Privacy Policy |
Please read our Terms
of Service | Signup and
Kim
Reged: 04/16/04
I just purchased "Barska Binocular Tripod Adapter" for my Olympus 10x50.
Last night, I attached it on Orion's "Large Tritech Tripod," but it was really shaky and unstable.
Both of tripod and adapter have rough rubber surfaces.
Is this normal or is the item defective?
The adapter only costed 8.99 + shipping in Opticsplanet.
Thanks.
Edited by Kim (07/11/08 11:09 PM)
hallelujah
Reged: 07/14/06
Loc: Colorado Rocky Mt. High
More than likely you have purchased a plastic tripod adapter and therein lies the problem. You need a solid metal tripod adapter to overcome the shakes and instability.
This one is "the best" out of four that I own:
http://www.garrettoptical.com/Binocular-Tripod-L-Adapter-p/gladapt.htm
You should return the other for a full refund.
-------------------- Pentax 12x50mm PCF WP II FMC/WP/FP
Pentax 16x60mm PCF WP FMC/WP/FP
Pentax 20x60mm PCF WP II FMC/WP/FP
Orion 12x63mm Mini Giant FMC/JAPAN
Orion 15x70mm Little Giant II FMC/JAPAN
Orion 16x80mm Giant FMC/JAPAN
Orion 20x70mm Little Giant II FMC/JAPAN
Orion 30x80mm MEGAView FMC/JAPAN
Barska 30x80mm X-Trail LW FC
Burgess Optical Series II 20x90mm FMC/WP/FP
Handel's Messiah**Hallelujah! For the LORD God Omnipotent Reigneth
Edited by hallelujah (07/11/08 11:16 PM)
Kim
Reged: 04/16/04
I mean the base does not quite fit on the tripod, and that causes the vibration.
Is it still because of a plastic?
If so, I wasted some money.
Anyway, does that adpater have two holes? One is for a screw and another is for a pin.
Barska have only one hole for the screw; it easily spins even though I completely tightened it.
Rich V.
Reged: 01/02/05
Loc: Carson Valley, Nevada USA
Kim, is there something preventing the L bracket from completely tightening down onto the head? It just sounds to me like you're not mating the two surfaces tightly enough.
The 1/4"-20 screw must be run as far as it can go into the L bracket and then the jam nut around it must be tightened to finish the job.
Just wondering,
Rich V
-------------------- Binoculars:
33-150x100 Saturn III, 16x70FMT-SX, 10x50 PCF-V, 10x43 DCF-SP, 10x35 E2, 7x35 E, 8x30 E2, 7x26 Custom, 8x23AS Diplomat, 8x23 Travelite
Scopes:
C9.25, 6" f8 reflector, SV80S
Kim
Reged: 04/16/04
It goes deeper.
Something was stuck when I just tried.
It fits now
I should test if it's going to be still shaky
Thank you for the help.
Rich V.
Reged: 01/02/05
Hope the bracket is stiff enough.
Rich V
Scopes:
Kim
Reged: 04/16/04
Sorry, one more weird question.
Assume that your binoculars are connected to an adapter.
Does the connection loosen when you spin your binoculars little bit to the clockwise and then to the counterclockwise? (Repeat the same step)
Rich V.
Reged: 01/02/05
Yes, it can. It depends on the design of the adapter. Some adapters use washers w/rubber to prevent twisting the binocular. Others are designed to spin without becoming loose.
A tip: don't expect perfection for $9. ;^)
Rich V
Scopes:
Kim
Reged: 04/16/04
I was just wondering.
Thank you again
Martin O
Reged: 08/09/05
Loc: Malmoe, Sweden
Rich V
I did't like the rubber washer, so I made my self a cork washer and it solves my problem with "tilting bin's"
-------------------- http://www.kikarforum.se
The Swedish binocular community
Kim
Reged: 04/16/04
I guess it is the common problem for most tripod adapters..
I also going to try a cork. Thanks for the info, Martin.
6 registered and 17 anonymous users are browsing this forum.
Moderator: EdZ
