Homa
journeyman
Reged: 06/21/08
Loc: Germany,by Hamburg
Hi, my first mount in wood built with 40 mm steel axis in 2001
-------------------- i very like historic refractors
Homa
journeyman
Reged: 06/21/08
Hi, the second mount in steel and aluminium i have show in refractor forum(or look in classic scope gallery under "HOMA") the third last mount only in steel(85%)has in rekt. 85 mm axis and in decl. 77 mm diameter the rekt axis it is 24 inch long , the decl.axis ~ 18 inch (it is not ready now) the worm gear has 8 1/2 inch diameter( 420 €)-is temporary -later will be Gierlinger worm gear 14 "(~2000 €)better quality and the temporary worm gear sitting on decl.axis  the project will be longer time-not enough money
Homa
journeyman
Reged: 06/21/08
now the flange for rekt. ready ( 85 € )
only the rect.-axis(D 3"/d 1,55") had 125 € cost.
Regards marc
PS: this mount will be taken a 8"f25 or 10"f20 or 11"f30inch folded-refractor
Edited by Homa (07/17/08 04:43 PM)
Luigi
Reged: 07/03/07
Loc: Massachusetts
Fat axles are cool, but seems most mounts nowadays are going for large flat (or shallow coned) surfaces with thrust bearings to take the load, rather than the shaft. The shaft is relatively small diameter, more to put tension on the thrust bearings than take the bending load.
-------------------- 17.5" f/5 Discovery Truss
IM715 7" f/15 MCT (due July!)
Eon-120ED refractor
CG5A coffee grinder, Orion Skyview Alt-AZ
35,19,15 Pans.9 Nag. Meade 24.5 4kSWA, 4.7 5kUWA.
BO-TMB 7mm planetary.
Zeiss Diascope 85
Zeiss, Leica, Canon IS, Fujinon, Nikon binos
Homa
journeyman
Reged: 06/21/08
Hi, i think two bearing pairs to sitting by 2x tapered bearings D150/d85/H31 are enough. joseph fraunhofer had take for the struve mount(Dorpat) too ~95 mm steel shaft and only gliding bearings. okay, the repsold mount of kufner observatory(vienna)is perfects  i am not the mechanical master  perhaps the long telescope-tube it is heavy ,but under f 20 the false color will be greater  i am not like to buy a chroma corrector  perhaps are 8"f18 or 10"f18 or 11"f 25 (folded) enough  i believe that the axis in steel will be not breaking and the bearing can to change regards Marc
Mike Clemens
Reged: 11/26/05
Loc: Alaska @ 61N -149W
ooo that last pic is gorgeous
JohnG
Reged: 12/16/06
Loc: Wake Village, Texas - East Tex...
Me, too! Antique refractors have an appeal that modern equipment just doesn't match. What scope are we looking at in the last photo, Marc? I collect photos when I can get them so I'd like to know more about the telescope.
JohnG
Cyclop_si
Reged: 03/13/08
Loc: Slovenia
Wooww, there is a lot of wooden hand controls. What are they for?
-------------------- David
Homa
journeyman
Reged: 06/21/08
Hi, this is a 11"f13,5 Optic from Steinheil(munich,1896)the mount from Repsold(hamburg,1896) the hand-controls(wooden knobs)to distracts(?) the rect and decl in slowly and speedy
Homa
journeyman
Reged: 06/21/08
Hi, you want more photos >send me your mail-adress regards Marc
BRCoz
Reged: 10/21/05
Loc: Moreno Valley, CA
WOW! very nice.
-------------------- 60mm AP guide scope
WO ZS80FD 10th Anniversary
FS102, AR5, APM/TMB 130
102 Apex, 8" Meade LX10, C11
PST
GM8, G11 & ASGT
Denk Standard, 25x100 binos
30D, 10D, AE-1, OM1
tim53
Reged: 12/17/04
My gawd, that's a beautiful telescope!
-Tim.
-------------------- "We`re just waiting looking skyward as the days come down.
Someone promised there`d be answers, if we stayed around."
-Orchestral Maneuvers in the Dark, "The Romance of the Telescope"
Homa
journeyman
Reged: 06/21/08
Now the decl.axis case in work
Edited by Homa (08/15/08 07:42 PM)
Wes James
Reged: 04/12/06
Homa- Your work is awesome.. and the pictures of the Antique telescope and mount- beautiful.. simply beautiful. Sometimes I think they don't think they make things the way they used to... then, sometimes I think there's hope.
-------------------- Wes
Atlantic Beach, FL
Some bino’s from Miyauchi 5x32 Binon's up through Garrett 20x110 Signature's,
Some telescopes from a Stellarvue 80mm NHNG up through a couple of 8” reflectors…
And a wonderful 4.25" Delmarva Shiefspiegler!
Some good friends, made here on C/N.
Oh- several cats and a wonderful wife!
Anyone want a cat???? :-O
"When your work speaks for itself- Don't Interrupt" -Gamble Rogers
