Privacy Policy |
Please read our Terms
of Service | Signup and
amys
Reged: 06/12/06
Loc: Groton, CT
I'm looking for some mount advice. I just got the Garrett right angle 70mm binoculars (same as the Orion BT-70). I have the Orion paragon plus tripod but I found that the binos won't stay put when they're pointed at the sky -- they're too back heavy so the eyepieces drift down towards the ground.
So I've been mulling 3 different possibilities and I'd like your input. I have a Desert Sky Mount. I think I could get a heavy duty L-bracket to attach to the binos and then attach the bracket to a dovetail to use on that mount. One problem with this -- the binos will be quite close to the top of the tripod and I'll constantly be stepping around tripod legs. There's also no way to change the height of the binos without adjusting the tripod legs.
Second possibility: Universal Astronomics T-Mount light. This looks like it would get the binoculars away from the tripod and adjusting the height looks like it would be very easy. I'm assuming that it's designed to be easy to balance. But I'm wondering if it will be a hassle to set up.
Third option: The oberwerk fork mount, assuming these binos will fit. This mount will not solve the height issue and I'll still be stepping around the tripod legs.
So your thoughts? Any better (not too expensive) options?
-------------------- Amy
Wes James
Reged: 04/12/06
Is a pier mount a suitable prospect for your bino's- then pick an appropriate head? No legs sticking out, that way- Otherwise, I would think a P-mount such as the Uinversal Astronomics would be the best. I believe Joe Ogiba uses a setup like that for his RA-88's and seems to like it- ans he recently posted pictures of it here in one of the threads. Wes
DeepSpace67
Reged: 05/13/06
Loc: Kansas City, KS, USA
Homemade mount
-------------------- Matthew
10" Antares Dobsonian, 8x50 RACI, Telrad, Green Laser
Apogee RA-88-SA, Custom Mount, Green Laser
Garrett Gemini Lightweight 11x56 Binoculars
11 registered and 16 anonymous users are browsing this forum.
Moderator: EdZ
