Privacy Policy |
Please read our Terms
of Service | Signup and
Wildthing
Reged: 11/07/07
Loc: Muncie, IN
I just purchased a Phillips SPC900NC Web Cam. I wanted to use it with my newer laptop which has 2GB memory and uses the Windows Vista Home Premium operating system. Per the instructions with the web cam it does not say it will run on Vista. My older laptop uses Windows XP however my older laptop does not have as much memory (512MB) as my newer HP laptop. Is there some other software I can or should use with the Phillips SPC900NC web cam to make it workable with Vista so I can use my newer laptop? I wanted to try to do some astro imaging..... I already have the 1.25" camera eyepiece adapter.
Thanks for your time! Don
Clear Skies, Donnie / Muncie, IN
Equipment:
Orion 80ED
Celestron C-102 (102mm)f/10 Achro Refractor
Celestron Omni XLT 120 Refractor Telescope
Vixen R130sf Reflector
XT8i Orion IntelliScope
Celestron C-6 Schmidt-Cassegrain
Tripods / Mounts
Celestron CG5-GT, CG-4, TV Gibralter with Sky Tour
sirzeusor
Reged: 04/27/08
Loc: Stow, Ohio USA
i believe this is what your looking for Vista Driver for SPC900NC
-------------------- http://www.ohioastronomy.com/
Orion XT10 Dobsonian
10MM Orion Sirius Plossl
25MM Orion Sirius Plossl
Orion 2x Shorty Barlow
LaserMate Delux Laser Collimator
SteadyPix SLR Camera Mount
Kodak EasyShare C74 Point & Shoot
Phillips SPC900NC Webcam
& a lot of patients.............................................
Chris_H
Reged: 11/24/03
Loc: Norway
You don't need a lot of RAM to run the SPC900, a fast hard drive is more important (to stop dropped frames). My old Dell with 512mb ram had no problems at all Vista uses a ton of memory just sitting around doing nothing at all. You'll probably be using more RAM running the cam under Vista then under XP!
-------------------- Chris
"Big Papa Smurf" (254mm f/4.7 Sky-Watcher Newt)
Megrez 80 II
SPC900
Canon Powershot A610 (CHDK modded)
Canon 10D (modded)
Canon EF 50mm f/1.8 II
Canon EF 70-200mm f/4 USM L
My Website
rcd47
Reged: 03/15/08
Loc: East Texas, USA
Also, you'll probably do better using another capture program instead of V-Lounge that comes with the camera. I never could even get Vlounge to install on my Vista laptop. Try Astrocapture http://arnholm.org/astro/software/wxAstroCapture/
or K3CCDtools http://www.pk3.org/Astro/index.htm?k3ccdtools.htm
or maybe AMCap http://amcap.en.softonic.com/
There are others too. I like Astrocapture because it's simple. I use it in conjunction with WCTRL http://www.burri-web.org/bm98/soft/wcctrl/index.htm, but it will work by itself. Wctrl, just lets you have really good control over your camera settings and allows easy saving of them.
-------------------- Randy
Edmund Astroscan
Meade ETX125PE
Celestron C6R/CG5
Orion ST80/Mini EQ1
Tasco Starguide 114/Celestron Hand Paddle
Pentax 10x50 Binoculars
Philips SPC 900NC
Stellacam EX
6 registered and 6 anonymous users are browsing this forum.
Moderator: Charlie Hein, knuklhdastnmr
