sirzeusor
Reged: 04/27/08
Loc: Stow, Ohio USA
i think either my focus was a bit off, or this is just a challenge to do in light polluted ohio, looking through a lot of air, since it is so low in the sky, but heres what i managed to get out of what i thought was a good night....mag 5 around 2am ( mag 5 is rare where i live) dont mind the green lines, its something registack did...???? suggestions welcome
-------------------- http://www.ohioastronomy.com/
Orion XT10 Dobsonian
10MM Orion Sirius Plossl
25MM Orion Sirius Plossl
Orion 2x Shorty Barlow
LaserMate Delux Laser Collimator
SteadyPix SLR Camera Mount
Kodak EasyShare C74 Point & Shoot
Phillips SPC900NC Webcam
& a lot of patients.............................................
X-Lurker
Underpaid Slacker
Reged: 09/12/06
Loc: N.W. Ark.
I think it looks good, how many frames did you capture and what was the frame rate? Assuming you used the web cam.
-------------------- I wasn't sick...I just called in uninterested
Glob
AOAS Member
Atlas 10 EQ-G Reflector (Cloud Magnet)
12X50 Bino's
SPC 900NC
sirzeusor
Reged: 04/27/08
Loc: Stow, Ohio USA
i used my point and shoot, avi about 900 frames
i am considering selling my webcam, with out buying a new laptop, its useless, and i have gotten better results with my camera doing afocal to be honest, and im considering a better DSLR camera to use for the family , and double as a AP camera im almsot ready to sell the SPC900NC on e bay with all the goodies, i've pretty much had it trying to get results with it, cant figure out what all the hype is about it, i think its awfull!
sirzeusor
Reged: 04/27/08
Loc: Stow, Ohio USA
i have even gone as far to read all the forums , and people that use this webcam, bought a 30' extension for my webcam and my monitor to use with my main computer, and it just dosent seem to get the job done for some reason
X-Lurker
Underpaid Slacker
Reged: 09/12/06
Loc: N.W. Ark.
I've had pretty good results with mine, no complaints so far...You shouldn't have any problem selling it. Did you use your Steadypix on this image? Not bad for an afocal.
Glob
AOAS Member
12X50 Bino's
SPC 900NC
sirzeusor
Reged: 04/27/08
Loc: Stow, Ohio USA
ya i used the steadypix and my point and shoot, so if i am getting these results this way, it leads me to believe i have the concept grasped more then the webcam method, therefore, may be go off to the afocal of a better camera, or the one where i put the camera in the eyepiece and or use the cameras zoom and features.....forgot the term ....but im sure you follow
fishmagnet
Reged: 12/11/07
Loc: Satellite Beach Fla
Webcams do work. This is an image shot through my 103mm (4.5 inch)refractor using a Philips PCVC 740K TouCam on 7/10/08. Your image looks like it might have been affected by atmospheric turbulence or maybe heat waves coming off a hot roof. Florida is famous for unstable air and sometimes my images look similar to yours. It is best to capture planetary images when the object is close to the zenith. When you image close to the horizon you will get blue or green edges on Jupiter's limb. Light pollution is probably not your problem. The sky around my house is very light polluted.
****John
-------------------- Vixen ED 103S refractor
Vixen VC 200L
Takahashi EM 11 Temma II Jr
Astro-Tech AT66ED
SBIG ST-10E CFW-8
Meade DSI Pro II monochrome CCD
Atik filter wheel
Philips PCVC 740K ToUcam
Registax 4.0
Photoshop CS3
MaxIm DL4
The Sky 6
Astro-Lab Roxy
Member Brevard Astronomical Society
"Starin' at the stars in a distant galaxy; wonderin' if there's someone out there starin' back at me!"
Fountains of Wayne
Edited by fishmagnet (07/20/08 07:39 PM)
huckabuck
Reged: 02/18/07
Loc: statesboro, ga
using a 30' extension on a webcam will cause ALOT of image compression. you'd be better off without using it.
stefsaber
Reged: 06/24/06
Loc: Rainy Florida
I second that! If at all possible get a laptop so you don't have the long extension.
-------------------- -Stefan
"It’s not the fall that kills you; it’s the sudden stop at the end." -Douglas Adams
Current Scopes: "Gator" William Optics 66SD---Black Swan William Optics Megrez 80 II ED Triplet---Zhumell 10" Dob
-Sirius Mount---Canon Rebel XT-
Past Scopes: ETX 90---Vixen ED80Sf
Fort Myers, FL
FoxK
Reged: 11/07/07
Loc: Cape Cod, MA
Also..after you stack with registax...try going into the wavelets section and increasing the sliders (i typically leave the top one (1) alone and the rest are adjusted.
