Wes James
Reged: 04/12/06
New Garrett RA 70mm's
      #2519143 - 07/14/08 08:49 PM Attachment (40 downloads)
I just purchased a pair of the Garrett 20/25x70mm RA bino's from Zach at Garrett, as always- a pleasure to do business with. It was, however- a week before I could get the out to try to see if I wanted to keep them. Finally last night, I got them out- but just for a very short period of time. It was a hot evening, humid as could be- I took the bino's out in their case over an hour before dark, opened the case 1/2 hour before setting them up to view- to try to let them acclimate to the warmer air outside from the A/C inside environment they'd been in. Obviously I didn't allow enough time, as when I got them set up, the right eyepiece especially clouded up almost immediately, the result of the bino's colder temp maintained in the warmer, more humid environment. Just had enough time to determine that they come to pinpoint focus on stars, focus across the FOV will be acceptable, and on the moon, false color was not bad enough to be an issue. Collimation was fine. The exit pupils- Zach had sent me pictures of before I got the bino's when he was testing them- they are, indeed round. Haven't measured the exit pupil yet, but I will. This was with the 20x eyepieces, probably the only ones these bino's will see use with. One other owner of these Garrett's isn't too happy with the 25x eyepieces- and may try toe Orion's 16x eyepieces. I hadn't thought of that.
I've got mine mounted on an Oberwerk surveyors tripod- topped with an 8" Helix alt-az mount. It was a tiny bit too small to fit the bino's- so I ended up having to make some aluminum spacers to widen out the width of the mount about .125": even so, I still have to remove the cover caps over the side mounted threaded inserts for the mount to fit!
I either need to provide some heat to these bino's- to keep them from dewing up so badly- or allow more time for them to acclimate to the heat and humidity. Either that, or they'll be winter bino's!
I am in the process of having a bracket machined that will allow me to mount a laser pen in place of the handle- which will be handy for pointing the bino's. Will post a picture of that when I get it back from the machinist.
Anyway, I know that there have been some unhappiness in some of the RA bino's, at least I was able to determine these will be keepers- a fact which will make Zenith viewing much more enjoyable than it has been to date.
The sliding dewshields have a snug, smooth feel to them- the metal objective caps are a snug fit that requires a bit of care to put on or take off, but have a quality feel to them- much better than some of the junk out there- and caps are provided for the focusers- open when no eyepieces are installed- and for both ends of both pairs of eyepieces. The quality and fit of all the caps are appreciated. They come in a white bag- with a pair of white gloves... not sure of the need for them?!?! If the bino's were black, mebbe...
Anyway- I'm satisfied with these so far, and cannot wait to check them out further when I don't get "dewed-out".
Wes
Atlantic Beach, FL
Some bino’s from Miyauchi 5x32 Binon's up through Garrett 20x110 Signature's,
Some telescopes from a Stellarvue 80mm NHNG up through a couple of 8” reflectors…
And a wonderful 4.25" Delmarva Shiefspiegler!
Some good friends, made here on C/N.
Oh- several cats and a wonderful wife!
Anyone want a cat???? :-O
"When your work speaks for itself- Don't Interrupt" -Gamble Rogers
Wes James
Reged: 04/12/06
Re: New Garrett RA 70mm's new [Re: Wes James]
      #2519144 - 07/14/08 08:49 PM Attachment (40 downloads)
Another view-
Wes James
Reged: 04/12/06
      #2519151 - 07/14/08 08:51 PM Attachment (23 downloads)
The aluminum filler strips- to sllightly widen the mount- 4 required, to on the base- and 2 on the saddle.
Wes James
Reged: 04/12/06
      #2519155 - 07/14/08 08:52 PM Attachment (21 downloads)
Even so, they're a snug fit in the saddle of the Helix mount.
viperbob
Reged: 08/20/07
Loc: New Jersey
      #2519208 - 07/14/08 09:14 PM
Wes, best of luck with your new setup. Lets us know how they work out when all is well. Jupiter this time of the year would be an excellent target.
Enjoy!!
