Observing >> Deep Sky Observing
Pages: 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | (show all)
David Knisely
Reged: 04/19/04
Loc: Beatrice, Nebraska
Re: Is it possible to see the nebula with colour? new [Re: semiosteve]
      #2044347 - 12/11/07 05:35 PM
You guys have to get a Mallincam...I see serious color (like hubble color) on a lot of objects in near real time even with my AP 180mm.
Visually I see color with my 20 inch Obsession on the Orion nebula and the Dumbell and a few other larger objects. ...Not neon, but not usually just one color either... There are numerous small blue or green planetaries especially in the summer.
Yes, but a Mallincam is astrophotography and not visual observing. It is possible to see color in brighter emission and planetary nebulae, although again, the colors are somewhat subdued and red will be the most difficult color to discern. Clear skies to you.
David W. Knisely
Hyde Memorial Observatory
http://www.hydeobservatory.info
David Knisely
Reged: 04/19/04
Re: Is it possible to see the nebula with colour? new [Re: Mauro Da Lio]
      #2044390 - 12/11/07 05:59 PM
Maybe, if the observer's eye was sensitive enough (otherwise, probably not). I have only seen the typical bluish-green color in my 10 inch (but 36 inches is a lot of aperture).
The maps of OIII and Ha emissions shows that the ratio Ha/OIII is greater at the centre than in the outer shell. The fringe is greener than the centre. So: if one sees geen the centre it must cannot see the fringe reddish regardless how much sensitive he is to red (the first red he should see should be at the centre).
It depends on the spectral sensitivity of the observer. Most of the observations I have read on NGC 1535 do not mention red at all (bluish, bluish-green, or even gray). One mentions that the outer edge looks a bit "coppery" in color.
The theory that observed colors are necessarily real is dead.
Well, it is dead to you, but not to those who have observed the reds. There is no definitive proof that these colors are illusionary despite all you have provided.
This, besides the ears of M27, is a proof of false color percetion at a relatively high brightness.
No, again, this is not "proof". You have misread a number of the postings here and distorted what was said.
What hiopes remain? IC418 is much redder, so if real red is see that should happen there. Let us see if it is visible in Halpha. As for M42, the brightness levels where red is seen are similar to those of rthe above false colors. Unfortunately those regions are red so we cannot discriminate between false color perception and real perception based on the perceived color. But we only have to wait the ha test.
There is no need to "hope". IC 418 *does* appear red on the edges, and this is well documented as you have been told more than once by a number of people. Also, the "H-alpha test" was done for you by me (and others) using a variety of filter combinations to rule out a contrast effect. Red was seen in parts of M42 when a narrowband filter with H-alpha and OIII/H-Beta passband was used and was not seen when a filter that had only the OIII/H-Beta passband was used. Red was seen when an H-Beta line filter with a high red transmission secondary passband was used on M42 but not when an OIII filter *without* any red transmission was used. This is clear evidence that the red is not a contrast effect, as the red vanished when the filters without any red transmission were used. Why can't you understand this? Although it can be difficult to do, it is definitely *possible* to see reddish hues in M42, M8, IC 418, and Campbell's Hydrogen Star. It is your contention that it is not possible which is "dead".
Mauro Da Lio
Reged: 09/12/04
Re: Is it possible to see the nebula with colour? new [Re: David Knisely]
      #2046394 - 12/12/07 03:59 PM
The test must be made with a Ha alpha filter. It might be that the OIII with read leak passes the star field lights in a different way that without the leak (thus color constancy effects work differently). Given the examples that one can see red through a OIII filter without the red leak, who can say what happens in those critical condition.