-------------------- Orion 80mm ED Apochromatic Refractor
Meade 70-AZ-A 70mm Guider
LS60TCaK/B600/C
PHD on a GPUSB interface
CG-5 Advanced GT Mount
Nikon D40x with T-Adaptors
Philips SPC900NC
Imaging Source DMK 21AU04.AS
Dome=the box my mount came in so I can see my solar images in bright sun lol
- click for cloud prediction for Plymouth, MA. area
sirzeusor
Reged: 04/27/08
Loc: Stow, Ohio USA
ill keep at it then and start saving for a dedicated laptop the one i have is so old, i'd have to buy a new hard drive for it, its 2g and xp takes up most of that.....ill consider upgrading the laptop first, then weigh my options thanks for all your help
a-l-e-x
Reged: 12/25/07
Im thinking of getting the steadypix universal mount for my digicam (its an Olympus C7070). Would it work well with that cam and 40mm or 32mm EPs? My cam has a front filter thread of 40.5mm How long an exposure can I take with this setup? I have a Nexstar 8SE. Im looking for exposures of up to about 15sec so I can image the moon, planets and some dso (M13, M42, M31) as well. Is the vignetting minimal and can I use barlows and filters with this setup? The EPs I will be using with this are the Orion Highlight Plossl (40mm) and the Sirius Plossl (32mm). Thanks!
We love our precious Harmony, our sweetest Destiny and our darling Sonya Marie !!!
sirzeusor
Reged: 04/27/08
Loc: Stow, Ohio USA
i would assume it would depend on your mount's tracking ability, and if your camera can be set for that esposure time as long as your camera has a 1/4"-20 thread on the bottom, it will mount up to it, via either a 2" or 1.25" eyepiece
a-l-e-x
Reged: 12/25/07
Thanks! My camera has a great manual mode. Do you use any other accessories, or just camera+steadypix+telescope? I have the tripod adapter at the bottom of my cam. No risk of the camera falling off? My cam's zoom range is 27mm-110mm, so hopefully this set up will work fine. Whats the longest steady exposure been and what EPs have you used with it? Also, have you done any dso's? How bad is the vignetting at wide angle? Thanks!
sirzeusor
Reged: 04/27/08
Loc: Stow, Ohio USA
havent tried any dso's yet, mostly concentrated on closer objects like planets and the moon for the learning curve to kick in.... im also learning how to use my eq platform, that has been a steep learning curve, and i ended up modifying it a lot to get it to do what i wanted it to do, i dont use auto-guiding or a goto system, so the challenge has been to find the objects in the middle of the light polluted city
as far as the camera goes, you may want to consider the prime focus method, where you screw an adapter on the camera itself, then use it inplace of the eyepiece, or basicaly , slide directly into your focuser and use the camera as the eyepiece....its cheaper, and i think the results are better look up these 2 methods of astrophotography: afocal prime focus
john D
All you have to do is ask!!
Reged: 08/05/07
Loc: Midlothian, VA
great shot! looks good!
-------------------- Meade ETX-125EC
Meade LXD55
Orion 90mm mak-Cass (4SALE look in S&S)
Celestron NS GOTO mount (4SALE look in S&S)
Philips SPC900NC webcam
MY BLOG
-Midlothian VA
sirzeusor
Reged: 04/27/08
Loc: Stow, Ohio USA
so close to zenith, meaning its low in the horizion, and im looking through a lot of air, and be patient for it to rise higher "up" k got it webcam issues....be more patient with it, dont blow another grand on a DSLR and get a laptop or upgrade the dinasuar i currently have and dedicate it to astrophotography.......k i got that too... be patient and wait for nights of great viewing of objects close to zenith... take on the DSO once you better learn the nights sky, and study the maps more, because you cant afford the ATLAS you realy want, plus the tracking OTA and the additional autoguider camera to track them....and plug it into your atlas, refer to cant afford that..yet.....lol pospone the iphone for work coz AP is more important.....lol and if you do decide to sell the SPC900NC, wait a bit longer untill your totaly frustrated after like a year or more ( coz they will be worth more, if you havent had any sucess at that time) then sell it for the iphone, and make a profit? im getting this right............right? lol thanks all, im jsut frustrated.....i took up this hobby to learn patients.......im getting it now....thanks!!
Fusion
Reged: 01/27/08
Loc: Amory, MS, USA
This has to be one of the most "other factor" dependent hobbies that I know of. Patients is an absolute must.
-------------------- Lee
Celestron Nexstar 8SE
Orion 80mm Shorttube
Piggybacked on the CG-5 ASGT Mount
Meade DSIc
Phillips SPC900NC/00
a-l-e-x
Reged: 12/25/07
Can you do prime focus with a point and shoot with manual controls? Also, how did you convert the images into avi format and combine individual frames into 900? Thanks!