VB
VB
40 25'N 74 11'W
LX-90 8"SCT
8x40 Nikon Action
Nikon 12x50 AE's
Nagler 7mm Type 1
Nagler 12mm Type 2
Nagler 16mm type 2
Nagler 20mm Type 2
Orion Epic ED-2 22mm
Televue Plossl's 25mm,32mm
Panoptic 27mm
GSO SuperView 30mm & 42mm
Wes James
Reged: 04/12/06
Re: New Garrett RA 70mm's new [Re: viperbob]
      #2519228 - 07/14/08 09:25 PM
Thanks, VB! I'm leaving them on the tripod so they'll be ready to go... Think these will get a lot of use! Now, if they were only, say... 100mm...
or, better yet- 110mm- with the optical quality of the 110mm Garretts! Whooooo- DOGGIE , that'd be AWESOME!
Wes
(you listening, Zach??? )
Nick Lloyd
Reged: 10/24/06
Loc: cincinnati
      #2519322 - 07/14/08 10:15 PM
I assume you can't use regular 1.25" eyepieces with this?
"The best scope is the one you use." -rcg
rookie
Reged: 01/14/06
Loc: St Petersburg, FL
Re: New Garrett RA 70mm's new [Re: Nick Lloyd]
      #2519407 - 07/14/08 10:59 PM
Nice binoculars & mount, You just need a hair dryer!
Shirley
Celestron CPC 800XLT
Garrett 0ptical BT80~45degree
Celestron Ultima 9x63 & Regal LX 10x42
Wes James
Reged: 04/12/06
      #2519962 - 07/15/08 09:27 AM
No, unfortunately- it uses proprietary eyepieces held in place with o-rings. Slightly on the loose side, but not bad- and a nice, smooth feel sliding into the helical focusers. Everything about these binoculars feels pretty good. FYI, the eyepieces measure 1.335" in diameter. The velvety smooth way they fit- they almost feel like they're held in by vacuum pressure.
Agree on the hairdryer!
Wes
GlenM
Reged: 05/20/07
Loc: 53° 36'N 2° 06'W
      #2520130 - 07/15/08 10:54 AM
Wes,
thanks for the quick report on the new 70's 90°
I have been looking at this pair since they appeared on Zach's website.
Someone else(amys) who's got these said the same thing about the 16 eyepieces. Looking forward to another review when weather allows.
Thanks Wes.
Glen
steveoid
Reged: 02/10/08
Loc: London,England
      #2520157 - 07/15/08 11:08 AM
Wes, I have the 100mm binoculars and have found them to be really good and very easy to use. You can observe overhead for hours if necessary you never get neck ache. Mine came with the x20, x30 and x37 and all fit nice and tight. You should see both exit pupils to be both round and just watch the finish on the binoculars when you come to mount them don’t catch the sides on the fork mount. I also got a pair of white gloves and a white bag the bag can be useful but watch the handling if you wear the gloves, the binoculars have an extremely smooth finish and they can slip. The overall view is pretty good and collimation for mine was also spot on, and like you said the colour aberration is not bad at all. These are definitely keepers for me and would recommend them to anyone who does binocular astronomy.
Celestron 8SE.
120mm ED Pro refractor.
80mm ED Pro refractor (solar observing)
Baader Herscel wedge.
Quantum 6- X20,X30 & X37 100MM binoculars.
Helios 10.5 x 70mm HD binoculars
Heq5 Pro mount.Eye pieces
Celestron ultima 2x barlow.
Numerous eyepieces.
FR/FC lens 6.3 Celestron.
2" WO Dielectric.
1/1/2" WO Dielectric.
Wes James
Reged: 04/12/06
Re: New Garrett RA 70mm's new [Re: steveoid]
      #2520180 - 07/15/08 11:18 AM
Hi, Stevoid-
Yes, I would love to have a pair of the 100's... I recently learned they were made by the same factory producing these, however they're not being imported into the US. Spoke to Zach about them, apparently they're not happy enough with the quality of them to take that line on. Sure would love to have a good pair, though... or- as I said- I have the 20x110's- consider the optical quality of them to be very, very good... would love to have those optics in a RA bino! Viewing Nirvana!
Have already realized the finish will be delicate- especially as snug a fit as they are on the mount I have... but once on, the match is wonderful, as the Helix mount is really smooth and solid. I think, for me- the answer is to leave everything together on the tripod- cover it with a towel, so when I want to use it- it's ready to go. Yes- the gloves- on the glass smooth finish- BAD COMBINATION!!
