iceman
Reged: 03/07/04
Loc: Gosford, Australia
Jupiter in nice seeing - 16/07/2008 new
      #2523122 - 07/16/08 07:37 PM Attachment (84 downloads)
Hi all
Here's the first processed image from a session last night in variable seeing, but with a couple of very steady moments. This image is from one of those good moments. I'm not sure the rest will be as good, but at least I got one. Unfortunately the GRS has already finished transiting a few hours before (always the way).
The seeing started deteriorating at around 12:15am local time when the temperature dropped 2deg in 10 minutes. I could've turned my active cooling back on, but Jupiter would've gone behind a tree in 30 minutes anyway so I called it a night.
12" newt on EQ6, DMK21AU04 + 5x powermate.
Thanks for looking.
. My Bio | My Jupiter 2007 Gallery | My Image Gallery
FoxK
Reged: 11/07/07
Loc: Cape Cod, MA
Re: Jupiter in nice seeing - 16/07/2008 new [Re: iceman]
      #2523138 - 07/16/08 07:48 PM
Wonderful image Mike....love to see someone make an animated .gif with images of this quality...I've made some but not good ones with my 80mm
Orion 80mm ED Apochromatic Refractor
Meade 70-AZ-A 70mm Guider
LS60TCaK/B600/C
PHD on a GPUSB interface
CG-5 Advanced GT Mount
Nikon D40x with T-Adaptors
Philips SPC900NC
Imaging Source DMK 21AU04.AS
Dome=the box my mount came in so I can see my solar images in bright sun lol
- click for cloud prediction for Plymouth, MA. area
remuscj
Reged: 04/05/06
Loc: Singapore
Re: Jupiter in nice seeing - 16/07/2008 new [Re: FoxK]
      #2523164 - 07/16/08 08:03 PM
Looks real good, Mike!
Remus
www.celestialportraits.com
Takahashi TOA130F
Takahashi E210
Takahashi CN212
Vixen FL80S
Celestron 5.5 Schimdt
Questar 3.5
Losmandy G11
Losmandy GM8
Vixen Atlux
yock1960
Reged: 06/22/08
Loc: SW Ohio, USA
      #2523243 - 07/16/08 08:56 PM
Wow!
I was happy with my images (6" Newt. unguided) now I'm ruined!
That's a beautiful shot!
Discovery 6" Dobsonian
ETX80 Backpack Edition
SPC900NC
Televue Powermate 2.5x
huckabuck
Reged: 02/18/07
Loc: statesboro, ga
Re: Jupiter in nice seeing - 16/07/2008 new [Re: yock1960]
      #2523248 - 07/16/08 09:01 PM
well mike i see you've done it again. great image
solshaker
Reged: 06/06/06
Re: Jupiter in nice seeing - 16/07/2008 new [Re: huckabuck]
      #2523793 - 07/17/08 04:54 AM
amazing work again!
My Gallery
Lester
Reged: 07/05/06
Loc: South Australia
Re: Jupiter in nice seeing - 16/07/2008 new [Re: solshaker]
      #2525051 - 07/17/08 06:45 PM
Very nice image Mike, good to see.
nickatnight
Reged: 04/14/08
Loc: Santa Clarita, CA (LA Suburbs)
Re: Jupiter in nice seeing - 16/07/2008 new [Re: Lester]
      #2525158 - 07/17/08 07:49 PM
Your image feels just like being there. Incredible!