You are so convinced that "every color must be real" that you prefer to question the colors of a photo (nor you point any other photo). But, let us suppose that the real red is really seen in some parts of M42 and IC418. Can we say that "every reported color is real" where there is the evidence that starting at 17-18 there are false color perception in *perfect* agreement with the experiments by Pokorny et al? How many real reds are there? I said I think zero, but if it turns out they are 2-4 is that very different?. If you clearly state that except for those few cases red is not seen then we will focus on those four candidates and see if they survive the Ha filter test. To see red, red must be not only above L-cones threhold (which happens in the hygenian region for example) but also *a lot lot lot* stronger than OIII to prevail on it.
As for what concerns the red in the outer fringe of NGC1353, I am afraid but the central part is brighter an richer of Ha (comapred to OIII which still is dominat). Thus there are two unbeatable points against your theory that someone very sensitivy to red might have perceived it:
1) in order to perceive red which is fainter than OIII one should have a sensitivity to Ha *greater* than *his owns sensitivity* to OIII. People sensitivity to Ha is 10% than that to OIII. You imagine somebody who has 200% sensitivity to Ha compared to *his own* OIII (a completely reversed perception of colors!)
2) If somebody would be really able to sense the red in the fringe he *should* also see the brightness and richer in red centre as red too. Not green.
There are serius experiments that fit very well the reports. Why not at least reading and evaluating them? Why ignoring them? How can one say they are not valid without even having read?
PS I google many NGC1535 oics: none shows any trace of red at all. Note that the following picture shows the centre less blue than the outer fring (in agreement withn the fact that the centre has *more* red than the fringe, so why the fringe is seen red and the centre green?).
Do you think that all the pictures are wrong? You probably will rebut the pictures (all?!?) because they do not represent the real perceived colors. The point is however that pictures are more sensitive to red than the eye.
Edited by Mauro Da Lio (12/12/07 04:28 PM)
David Knisely
Reged: 04/19/04
      #2046800 - 12/12/07 07:17 PM
Mauro Da Lio posted:
The only difference between the OIII with the red passband and the one without *is the existance of that red passband*. Otherwise, the primary OIII passbands were very nearly identical. Similarly, the H-Beta filter I used has a similar deep-red passband that passes H-alpha at a very high level of transmission as well as the weaker H-Beta line). Red was seen in M42 with that filter but not with any of the filters that did not have red passbands (such as my newer 2" Lumicon OIII filter). Again, why can't you understand this??
I have NEVER said that "every color must be real". Why do you keep distorting what I (and others) are saying here?? Is your position so weak as to make you unable to discuss things instead of distorting them?? I don't "prefer" to question the colors of images, but I do *point out* that, unless they are done quite carefully to reflect a visual response analog (like David Malin has done), they often may not accurately represent the color detail which may be seen visually. I don't know about the colors seen in NGC 1535, but I do know about those which have been seen in the objects which I specifically mention and that others have observed in large instruments or when using filters. Now please quit distorting what I am saying!
David Knisely
Reged: 04/19/04
      #2047154 - 12/12/07 09:53 PM Attachment (24 downloads)
As for M27, I have never seen any red it it, but the aqua (bluish-green) coloration is quite prominent, especially at lower powers or in large apertures. This is a "balanced" image of M27 taken by Richard Johnson of rural Park Rapids, Minnesota using a 14 inch SCT. He has balanced the color so that an early G-class star like our sun would appear essentially white.
David W. Knisely
Starman1
Reged: 06/24/03
Loc: Los Angeles
      #2047567 - 12/13/07 12:57 AM
If you look at David's image of M27, there is a generally brighter area running across the narrow axis of the ellipse. The ends of that area, also called "the bow tie" or "the dumbbell" appear red in the photo.
This central area appears almost rectangular in the photo, and in real life.
I have made extensive notes on the nebula, and almost always see the brighter area spanning the short axis as greenish-blue. I have never seen any red in that area, despite the rendition of the color photo.
However, in Mauro's defense, the long axis of the ellipse, the area colored aqua in the photo, has appeared reddish to my eye on more than one occasion, and THAT is a spurious color created by my brain under low light conditions. If there is any Ha emission by that part of the nebula, it is miniscule compared to the O-III output.
