen to be there and see using his scope and eyepieces/barlow, was NGC 6543, the Cat's Eye. As for the other buddy who made a similar comment just last week, I'm unsure what object he viewed.
I saw what he said to be happening, but I don't know what optics these guys were using and quite possible they could have been using a poor high power ep and a good low power ep/good barlow, idk.
There might not be anything real happening here, but since two people found it to apparently improve the cs viewing (although possibly not real) I thought I'd toss it out there for people to comment. I don't have a barlow to investigate for myself if eyepiece quality is the root cause, or what else might be happening.
It may have just been an overall improvement in viewing but was attributed to cs's because that was the object viewed at the time it was noticed, I'll ask what high power ep's these guys use.
Steven
Bill Weir
Reged: 06/01/04
Loc: Metchosin (Victoria), Canada
On the Televue site section for Paracorrs just below the chart for the Tabletop setting is explicitly states DO NOT use a barlow in the Paracorr because it might scratch the lens element.
That being said, I use my 1.25" 2.5X Powermate in my Paracorr regularly. This is when I'm busting out the high power on PNs. With the eyepieces I'm using though it is always set on the #4 setting so the bottom end of the Powermate isn't close to the lens of the Paracorr. Also, I measured before I did this to be sure the two wouldn't touch. I won't recommend this though, because I don't want to be blamed if someone else recks their Paracorr.
I'd be more wary of using a 2" Powermate/barlow because they tend to sit deeper within the Paracorr. The 1.25" adaptor adds just that little bit more separation of the two elements.
It's an interesting concept that the barlow/eyepiece combo vs eyepiece alone shows the central star better. I just might have to test this out tonight. So was this only on the tough to show central stars, or just any old central star in general? I guess I'll find out.
Bill
-------------------- 6'' Orion SkyQuest
12.5'' f/5 Custom Truss Dob
William Optics 80mm ZenithStar II ED Doublet
f/5 25" newtonian on a giant GEM, any time I want
Observing sessions grand total for 2007, 171.
So far in 2008, 87
Steven Aggas
Reged: 04/15/08
Loc: Arizona
So was this only on the tough to show central stars, or just any old central star in general? Bill
Let us know Bill....
I only use Televue Naglers (plus the 35 Pan)ep's, but both guys that commented on this apparent improvement use other designs which I have no first-hand knowledge of their performance, besides that one evening. Since Dave K. shot down the only suggestion so far for this effect being real, that the barlow has no effect on coma when it alters the light cone to a longer FL, then this effect might not be real. No other objects were viewed with ep/barlow that night that guy showed me the cs to conclude that the improvement was poor optics related v. optics manipulation related.
(Also, one should try hard not to point out flaws in another man’s optics if one wants to continue looking into said man’s optics…. (Well, there was that one time…, but that was someone putting a brand new 40mm, 1.25” barrel, 50 degree avof eyepiece in my scope when I was expecting an 80 degree afov. My friends still bring up the comments I made because the ep owner was right behind me when I looked for the first time not knowing it was really his ep. ))
David Knisely
Reged: 04/19/04
Steven
Good, that object's central star gives me a "constant" to use in some tests (and will be well-placed for NSP). I did observe NGC 6543 a couple of nights ago in my NexStar 9.25, and the central star was visible pretty much all the time, although at certain magnifications, there were "sweet spots" where it seemed to stand out somewhat more. It appears fairly well at low to moderate power due to a brightening of a tiny inner shell right around the star that seems to help it a bit. At high power, it tends to come and go with the seeing, so even slight seeing changes might lead one to see an apparent change in visibility that was not actually due to some optical combination's effect. Of course, I use *really* high power on NGC 6543 (typically from 480x to as high as 744x), as that really brings out the inner arc-like detail in the main bright shell. Clear skies to you.
