Astrophotography and Sketching >> Beginning Imaging
cnstarz
Reged: 12/22/07
Loc: Kentucky, USA
Processing GIMP IRIS ? new
      #2529306 - 07/19/08 11:51 PM
Well I've just started imaging using a first gen DSI color camera. I'm using a really low budget setup and in that spirit I need to develop my processing suite. I've installed GIMP and IRIS and feel that going with no cost software is the way to go for me right now... Any other must have tools that you know about that are GNU or freeware?
Matt
Apogee 50mm BB scope
ETX-60 BB
Meade 70-az
5" DIY Newt (wip)
C6-N on CG-4 GEM
Gallery
Charlie B
Reged: 03/22/08
Loc: Virginia
Re: Processing GIMP IRIS ? new [Re: cnstarz]
      #2529711 - 07/20/08 09:00 AM
You might want to get Deep Sky Stacker.
Charlie B
Meade SN-8, DS-90, AT-66
DSI Pro II (Schuler Filters), DSI-C, LPI, Canon XTi
AIP4WIN, Nebulosity, DSS, Registrax, GIMP
running on Dell 1420 with Vista
Charlie B
Reged: 03/22/08
Loc: Virginia
Re: Processing GIMP IRIS ? [Re: cnstarz]
      #2529740 - 07/20/08 09:21 AM
Also, Registrax!
Charlie B
cnstarz
Reged: 12/22/07
Loc: Kentucky, USA
Re: Processing GIMP IRIS ? new [Re: Charlie B]
      #2533605 - 07/22/08 07:28 AM
Thanks for the suggestions Charlie. I've got a long way to go with learning how to use these applications. There's so much that they can do, Ive read where gimp will take PS paintbrushes. Pretty cool stuff!
Matt
ETX-60 BB
Meade 70-az
5" DIY Newt (wip)
C6-N on CG-4 GEM
Gallery
Gregk
Reged: 11/19/06
Loc: Gilbert Arizona
      #2535600 - 07/23/08 12:21 AM
Gimp is a good start although only 8 bits it has may Photosop functions...and also layer creation.
Iris has a great filter called adaptive filter for smoothing out noisy images. Also a gradient removal tool.The contrast adjustment in Iris is like a poor mans curves.gamma and light balance are also good for tweaking colors and contrast. Also saturation works well....I beleive Iris is 16 bit though.
You may want to look at nebulosity for 45.00 It captures stacks aligns filters debayers combines stretches. It drives my DSI canon Xt and SPC900 and also my SBIG ST-7 if need be.
keep asking ??
Greg
www.azspaceblog.com
Charlie B
Reged: 03/22/08
Loc: Virginia
Re: Processing GIMP IRIS ? new [Re: Gregk]
      #2536094 - 07/23/08 09:26 AM
Gimp is a good start although only 8 bits Gimp is a good start although only 8 bits
As of version 2.5, GIMP uses the GEGL (Generic Graphics Library) which is a graph based image processing framework.
It supports floating point handling and processing and output of larger 8bit, 16bit integer and 32bit floating point per component buffers larger than RAM.
The version 5 releases are not really stable, but GIMP is near version 2.6 and, when it arrives, should be much more capable.
Charlie B
nik hodges
Reged: 04/20/07
Loc: UK
      #2538487 - 07/24/08 11:54 AM
you could also look at cinepaint (16bit and free) or pixinsight very good and quite cheap
nik
Flurostar 110 [TMB]
Megrez 80mm triplet apo & mkIII FF
"LX200R" (8") with AP CCDT67 reducer & moonlight focuser
StarlightXpress SXVF-H16 camera/trutek filter wheel
DSI Pro II
AstroEngineering MegaWedge
Maxim DL/Maxpoint + adobe PS3extended
On AP900 notification list
7 registered and 9 anonymous users are browsing this forum.
Home