So can I be certain the fainter areas of M42 that I see reddish are displaying real colors, or are spurious like in M27? It, after all, may just be a coincidence that the reddish areas really DO transmit the reds.
Well, I don't know for sure. However, M27 never damages my night vision, while M42 usually does. To my mind that means that M42 is brighter than M27 and so MIGHT just be turning on real color receptors in my eye. One positive indication is my views of greenish, bluish, and peach shades in the nebula at the appropriate places for those colors. I do see the reds as fainter, which is what I'd expect.
David talks about some empirical evidence that the colors are real.
I hope to get a chance to view the area with an Ha filter in January. I got "skunked" by the weather this month. I'm not certain that will prove anything, because if the image is faint enough, my brain might be filling in the deep red colors instead of their being really transmitted by the Ha filter.
Don Pensack
12.5" Truss Dob, 5" Maksutov
Sustaining Lifetime IDA member, TeleVue junkie
Mauro Da Lio
Reged: 09/12/04
Re: Is it possible to see the nebula with colour? new [Re: Starman1]
      #2048873 - 12/13/07 04:02 PM
Don, the test with Ha is not whether you see red. It is whether you see something. You do not use the color recogntion "software", only shape detection (another independent function). If you see something with Ha filter, that it is the Ha alpha stimulating L-cones. Whatever color you see, it is the red (but I bet that what one sees with Ha is seen red because if it is seen, it is seen by L-cones; the rods do not sense Ha). You do not need to check the color, only to chek what is strong enough to be seen.
I am pretty sure that the Huygenian region is strong enough to be seen red in a Ha filter (we have the report of Nils Olof Carling, and another in this thread). Unfortunately that region emits a lot of OIII too (actually about half the power, but 5 times stronger stimulation of cones given the relative sensitivity to OIII and Ha) and the OIII prevails in our perception.
There are regions with a better ratio Ha/OIII. Are those regions are still within L-cones reach? Maybe. We have to check which parts are seen nin Ha.
Tomorrow or saturday I will hopefully be able to go under dark sky.
Edited by Mauro Da Lio (12/13/07 04:52 PM)
Mauro Da Lio
Reged: 09/12/04
      #2048899 - 12/13/07 04:15 PM
If one looks through OIII filter without the red leak keeping the filter close enough to the eye so that no stray light is seen, one will see something like this:
http://bp3.blogger.com/_rzxz_YRzFn8/RyTnkZqofuI/AAAAAAAAAEU/qp7XzXy7nyo/s1600-h/IMG_5182.jpg
well... not exactly... (sometimes there still are hints of colors, try to believe). BTW note how the rainbow colors of the word "Astronomik" become different monochromatic shades not related with the original color.
If one keeps the filter far enough that stray light from the surrondings is seen the colors "magically apperas". Colors are caused by the mechanism that compensates color dominants (it is the same causing the illusions posted in the past).
http://bp1.blogger.com/_rzxz_YRzFn8/RyTne5qoftI/AAAAAAAAAEM/4n4RWcv608Y/s1600-h/IMG_5186.jpg
The OIII with the red leak lets the red light of the stars "leak" into the field of view. Something might happen similar to the stray light entering in the second image. That might be a possible explanation. I do not know whether it is correct or if there is some other explanation. The fact that this witness apparently conflicts with the theory (proven by a large number of serious and controlled experiments), is not enough to convince me to thow all that serious work to the trash. I bet there is some explanation not needing to question the state of the art.
Of course if the red were seen in some strong Ha regions, strong enough to stimulate L-cones, that would not conflict with the state of the art.
The correct test will be Ha. If the red is claimed in regions that can be seen in Ha then it might be real. Is the fringe of NGC1535 seen in Ha? Which parts of M42 are seen in Ha? So far I know for sure that the huygenian region is seen in Ha (but it is greener).
