Telescope Specific Forums >> Meade ACF/RCX / LX / GPS
knuklhdastnmr
Pepperbelly
Reged: 02/24/05
Loc: Beerpuddle, Colorado
Toubleshooting Autostar#497 Proble
      #2516849 - 07/13/08 05:18 PM
After several years of reliable service, the Autostar #497 handbox for my LX-90 8" has a strange case of trouble. It seems to work well initially. It aligns the scope. Drilling down through the menus is the same as always. The first few stops using the GoTo are flawless. The objects are centered when the scope stops slewing. After a few objects, when I select the next object and press go to the handbox announces that it is slewing but the OTA does not seem to move and certainly moves no where near the newly selected object.
After a new alignment, it is spot on again for several objects and then the same thing happens.
I can use the arrow keys to slew the scope about. They seem to be working pretty normally. However, when I use them to center a new target the clock drive does not operate.
The handbox has been dropped from time to time over the years. However, a drop did not immediately precede the onset of this problem.
I did use a conductive epoxy paint kit two years ago to restore the push sensitivity of the buttons. The handbox has functioned well since.
Tonight I will see what happens if I connect the handbox to my laptop and use Autostar Suite to select targets. I'll report the results here.
My best guess is that for some reason the handbox quits sending the slew signal to the drive motors. I have no idea why though. I can't think of any change that would cause that. I thought about a loose wire in the connecting cable. But, if that were the case I wuoldn't think the arrow keys would work. Loss of the clock drive is also a mystery.
Does anyone have any suggestions for diagnosis, further trouble shooting or remedies?
Knucklhead Astronomer
JAT Observatory
Space Freak
Reged: 02/20/05
Loc: Eastern PA
Re: Toubleshooting Autostar#497 Proble new [Re: knuklhdastnmr]
      #2517058 - 07/13/08 07:09 PM
Rick,
Your path of connecting the scope to the AutoStar Suite is good one, but I would be surprised if the symptoms went away when using the AS Suite.
I would execute a reset and a reload of the firmware. I would also as a minimum do a trash collect.
-Marcus
The problem with free speech is even the stupid have a voice.
http://jatobservatory.org
12" LX200R on a Paramount ME
knuklhdastnmr
Pepperbelly
Reged: 02/24/05
Re: Toubleshooting Autostar#497 Proble new [Re: JAT Observatory]
      #2517878 - 07/14/08 08:35 AM
Marcus-
Thanks for the suggestion. I'm not familiar with "Trash Collect." Could you explain that a bit?
KimB
Reged: 02/28/08
Loc: UK
      #2518380 - 07/14/08 02:13 PM
Also check the HBX cable. I've had lots of problems with badly crimped plugs.
Remember the cable is reverse wired, so you can't use a network cable. see pinouts.
8" Meade lx90 LNT
Joe Lalumia
Reged: 01/24/07
Loc: Rockwall, Texas, USA
Re: Toubleshooting Autostar#497 Proble new [Re: KimB]
      #2519965 - 07/15/08 09:30 AM
In the Autostar suite software is an option called "trash collect" --- it removes bits and bytes of JUNK code that might be left in the hand-controller.
As Marcus said--- do a trash collect--- then a RESET-- and re-load the firmware. Re-train the drives, and put in time, date, site-- Then Calibrate sensors on Polaris. Don't rule out a bad cable-- I have had two Meade cables go bad-- and switched to the one sold on scopestuff.com, it is much better quality and more flexible, with better connectors.
LX90 8" LNT, SV Nighthawk & TelePOD, SV 80/9D & M4 mount, ETX 90, Orion XT10i, 20x80 binoculars, SV-BV3s.
"The hardest thing in the world to understand is the income tax." - Albert Einstein
Edited by Joe Lalumia (07/15/08 09:34 AM)
knuklhdastnmr
Pepperbelly
Reged: 02/24/05
Re: Toubleshooting Autostar#497 Proble new [Re: Joe Lalumia]
      #2521516 - 07/15/08 11:41 PM
Thanks folks. I'm going to try your suggestions at my first opportunity. Work intervenes at the moment. But I should get a chance later this week.
Joe Lalumia
Reged: 01/24/07
      #2522373 - 07/16/08 12:41 PM
Your PM --- answered--
Joe
knuklhdastnmr
Pepperbelly
Reged: 02/24/05
      #2525750 - 07/18/08 01:20 AM
Thanks Joe. I still haven't found Trash Collect. I forgot to look when I had the handbox connected.
But, it looks like upgrading from version 3.0 to 5.0 did the trick anyway. I'll know for sure as soon as we get a night clear enough to center some targets.
knuklhdastnmr
Pepperbelly
Reged: 02/24/05
      #2530601 - 07/20/08 06:36 PM
Well, I just thought I had this one solved. Now though, I'm thinking the problem might not be in the handbox. Last night I went for a target almost at the zenith. I acquired that target fine. But, when I hit the GoTo command for the next target, nothing: no movement, no motor sound, no nothing. After I realigned everything worked reliably again.
Does anyone have any thoughts?
Joe Lalumia
Reged: 01/24/07
      #2531975 - 07/21/08 01:52 PM
Did you hit ENTER first-- then GOTO?
knuklhdastnmr
Pepperbelly
Reged: 02/24/05
      #2532244 - 07/21/08 04:05 PM
Don't think so, but I'll keep an eye on that one.
Joseph Gillman
Reged: 12/06/05
Loc: Boothwyn, PA
      #2532366 - 07/21/08 05:06 PM
If you don't hit ENTER to *select* the next desired object, it will GOTO the *previous* selected object, which is usually the object you are currently looking at! So the scope doesn't move at all and then dutifully reports, "Requested Target Acquired, Sir!!"
Be sure Autostar thinks you pressed ENTER first. I say that because sometimes the button connections can get flaky (that too can be fixed easily...)
The ENTER then GOTO thing is the culprit in 99% of these "problems"
PS the display on the handbox should change once you press ENTER, to display some info on the object on the second line
Meade RCX400 30cm --
People dont like when I stick up for Meade but they're just jealous of my RCX
Edited by Joseph Gillman (07/21/08 05:09 PM)
knuklhdastnmr
Pepperbelly
Reged: 02/24/05
Re: Toubleshooting Autostar#497 Proble new [Re: Joseph Gillman]
      #2532875 - 07/21/08 08:23 PM
I applied the paint the back of the buttons fix a couple of years ago. It improved things immensely.
I'm going to point the dang thing at the zenith tonight. Be careful about how I push buttons and see what happens.
It won't be the first time this scope has been repaired by removal of operator error.
knuklhdastnmr
Pepperbelly
Reged: 02/24/05
      #2533329 - 07/21/08 11:56 PM
Dang Operator Error
Thanks guys.
3 registered and 1 anonymous users are browsing this forum.
Moderator:  Joad
Home
