Rhosheen
Reged: 06/06/04
Loc: Maple Valley, Wa.
Skyview Pro goto
      #2515529 - 07/12/08 08:29 PM
I have the skyview pro goto with the 8" ota.
I am trying to control it with my comp. to no avail.
I have a new Toshiba laptop with autostar suite on it but can't seem to configure it to control the scope. What am I missing? My laptop doesn't come with a 9 pin com port but I do have a converter to usb which vista recongizes and installed the drivers for.
I have tried every com port listed but it won't connect. I installed all the ascom drivers just for gigles, still no luck.
In the directions in the manual for the svp, it says that in the utilities section you need to tell the handheld to connect to the rs232 cable. Well, I can't find that on the handheld and I updated the firmware today.
It annoys me to no end.
Phil Andrews
Hardin 6" DSH
Orion SVP 8"GT
desertstarsAdministrator
Deja moo
Reged: 11/05/03
Loc: Tucson, AZ
Re: Skyview Pro goto new [Re: Rhosheen]
      #2518415 - 07/14/08 02:32 PM
This wasn't getting any responses in its original location, so I thought I'd move it here and let you guys take a shot at it.
Tom W.
SVP8 'She turned me into a 3-legged Newt' EQ
Ralph, the All-Purpose 102mm Refractor
Under the Desert Stars
"If we don't change direction soon, we'll end up where we're going." Professor Irwin Corey
Reged: 07/06/07
      #2518487 - 07/14/08 03:19 PM
The reason it does not work is that Autostar Suite is NOT compatible with your scope. It is only for Meade telescopes. There are plenty of programs you can use; here are some free ones:
Cartes du Ciel
Winstars
Hallo Northern Sky
Uncle Rod
Watch for Rod's New Book:
Choosing and Using the New CATs--coming soon!
David Rosenthal
Reged: 06/23/06
Loc: Midland Park, NJ
Re: Skyview Pro goto new [Re: rmollise]
      #2518616 - 07/14/08 04:11 PM
I have the SynScan GOTO kit installed on my SVP and I am able to control the mount with Starry Night Pro 5 and the ASCOM drivers for the Celestron Nexstar5 series of scopes. Strange, but that is what worked !
David Rosenthal | Midland Park, NJ
My Image Gallery
LX90 8" + Feathertouch | Orion ED80 | WO ZS66SD
Orion SVP [SynScan + GPUSB]
Self Modded 400D | DSI Pro | SPC900NC
5000 26mm, Hyperion 17mm, TV 11mm
ccs_hello
Reged: 07/03/04
      #2519010 - 07/14/08 07:41 PM
Phil,
If your SVP Goto is this pic, then what you have is indeed the Synscan-GOTO system.
Vista is tricky, but some USB->RS232 dongles can perform exactly the same thing as a physical serial port does. Just need to find the comptible one .
Clear Skies!
ccs_hello
DonR
Reged: 11/15/06
Loc: Georgia, USA
Re: Skyview Pro goto new [Re: David Rosenthal]
      #2519028 - 07/14/08 07:53 PM
Not strange at all - that's how the Orion manual for the Skyview Pro GoTo System says to do it. Also works for the Atlas and Sirius GoTo mounts.
Don
Atlas EQ-G
Orion 8" f/4.9 newtonian
Orion 127mm Mak-Cass
Orion Skyview Pro mount
Orion 80mm guide scope
Canon Digital Rebel XT
Meade DSI
Philips SPC 900 NC webcam
Rhosheen
Reged: 06/06/04
Re: Skyview Pro goto new [Re: DonR]
      #2525241 - 07/17/08 08:31 PM
That's my scope in the pic. I will try Starry Night Pro 5. I have the ASBCOM drivers installed already.
Phil Andrews
Hardin 6" DSH
Orion SVP 8"GT
Rhosheen
Reged: 06/06/04
      #2544885 - 07/27/08 07:23 PM
Well, it seems I had a usb to serial converter problem.
I bought a new cable and ran the sw and then selected the com port to use and now I can use Cartes Du Ciel.
Phil Andrews
Hardin 6" DSH
Orion SVP 8"GT
RandallK
Reged: 11/10/06
Loc: Nanaimo, B. C. Canada
      #2546385 - 07/28/08 02:21 PM
When I buy something, I like ALL the features to work, even if I'm not going to use them. Such is the case with my HEQ5-Pro/SynScan. I can use Starry Night, Cartes du Ciel, EQMOD, ASCOM, and even Astromist on my Palmx TX with Bluetooth wireless control, to control my mount. But in all practicality, I find taking my Palm TX (without using my Bluetooth wireless control), and just use the Astromist planetarium program to see what's up. Then just key in to the handcontoller the object I wish to view. I can do the same using Starry Night etc. I just find that connecting up another cable is one more cable to worry about tripping over. My mount came with the GPS unit and even after I've set up my mount for the night and the GPS data has been downloaded to the hand controller, I remove it from the H/C as well. I do like the option to contol via computer but the "look-up and enter" mode is a bit easier in my opinion. Whew!
Scopes: Meade SC-8AT w UHTC
SkyWatcher 5" F/5 Reflector
SkyWatcher 127mm MAK
Mount: HEQ5 Pro
Cameras: Orion Starshoot DS Colour Imager V.1
Imaging Source Webcam DMK21AU04.AS
Palm TX PDA w Astromist and Bluetooth wireles control.
Rhosheen
Reged: 06/06/04
Re: Skyview Pro goto new [Re: RandallK]
      #2599094 - 08/23/08 06:03 PM
Yeah, I hear ya on the cable problem. My new LT is set up for bluetooth and I think Orion sells some bluetooth gizmo for thier goto systems. I'll prob. have to buy one.
Phil Andrews
Hardin 6" DSH
Orion SVP 8"GT
12 registered and 10 anonymous users are browsing this forum.
Moderator:  Charlie Hein, FAB
Home