Suppose one sees: 1) red with the OIII with red leak, 2) not red with the OIII without the leak and 3) you do not see anything at all with Ha; what would be the conclusions?
Edited by Mauro Da Lio (12/13/07 06:38 PM)
Mauro Da Lio
Reged: 09/12/04
      #2049107 - 12/13/07 05:45 PM
Balancing the RGB channels to match G stars as white is not enugh if line spectra are involved. See here an explanation.
http://www.astrodon.com/oldsite/ColorExposure.html
For color realism ith line spectra one needs to reproduce the photopic sensitivity. The passband of the red channel in photos is often a square window, not wheighting the different wavelenghts according to photopic sensitivity. Note how the Ha line is wheighted the same than OIII in the below example set. (cameras not for astronomical use include a filter to reduce sensitivity to red to match eye photopic curve).
All reds in the red passband wheight the same. This is not much of a problem for broadband sources, but it definitely is for line spectra: a line at 565 nm and a line at 656 have the same importance for the digital image but (see below) the latter is 10 times fainter to the eye.
By comparison this is the photopic sensitivity: to the eye Ha it looks 10 times, 2.5 magnitudes, fainter than peak sensitivity of cones, and 1200 times fainter than rods (in mesopic conditions rods sense OIII and cones Ha).
Thus pictures capture Ha stronger than the eye unless a proper wheighting is done *before* the wavelengths passed by red filter are lumped into a "R" overall intensity (or, if R comes only from Ha, a proper reduction factor must be applied to reflect the eye sensitivity to that line http://heritage.stsci.edu/2000/25/ngc7078supp.html). See the link of the hubble realistic color rendering. To see real red you need something really brighter in Ha than in OIII.
Edited by Mauro Da Lio (12/13/07 06:43 PM)
David Knisely
Reged: 04/19/04
      #2050151 - 12/14/07 03:30 AM
No, I see a bluish-green coloration to *everything* when using my OIII that only has the 110 nm FWHM OIII passband. In order to see other colors with that filter, the filter must be significantly tilted (much more so than is present when used at the telescope. There is only the darkness of the edge of the field of view when such filters are used telescopically, so your "illusion" seen with the second image is *not* present when viewing with the scope.
I have looked at M42 using my "Mars" filter (a Wratten #23a equivalent red filter), and while the image was somewhat dim, what I saw was *red* in the nebulosity with *no* other colors present. The brightest red was in the Huygenian region, but the color did extend to some degree away from that area. The filter is not as light efficient as a dedicated H-alpha interference filter, but it does let through H-alpha and did allow me to see clear red coloration in the nebula.
David W. Knisely
Mauro Da Lio
Reged: 09/12/04
      #2050178 - 12/14/07 05:08 AM
1. How do you explain the second photo? (the filer must be kept somewhat away as in the photo). There are colors through the filter in the photo (also original reds and black look the same color!). The same happens to the eye (do not tilt the filter, we are not changing the band pass).
Edited by Mauro Da Lio (12/14/07 05:14 AM)
Mauro Da Lio
Reged: 09/12/04
      #2050184 - 12/14/07 05:27 AM
... The brightest red was in the Huygenian region, but the color did extend to some degree away from that area.
and here is a quote from another post of yours #2005477
... the parts of M42 which show reddish colors to me tend to be well *away* from central Huygenian region and the Trapezium rather than adjacent to them
From these descriptions I understand that the parts that really stimulates the cones (first quotation) are not the same that show reddish color (the second quotation). I mean that I understand that "some degree away" il less away that "well *away*".
So, are you meaning the same regions? And which exactly are these regions?
Edited by Mauro Da Lio (12/14/07 05:34 AM)
David Knisely
Reged: 04/19/04
      #2050205 - 12/14/07 05:54 AM
I don't have to explain the photo! It does *not* represent the situation where you are viewing a nebula with a filter. End of story.
