Privacy Policy |
Please read our Terms
of Service | Signup and
Talstarone
Vendor (Inner Planetary Products)
Reged: 09/12/06
Loc: Benson, North Carolina
I received my order of some different type micromount cases today from Roman at MeteoriteLabels.Com.
They are nice square acrylic cases with padding measuring 2inX2inX3/4in.They easily fit a flat MeteoriteLabel and are well priced at $3.50 with your choice of label or $1.00 with no label.
I received my first 6 and am going to order several more this evening.
I still love my round,padded gem-cases(jars)for bing much more economical.But I will gradually try to change over my micros to the new labeled cases.
-------------------- Todd C.
Celestron NexStar 4SE(102mm F/13)Maksutov-Cass
Meade ETX-80AT(80mm F/5)Achro Refractor
Meade ETX-60BB(60mm F/5.8)Achro Refractor
Meade #884 Tripod
Meade LPI(Thank You Frank)
Meade DSI-C(Thank You Frank)
edwincjones
Reged: 04/10/04
Look very nice, but costly for a larger collection-I am currently using the small round cases in the WM Rubbermaid box; but at some time in the future a more impressive case will be obtained.
edj
n w arkansas
Binocular, Solar, General Amateur Astronomy
Talstarone
Reged: 09/12/06
It does turn out to be expensive for a largeer collection.That is why I am making the change over gradually.
With around 75 to 80 to change over(Luckily they are larger then the gem-cases and will hold about 1 1/2 to 2 round cases per square case)it will take quite a while to completely get all the square cases. But if I continue collecting I will try to make the labeled cases the ones I use for my micromounts.
But regardless of what you put your micromounts in,its the specimen that means the most.
Meade #884 Tripod
Moderator: Tom Trusock, csa/montana
