4stargazers
Reged: 07/13/08
Loc: colorado
Orion 10'' reflctor on atlas eq-6 new
      #2535005 - 07/22/08 06:54 PM
orion sales a 10'' reflector on an atlas EQ-6 if it were set up for ccd with guidescope, heater, ccd, etc....Will it be too heavy for this mount? The scope is about 28 lbs, 5 lb guide scope, and everything else probably >10 lbs and the you have to add the weights for balance. The mount is only rated to 40 pounds does that include the weights?
AstroEye
Reged: 10/04/06
Re: Orion 10'' reflctor on atlas eq-6 new [Re: 4stargazers]
      #2535241 - 07/22/08 08:35 PM
I had the 10" reflector on my Celestron cg5 mount which is rated at 30lbs and it carried the weight, verily. But celestron sold the 10" on the CG5 so I guess they felt it could handle the weight. The Atlas mount is twice as heavy as the Celestron CG5 and alot more sturdy and strong. I think the Atlas mount would handle the 10incher plus accessories no problem. I thought I remember seeing somewhere where someone stated that the 40lbs is conservative for the Atlas and it could handle 50lbs.
Its a beast and with the 10incher,It will be a huge imposing sight to say the least.
Edited by scuwinger (07/22/08 08:46 PM)
dvb
different Syndrome.
Reged: 06/18/05
Loc: Vancouver, Canada
Re: Orion 10'' reflctor on atlas eq-6 [Re: AstroEye]
      #2535319 - 07/22/08 09:28 PM
I'm running this rig now. It works well for visual and video astronomy. I've beefed up the saddle with ADM stuff and a Wilcox ring.
For DSLR imaging, check out this guy's results:
http://www.nightskyimages.co.uk/
17 registered and 25 anonymous users are browsing this forum.
Moderator:  Jarad, ausastronomer, okieav8r