David W. Knisely
David Knisely
Reged: 04/19/04
      #2050213 - 12/14/07 06:08 AM
These are two COMPLETELY DIFFERENT OBSERVATIONS! One was with a red filter, and the other was with a different filter like the NPB or the dual passband OIII. You are comparing apples and oranges. With a red filter, *all* the visible nebulosity was red: PERIOD.
With the dual passband filter, the red was primarily not in the inner Huygenian region but in the area around it and in spots well away from the Huygenian region, like patches in the "wings" of the nebula or the area south of the inner Huygenian region. The inner Huygenian region appears a greenish-blue color in the NPB filter. In the H-beta filter (which also has a red passband), the Huygenian region appears more bluish but the area around it appears more reddish than in the NPB filter, as the H-Beta contribution is weaker than the H-alpha line.
David W. Knisely
Mauro Da Lio
Reged: 09/12/04
      #2050428 - 12/14/07 09:31 AM
The photo shows that the leaking of light (not monochromatic light) may induce the algorithm for white compensation, and likewise the brain (it happes the same), to produce colors from nothing.
A filter with the red leak just do that: lets some red light from stars to leak into the field of view. I do not know if this might be an explanation, however I think that the red-leaking filter test might fail and should be regarded with care and replaced as soon as possible by a Ha test.
As for what concerns the views with different filters, the point is that if real red exists in one spot, it must be seen with both methods. I understand that red was seen in spots far away from the huygenian region with the red-leaking filters, the same spots were not visible at all in the red filter (red seen in the huygenian region and somewhat away it). Am I wrong?
If this is the case (a spot seen red with red-leaking filter but not seen with the red filter), it would be another proof (besides M27 and NGC1535) that at least those spot colors were not real. How is it possible to see red patches that disappears in a red filter?
The countrary is of course instead possible: it is possible to see red the huygenian region when a filter "isolates" the red components, yet that region being richer of OIII appears green.
To see red one must meet two conditions:
a) find a patch that emits Ha sufficient to stimulates L-cones. This is possible and a Ha or red filter will show all the candidates patches and they will be red (being detected by L-cones).
b) the same patch must emit very little or no OIII (otherwise OIII wins and that region is gray or even green depending on the amount of OIII). "Very little" is necessary because the sensitivity to OIII is a lot greater than that to Ha.
Conditon b is indeed the most difficult to meet. My plans are to identify the candidate patches with Ha filter... hopefully as soon as the whether permits.
Edited by Mauro Da Lio (12/14/07 02:11 PM)
David Knisely
Reged: 04/19/04
      #2052147 - 12/15/07 03:25 AM
Yes, you are wrong. With the single-passband red filter (Wratten 23a), red was seen in the Huygenian region *and* the area around it (as well as in the parts of the inner "wing" sections of M42 that are fairly bright) . With the dual passband filters (NPB narrowband, red-leak OIII and red-leak H-Beta), extensive red was not seen in the Huygenian region itself, as most of that appeared a greenish-blue color. However, reds *were* seen in various parts a little outside the Huygenian region, as well as in sections of the "wings" and in some other parts nearer to the outer boundary of the nebula. With the *single* passband OIII line filter or with my older Orion Ultrablock narrowband filter that has no red passband, no red was seen at all anywhere in the nebula (only bluish-green color).
David W. Knisely
Mauro Da Lio
Reged: 09/12/04
      #2052223 - 12/15/07 06:11 AM Attachment (20 downloads)
1)...With the single-passband red filter (Wratten 23a), red was seen in the Huygenian region *and* the area around it (as well as in the parts of the inner "wing" sections of M42 that are fairly bright).
2)...With the dual passband filters (NPB narrowband, red-leak OIII and red-leak H-Beta), ... reds *were* seen in various parts a little outside the Huygenian region,
3)..as well as in sections of the "wings" and in some other parts nearer to the outer boundary of the nebula.
