gavbray
Reged: 12/31/06
Loc: Gold Coast, Australia
Star colors in Mallincam?
      #2514250 - 07/12/08 06:15 AM Attachment (41 downloads)
All stars appear to be white in all the images I've taken with my color Mallincam.
In this image you can see a 7 sec (from memory) shot of the open cluster NGC 4755. I've also included a comparative image which shows the central star as yellow. Also, this star is quite distinctly orange/yellow through the eyepiece.
Should I be able to view star colors, as seen through the eyepiece, using the Mallincam? If so, any suggestions for settings I should tweak?
Gavin
14" LX200R + SV90T + AP1200GTO
31mm, 22mm, 17mm Naglers, 13mm Ethos, 10mm Pentax XW, 2X Powermate, AP MaxBright
Mallincam Hyper Plus Color, DFG/1394 video converter, Optec 0.33 & 0.7 FRs
IDAS LPS, DGM NPB & OIII, Lumicon Deep Sky, Baader UV-IR Cut, Baader SkyGlow
JAT Observatory
Space Freak
Reged: 02/20/05
Loc: Eastern PA
Re: Star colors in Mallincam? new [Re: gavbray]
      #2514699 - 07/12/08 12:26 PM
You need to play with your white balance settings. I like to using the manual mode.
-Marcus
The problem with free speech is even the stupid have a voice.
http://jatobservatory.org
12" LX200R on a Paramount ME
rolandlinda3
Reged: 01/24/06
Loc: Crozet VA 22932
Re: Star colors in Mallincam? new [Re: JAT Observatory]
      #2514854 - 07/12/08 01:40 PM
Yes you will see some colors in stars. When you say the color mallinCAM, do you mean the Hyper Color or the older color system? Makes a difference on settings. As for the Hyper Color, a normal good setting for a nebula or nice galaxy is the same setting to use for stars. The reason is this: if you hype the color you can get false color on the stars as the internals work overtime to deliver any hint of color in a point source, so you don't want to overdo it. So rather than go by settings, I adjust and remember my settings for a galaxy I know where yellow and pinks may be in the arms...then I use the same settings (along with the monitor settings) to observe any star color. Also remember that star color that is achievable depends on aperture for stars...more is better. For nebula, I have found the opposite...the color seems easier to achieve with smaller aperture and faster scopes.
Hope someone else can give you more techy comment; my approach is sort-of pragmatic.
Roland
gavbray
Reged: 12/31/06
      #2515325 - 07/12/08 06:18 PM
Yes, I use manual mode and have played around with the settings to try to bring out the star color but to no avail. Colors look good for nebulae.
Gavin
gavbray
Reged: 12/31/06
      #2515351 - 07/12/08 06:31 PM
Roland
I have the Mallincam Hyper Plus. The settings I use work well for nebulae but no matter how much tweaking I do on the Mallincam and monitor I don't seem to get any color in the stars.
The image above was taken with a 14" SCT and MFR-4. Through the eyepiece I can easily see the yellow/orange of the central star using the 14" and also with my 90mm refractor.
Gavin
skyguy88
Reged: 11/13/06
      #2515513 - 07/12/08 08:20 PM
When I do initial allignment using the camera at two seconds, the allignmet stars are almost always white with a bright halo of red or blue. I wonder what they would look like if I cut the exposure to 1/1000 or so. I've never tried it and we're in the midst of our "monsoon" season so I guess it'll be a while before I can try a very short exposure. Has anyone tried to look at stars with very short exposures?
Bill
HendyPhoto
Sith Lord
Reged: 08/09/06
Loc: Bountiful, Utah
Re: Star colors in Mallincam? new [Re: skyguy88]
      #2515606 - 07/12/08 09:24 PM
Has anyone tried a UV/IR cut filter? That may bring out some natural color. I was shooting the leaves one night and that filter made them green and normal looking!
~jon
SparkCast  Ustream
CGE1400XLT w/HyperStar
90FD 66SD C6-R SN-8
CPC1100XLT Hutech 20D
Manny-Mod Vixen Porta
Mallincam MCHP
SPC900NC
CG-5 GT
"Two things are infinite: the universe and human stupidity;
and I'm not sure about the universe." --Albert Einstein
JAT Observatory
Space Freak
Reged: 02/20/05
Loc: Eastern PA
      #2515863 - 07/13/08 12:47 AM
\ Has anyone tried to look at stars with very short exposures?
Bill,
The image I captured above was taken with a 12" SCT.
No integration.
WB was in Manual/User mode.