nickatnight
Celestron CPC 9.25" GPS
Lumicon 2" LumiBrite Diagonal
Meade s5000 18mm UWA, Meade 6.7mm UWA,
Parks G.S-5 10mm, Celestrom 40mm Plossl
Parks 2x Barlow, Meade Tele-Extender
Celestron f6.3 Focal Reducer
Lumicon UHC Filter and Deep Sky Filter
Canon Rebel XTi (prime)
Canon Powershot G9 (afocal)
Canon EOS T-Ring and Parks T-Adapter
Lumicon Univ DigiCam Adapter
siriusc
Reged: 04/03/07
Loc: Racine, WI
Re: Jupiter in nice seeing - 16/07/2008 new [Re: nickatnight]
      #2525249 - 07/17/08 08:35 PM
Hi Mike:
That is definitely one of the most interesting Jupiter composites that you have posted this year. The Festoons along the SEB's northern border are spectacular, have you noticed the incredible wave pattern that these Rifts are producing in the EZ? Also, note the 'Blue Oval' located within the NTrZ, I don't ever recall seeing that before, could it be a new discovery? Like I said before, this is a very interesting shot, congratulations! Cheers, Dan
Edited by siriusc (07/17/08 08:39 PM)
nik59
Reged: 07/07/08
Loc: RUSSIA
      #2528310 - 07/19/08 12:45 PM
Mike! Why you have chosen USB, instead of FIREWIRE?
LX200 10",LXD500 8",Celestron 80 mm ED,TAL-2 150 mm,DMK 21AF04,DSI-pro,LPI,NexImage,Philips-900,Celestron 25*100mm Skymaster
iceman
Reged: 03/07/04
Re: Jupiter in nice seeing - 16/07/2008 [Re: nik59]
      #2528739 - 07/19/08 05:11 PM
Thanks guys for your feedback. Much appreciated. It sure was nice to be out amongst it again.
Nik59, I used to have the DMK firewire, but I sold it and bought the DMK USB because it was much more convenient for me. The firewire required a PCMCIA firewire card + external powered hub, because my laptop didn't have a firewire port. The USB draws power from the USB port itself, so no other power is required, no other cables. Just much easier.
Plus, I had the older DMK firewire which was only 30fps, while the newer USB DMK can do 60fps. It's also much more stable (for me).
DBleser
Reged: 02/28/07
Loc: North Miami Beach, FL
      #2532083 - 07/21/08 02:46 PM Attachment (5 downloads)
Even South Florida Amateurs like my wife and I are jealous of your location! The best we are getting this year is 42 degrees. The photo I took of Jupiter on July 21st shown below is not far from the view you photographed 5 days earlier. Taken from Miami, FL with a CGE 1100, 2.5X Powermate, Astronomik RGB filters and a DMK21AF04 using Astro IIDC. The best 200 out of 900 frames were used for each filter. The RGB images were taken at 2:48 UT on July 21, 2008. CM I 42 deg, CM II 355 deg, and CM III 299 deg. Altitude 36 degrees on a calm, clear night with good seeing and no dew problems. We are lucky to get 2 nights like this per summer month in South Florida.
Talstarone
Vendor (Inner Planetary Products)
Reged: 09/12/06
Loc: Benson, North Carolina
Re: Jupiter in nice seeing - 16/07/2008 new [Re: DBleser]
      #2532590 - 07/21/08 06:33 PM
Spectacular Image,Mike.The clarity of Jupiter in this image is as close to perfect as I have seen.
Tremendous amount of detail and contrast.Mike your talents in capturing these Images is amazing to say the least.
And dont feel bad Bleser,the image you have captured is exceptional in its own right.I would be estatic to have captured an image as detailed and sharp as yours.
I would like to say Thank You To Both You Mike, and The Blesers as well.Its a treet to get 2 images in 1 thread.
Todd C.
Celestron NexStar 4SE(102mm F/13)Maksutov-Cass
Meade ETX-80AT(80mm F/5)Refractor
BO/TMB Planetary 9MM EP
Celestron E-LUX 25MM Plossl EP
Celestron E-LUX 40MM Plossl EP
Smart Astronomy 5X's APO(3-Element)Barlow
David Rivas
Reged: 05/29/04
Loc: Lima, Peru
Re: Jupiter in nice seeing - 16/07/2008 new [Re: Talstarone]
      #2534177 - 07/22/08 01:14 PM
Splendid shot Mike!!
I love the image size and detail!!!
Bests,
David
6 registered and 2 anonymous users are browsing this forum.
Home