I understand that regions listed in point 2 are appering red also in test 1.
I understand that regions listed in point 3 are the so called "well away" spots which are not seen in test 1.
Thus, at least for the latter, they are seen red in the red-leaking filter but are not visible in the W23A.
My point is not whether the regions seen red in W23A turns green in OIII+Ha (that is obviuos if they emit enough OIII). My point is about spots seen red in OIII+Ha which are far away from the immediate surroundings of the Hygenian regions and are not seen in the W23A. How can be possible that a red spot is no longer seen in a red filter?
To be more precise, here is a picture of M42 where I marked various red sposts. Could you tell which of the marked points are seen red in the OIII/Ha filter? (or if there are others not listed. We can refine the picture with better indications (I also wait you Don here).
Edited by Mauro Da Lio (12/15/07 06:37 AM)
Starman1
Reged: 06/24/03
Loc: Los Angeles
      #2052492 - 12/15/07 10:41 AM
Interesting. The areas arrowed as red emitters are precisely the areas where I have seen red with scopes of 32-82cm.
However, those areas never appeared crimson. The color I've always seen is more like a "dusty rose" or a "red-tinted gray" and only one area near the Huygenian region has exhibited a "slight peach hue" or a "pale peach-gray" color.
The predominant color has never been the red--it's full-spectrum gray.
But, the only area where I've seen a "green-only" hue is in the central region. The fainter outer areas could have been a rose hue diluted by a pale greenish emission. While M43 and nearby NGC1977 have appeared a pale bluish-gray when color has been visible.
And that's another thing--the amount of color visible has changed from night to night. Some nights of exceptional transparency show more color than other nights. I've always seen more color when the nebula was higher in the sky and the SQM gave a darker reading. If the appearance of color was a threshold issue, that would be consistent with my previous observations.
Also consistent with a threshold observation is the fact that larger apertures always make the colors more apparent.
I'm looking forward to seeing what an Ha filter will show. I also have nebula filters with and without a red broadcast, so I'll be interested in seeing what obtains with each.
I have eyepieces that produce exit pupils of 5.4mm, 3.8mm, 3.0mm, 2.3mm, etc., so I'll also be able to test the visibility of colors at various exit pupils.
Unfortunately, due to work, I will not be able to do this test until the new moon period in January.
Don Pensack
Mauro Da Lio
Reged: 09/12/04
      #2052618 - 12/15/07 11:59 AM
Unfortunately me too (at least not in my ~21.5+ dark sky in the Alps). Yesterday a did a little comparison between the W23A and the Ha at Home SQM ~19. I do not consider the test valid for establishing what is visible in Ha. However the comparison between W23A and Ha was... interesting (suspance suspance... I would prefer to hear first you ;-).
Do you mean that you saw reddish (in various forms) in all hose places? Some are very faint (e.g. M). Did you see red in other places (arches?).
Edited by Mauro Da Lio (12/15/07 12:05 PM)
David Knisely
Reged: 04/19/04
      #2052845 - 12/15/07 02:29 PM
You still aren't reading what I am saying! The red filter I have does *pass* H-alpha, but is *not* an H-alpha interference filter! It is a simple dye glass color filter with some of the characteristics of the Kodak Wratten #23a light red filter, and is intended *only* for viewing lunar and planetary detail (such as the dark albedo markings on Mars). Its transmission at H-alpha is not very high (probably around 40% to maybe 60% at best), so while it does show the brighter H-alpha features, it cuts out enough light to hurt the view of the fainter ones. However, the red passband of a filter like the DGM Optics NPB is close to 90%, so there is little attenuation of H-alpha. This makes the somewhat fainter red features more easily visible. These fainter details were not seen in the simple red filter because the red filter does not have the transmission that the dual-band filters do.
David W. Knisely
3 registered and 3 anonymous users are browsing this forum.
Moderator:  matt, Olivier Biot
Home