Red setting 1 tick from the left.
Blue setting was in the middle.
-Marcus
gavbray
Reged: 12/31/06
      #2515911 - 07/13/08 01:41 AM Attachment (22 downloads)
Bill
I sometimes check the focus using Alpha Centuri which is a yellow double but always appears white in the Mallincam. Admittedly I haven't tried tweaking the WB settings for this particular star and have just used my normal settings that work well on nebulae etc.
Here's a fascinating shot of Alpha Centauri with sense up off and a sub-second exposure time.
Gavin
gavbray
Reged: 12/31/06
Re: Star colors in Mallincam? new [Re: HendyPhoto]
      #2515924 - 07/13/08 01:53 AM
I don't have a UV/IR cut filter but have tried an IDAS LPS filter but didn't like the results.
I once had strange banding through an image and was worried I had some sort of equipment defect until I realized I was shooting through a palm tree.
Gavin
HendyPhoto
Sith Lord
Reged: 08/09/06
      #2516449 - 07/13/08 01:02 PM
I have both filters and the IDAS LPS filter is alot different from the UV/IR blocking filter. You may want to pick up a cheap one to see if you like the results. Last night I was using both in 2 different scopes and there are HUGE improvements with both, although it does cut down your light and the integration time will have to be longer. Each filter also requires a different WB color tweak. I am at the point where I use a filter pretty much all of the time, but I dont stick with just one, different objects like different filters. It's fun to play!! lol
~jon
SparkCast  Ustream
90FD 66SD C6-R SN-8
Mallincam MCHP
SPC900NC
CG-5 GT
gavbray
Reged: 12/31/06
      #2517097 - 07/13/08 07:31 PM
That's interesting the IDAS LPS makes such a difference for you. After tweaking etc my results ended up being about the same as with no filter. However, after what you said, I'll play some more and will also get a UV/IR blocking filter out of interest.
Gavin
rolandlinda3
Reged: 01/24/06
      #2517428 - 07/13/08 10:35 PM
Gavin, wish I could help more but I need to check some clusters to see if I am remembering correctly. I do adjust my colors but my adjustment is semi-permanent: I leave red down one notch left of middle and blue one notch above the middle to compensate for the heightened sensitivity of the chip for the red. That being said, I have noticed colored stars in clusters but not that often. If I am using extended settings on bright stars (popular doubles where there is color) then I have not noticed color (probably because the stars are oversaturated anyway). You might see if Jack chimes in on this subject or also check with the yahoo group to get more particulars.
I tend to avoid filters because I have had little noticeable success with them and I have a hard time trying to compensate color balance when one is installed. I am sure others may have better information on filters and how to use them than I, however.
Roland
gavbray
Reged: 12/31/06
Re: Star colors in Mallincam? new [Re: rolandlinda3]
      #2517708 - 07/14/08 02:59 AM
Roland, my color settings are the same as yours and I don't often change them. I haven't had much luck with filters either but will probably try an IR/UV blocking filter as it's a relatively cheap purchase.
I'll do some more experimenting, weather permitting, and will let the forum know if I find anything useful.
Gavin
nytecam
Reged: 08/20/05
Loc: London UK
      #2529585 - 07/20/08 06:02 AM
I suspect your star images are saturated and thus 'white' - could try reducing exposure to the minimum or defocusing to spread the the starlight over more pixels
Nytecam 51N 0.1W
Meade 30cm LX200+ETX-70+DS-2090+C8+Ha+CaK PSTs SBIG SGS+homebuilt spectrographs
Starlight SXVF_M9/Lodestar/Canon 300D DSLR/Fuji E550
My observatory build-ETX-70 imaging-spectro page
gavbray
Reged: 12/31/06
Re: Star colors in Mallincam? new [Re: nytecam]
      #2530782 - 07/20/08 08:27 PM
Thanks for the suggestions. I'll try these when the weather permits. However, I would have thought my sub-second shot of alpha centauri (see above) would not be saturated.
Gavin
rolandlinda3
Reged: 01/24/06
      #2544107 - 07/27/08 12:17 PM
Checked the other night when we did M8 with the SV102ED....we can see a host of yellow stars in the scene. Same for the Trifid. This was at fairly modest settings (14 s and 40-50% AGC.
Roland
gavbray
Reged: 12/31/06
      #2547799 - 07/29/08 07:27 AM
Thanks Roland. I'll be trying again later this week, weather permitting.
Gavin
1 registered and 0 anonymous users are browsing this forum.
Moderator:  Chris Schroeder
Home