Yes- Amy's the one who turned me on to the 16x eyepieces at Orion... think I'll order a pair. The dimensions are the same, as I'm sure the bino's are (only with Garrett's better QA process), so I'm sure they'll be a welcome addition. The case even comes with 3 sets of holes for eyepieces... so obviously they planned on 3 sets at the factory.
Wes
steveoid
Reged: 02/10/08
Loc: London,England
      #2520272 - 07/15/08 12:01 PM
Wes the shop where I bought them from do a 100mm, 88mm and a 70mm pair. I went for the bigger objectives after trying the 88mm and 70mm because there didnt seem to be any difference in quality..
Celestron 8SE.
Numerous eyepieces.
2" WO Dielectric.
Edited by steveoid (07/15/08 12:03 PM)
DeepSpace67
Reged: 05/13/06
Loc: Kansas City, KS, USA
      #2520312 - 07/15/08 12:16 PM
Congrat's Wes!
Also out last night with the cousin 88's enjoying Jupiter, Moon, and sights in Sagittarius.
Matthew
10" Antares Dobsonian, 8x50 RACI, Telrad, Green Laser
Apogee RA-88-SA, Custom Mount, Green Laser
Garrett Gemini Lightweight 11x56 Binoculars
Mike Conley
Reged: 09/23/07
Loc: NW Ohio
Re: New Garrett RA 70mm's new [Re: DeepSpace67]
      #2520408 - 07/15/08 01:05 PM
I have the Apogee RA 88's. I'm betting those EP's from Orion will fit mine. May try a pair of the 16x.
Wes James
Reged: 04/12/06
Re: New Garrett RA 70mm's new [Re: Mike Conley]
      #2520862 - 07/15/08 04:37 PM
I just ordered the 16x from Orion today. Think they'll be a good choice in these.
Wes
hallelujah
Reged: 07/14/06
Loc: Colorado Rocky Mt. High
Re: New Garrett RA 70mm's new [Re: rookie]
      #2520889 - 07/15/08 04:51 PM
Shirley,
What color do you recommend?
Pentax 12x50mm PCF WP II asph FMC/WP/FP
Pentax 16x60mm PCF WP asph FMC/WP/FP
Pentax 20x60mm PCF WP II asph FMC/WP/FP
Orion 15x70mm Little Giant II FMC/Japan
Orion 16x80mm Giant FMC/Japan
Orion 30x80mm MEGAView FMC/Japan
Barska 30x80mm X-Trail LW FC
Burgess Optical Series II 20x90mm FMC/WP/FP
steveoid
Reged: 02/10/08
Loc: London,England
Re: New Garrett RA 70mm's new [Re: hallelujah]
      #2521030 - 07/15/08 06:16 PM Attachment (17 downloads)
Wes, here is the photograph of the 100mm 90 degree bins.Steve
Celestron 8SE.
Numerous eyepieces.
2" WO Dielectric.
Edited by steveoid (07/15/08 06:18 PM)
Wes James
Reged: 04/12/06
      #2521086 - 07/15/08 06:58 PM
DADDY!!!
Looked them up online, equivalent of about $1600.00 USD... Not very heavy, though- I was surprised. Ace listed the weight as only 13 lbs. Not to mention how much they'd cost to get over here.... Oh, well, nice to think about... thanks for the pic!
Wes
KennyJ
Reged: 04/27/03
Loc: Lancashire UK
      #2521117 - 07/15/08 07:23 PM
Steve / Wes / Glen / and all other night shifters ,
I considered those 100mm Helios Quantum 6 too -- but since 92.675% of my bino activity is carried out in the daytime , looking mainly in horizontal directions , and because I get backache just as a result of standing over a sink for any longer than 7.324 seconds , I decided against it !
The price probably does appear a bit on the steep side in the eyes of our north American friends , but in the UK , two pairs of Leica 25mm compacts can set us back more than that ! :-)
Kenny
Two eyes and a preference to use both
Zeiss 7 x 42 BGAT
Captain's Helmsman 7 x 50
Nikon 10 x 42 Superior E
Swift Audubon Kestrel 10 x 50
Helios 15 x 70 Observation
Strathspey 20 x 90
Televue 76 APO
Zeiss 85 Diascope
Helios 102 f5 refractor
11 registered and 27 anonymous users are browsing this forum.
Moderator:  EdZ
Home