Steven Aggas
Reged: 04/15/08
Loc: Arizona
Hi Dave, the combo ep/bar was exchanged several times with ep alone and the visibility followed the ep/bar every time, 'seeing' was the first thing thought of and the reason we changed back and forth a few times. It was really visible and then not visible when the optics were changed using the same magnification, though we did not view other things to judge an overall improvement not just with planetaries. I don’t recall the magnification used exactly but it was relatively moderate from my recollection of the view. This view was a few years back.
If no one has any more suggestions as to what optically may have been happening, besides poor quality high power ep, then empirical testing may show something. I appreciate those with barlows taking a look.
It’s too bad we don’t have a ray-trace guy to confirm that nothing happens in the manipulation of the light cone. I believe the guys’ scope was an f4.5 with no coma corrector. Why do I keep thinking the coma’s gotta get reduced, tighter star images, as it goes to f9 cone with a barlow? I don’t have a problem being wrong, do it all the time actually, but I’d like to see why. At that point I learn something.
Steven
Bill Weir
Reged: 06/01/04
Last night I went out to look into this. I had to work today and seeing as it really didn't get dark until midnight I was only using my f/8 6" dob. Tonight I'll do a little more with my f/5 12.5". the eyepiece setups I was comparing were;
5mm T6 Nagler (240X) vs 12 mm Speers WALER/2.5X Powermate (250X) the SW is a very sharp eyepiece and the same AFOV as the Nagler.
and
6mm Radian (200X) vs 15mm Televue Ploessl/2,5X Powermate (200X)
Due to limited aperture I only looked at two PN with the central star in mind, NGC 6826 (Cyg)Blinking and NGC 6543 (Dra)Cat's Eye.
With the Blinking (6826), as always it was a beacon with all eyepieces and combos. To be honest I couldn't see much difference in ease of detecting detail about the PN. If I really had to commit to which was best I'd say the Radian first followed closely by the 5mm T6, but really that's a coin toss. With the Radian the star appeared the brightest.
Then I looked at NGC 6543. With this PN, the single eyepiece clearly won over the combo. With the 5m T6 in moments of good seeing the central star could be detected. With the 12mm/2.5X Powermate combo there were tyimes I could tell there was a point central brightening but it was not seen as a star. The Radian vs the TV Ploessl/PM combo were a closer tie. They both showed a very strong small central brightening but nothing that I would call a star.
I then had a gander at a few other bright PNs NGC 6572, NGC 6210, and NGC 7027. On the whole I think the single eyepiece gave a slightly better veiw but it was really marginal.
It will be interesting to see how things look tonight with the faster optics. I think the results will be similar though.
Now I have one question. Do you want me to do the test with Paracorr in place or not? I guess both ways would be the best test.
Personally I think eyepiece quality was what your friends were noticing.
Bill
So far in 2008, 87
Steven Aggas
Reged: 04/15/08
Loc: Arizona
Thanks for looking Bill, I appreciate it. If you want to look with the paracorr in place, then sure, but I don't want to take up your observing time. Clear skies.
Steven
Bill Weir
Reged: 06/01/04
No big deal, as you might notice I get out lots. My backyard gives me SQM readings in the low 21s on most good nights. Getting out and observing on a whim is easy.
Bill
So far in 2008, 87
Steven Aggas
Reged: 04/15/08
Loc: Arizona
I talked to the one guy who made the comment just the other day. He was using a 9mm Nagler and a combo consisting of a 17mm generic Plossle with a 2x generic barlow. I've asked him to compare views of other objects with these two optic scenarios to see if there is a general improvement using the barlow. Hopefully this will show something. I will be flying to MI to view with these guys in early August, so I'll be able to see for myself the effects of each optic combination.
The second guy to comment this is a little tougher to get a hold of.... But if me and the MI boys get a clear night we'll compare views. What other objects do you guys suggest, as a cs was there or not and therefore pretty digital? While I'm not sure that another 200 stars would be noticed in a cluster of 50,000, as an exagerated example, maybe NGC 7789 which is somewhat uniform in member star brightness might display a difference? Any other suggestions?
Steven
2 registered and 8 anonymous users are browsing this forum.
Moderator: matt, Olivier Biot
