imjeffp
Senior Space Cadet
Reged: 09/30/03
Loc: Cedar Park, Texas
Pretty good seeing at 1:30 this morning with just a moderate ripple. Jupiter was far enough west that it wasn't directly over the roof of the house. LRGB with the DMK21AF04 in the LX200 @ f/25.
-------------------- Blog
ST80 • AT80EDT/LXD650
ETX-90/DS-2000 • 10" LX200 Classic ("The Quarter-Meter Telescope at the Heritage Park Observatory")
SPC900NC • DMK21AF04 • Digital Rebel XT
jimarshall
Reged: 03/20/07
Loc: Virginia
Great picture Jeff, I know what you mean about the roof. I have to photograph Jupiter over my roof top and heat pump!
-------------------- Jim
imjeffp
Senior Space Cadet
Reged: 09/30/03
Yeah, my next house is going to have the back yard to the south! (Can you imagine how baffled the real estate agent would be?)
DesertRat
Reged: 06/18/06
Loc: Valley of the Sun
Jeff thats a fine image for a northener (I bet they dont call Texans that very often!). Look forward to your Jupiter images in the coming years when its a bit higher. Well done!
Glenn
-------------------- Brandon 94mm f7, Televue TV102 f8.6; GM8
Baader Wedge & Filters, Coronado SM90/BF30
Intes Micro M715
Celestron C11 SCT + CI700 mount
solshaker
Reged: 06/06/06
nice one, Jeff. the center dot in the grs stands out well.
-------------------- My Gallery
john D
All you have to do is ask!!
Reged: 08/05/07
Loc: Midlothian, VA
wonderful shot jeff!
-------------------- Meade ETX-125EC (SEPT.7)
Orion 90mm mak-Cass
Celestron NS GOTO mount
Philips SPC900NC webcam
MY BLOG
-Midlothian VA
nik59
Reged: 07/07/08
Loc: RUSSIA
Jeff! I have telescope LX200 GPS+camera DMK21AF04 too. My photo Jupiter R+DMK21+LX200,10-05-08. Height above horizon of 8 degrees. It is my first experience. How you estimate it(him)? You Jupiter is very good.
-------------------- LX200 10",LXD500 8",Celestron 80 mm ED,TAL-2 150 mm,DMK 21AF04,DSI-pro,LPI,NexImage,Philips-900,Celestron 25*100mm Skymaster
DBleser
Reged: 02/28/07
Loc: North Miami Beach, FL
Here's ours at 40 degrees. Note that yours is better because the haze was so bad that Jupiter had dimmed to the brightness of Saturn, making photography at speeds greater than 15 fps impossible.
imjeffp
Senior Space Cadet
Reged: 09/30/03
Howdy Nik!
Around here, we call 8 degrees "tree-skimming." That's pretty good for a first shot--all you need is practice. Have you tried imaging the moon?
Talstarone
Vendor (Inner Planetary Products)
Reged: 09/12/06
Loc: Benson, North Carolina
Very Nice Image,Jeff.The detail and clarity of the banding in the pic was superb.
How well do you like "The Imaging Source" CCD Imager?I always like it when I see your name on a thread in the imaging section,because your images(no matter which scope you use)are always of Great Quality.And you didnt disappoint in this image either.
Just a quick question,is you Imaging Source Camera a USB or FireWire?Thanks,My Friend.
-------------------- Todd C.
Celestron NexStar 4SE(102mm F/13)Maksutov-Cass
Meade ETX-80AT(80mm F/5)Refractor
Astro-Tech AT-80(80mm F/6)Refractor(coming in September)
BO/TMB Planetary 9MM EP
Burgess 65 Deg. 20MM WA EP
Celestron E-LUX 25MM Plossl EP
Celestron E-LUX 40MM Plossl EP
Smart Astronomy 5X's APO(3-Element)Barlow
nickatnight
Reged: 04/14/08
Loc: Santa Clarita, CA (LA Suburbs)
hey imjeffp - you make Texas look like Australia with that shot. Nice.
-------------------- nickatnight
Celestron CPC 9.25" GPS
Lumicon 2" LumiBrite Diagonal
Meade s5000 18mm UWA, Meade 6.7mm UWA,
Parks G.S-5 10mm, Celestrom 40mm Plossl
Parks 2x Barlow, Meade Tele-Extender
Celestron f6.3 Focal Reducer
Lumicon UHC Filter and Deep Sky Filter
Canon Rebel XTi (prime)
Canon Powershot G9 (afocal)
Canon EOS T-Ring and Parks T-Adapter
Lumicon Univ DigiCam Adapter
Jeff in Austin
Reged: 02/26/07
Loc: Austin, TX
Hi Jeff! Great shot! I'm looking at the same camera, but the USB flavor. How do you like it? Any thoughts on the higher pixel count versions?
-------------------- Stellarvue SV102ED
Celestron C8-SGT XLT GoTo
Astro-Tech AT66ED grab n'go/finder/piggyback/travel/spotting scope
Canon XTi unmodded, TC80N3 timer, Stiletto Focuser.
2 Totes of various Astro Doo-Dads.
Supportive family, including 5 y.o. w/ Meade 60mm, sleeping infant, and lovely wife.
imjeffp
Senior Space Cadet
Reged: 09/30/03
Wow, thanks y'all.
I'm very happy with my TIS DMK21AF04. I can only compare it to the NexImage and the Philips SPC900NC, and it's definitely a step up in both quality & complexity (LRGB vs. one shot). I did a comparison using Mars when I got the DMK that I think shows the difference pretty well.
I use the Firewire version since I'm on the Mac and can use AstroIIDC to drive it. I'm not aware of a Mac USB driver.
For planetary imaging, there's no advantage to the DMK31 or 41. If anything, they're not as well suited since the larger frame slows down the max frame rate. The larger frame might be nice to have on the moon, though, for making mosaics from fewer images.
nik59
Reged: 07/07/08
Loc: RUSSIA
I did(made) by photo Moon with help LPI. I present Image of Moon, 28-08-2005, telescope LXD 500, 8 ”.
Edited by nik59 (07/22/08 01:12 AM)
Talstarone
Reged: 09/12/06
Thanks for the Link Jeff. The Mars comparison is exactally what I needed to see. Great Work.
David Rivas
Reged: 05/29/04
Loc: Lima, Peru
Hi Jeff, Great result for such a low elevation!! Regards,
David
lukasik
Reged: 10/11/05
Loc: Lawrenceville, Georgia
Good stuff Jeff. That's some nice detail for 35 degrees. Send more!
Bob
DSalters
Reged: 03/03/07
Loc: High Ridge, MO (St. Louis)
I know this is a thread about Jupiter, but I can't help but enjoy Nik's lunar image. There's something about the angle of the light sorce on the moon that makes that a very appealing image. It is also an orientation of the moon/photo that I do not see all that often.
Nice
-------------------- 5" f/5 Celestron Rebuild Grab-and-Go (under construction)
6" f/8 Bushnell Voyager Dob. Rebuild
10" f/5 Highe Dob. variant (under construction)
EPs: Antares Modified Erfle (30); Baader Hyperions + Finetuning Rings (17, 13, 8); BO/TMB Planetaries (4)
"The sun has one kind of splendor, the moon another and the stars another; and star differs from star in splendor." -1 Corinthians 15:41
JMP
Reged: 10/31/05
Lovely image, Jeff. It's only getting about 23 degrees above the horizon for me this year.
