AlanT
Reged: 08/20/07
Loc: 122º36' W, 47º37' N, WA USA
No room for an observatory. So....
      #2537867 - 07/24/08 12:41 AM Attachment (125 downloads)
Maybe this would be better posted in a different forum as it isn't an observatory, but I wanted to share. Maybe there is an idea here that will help someone.
I have no place to put an observatory in my yard, but I wanted the ability to leave my scopes out for a few nights in a row at times. I found that tarp type covers tended to sweat and would allow the equipment to get very hot or cold. So I decided to build a roll away shed.
The mostly finished shed is shown in the picture below. It's insulated and has 12v power which will either run a fan or small heater which are switched by a thermostat. Weather stripping around the bottom and the door panel keeps it well sealed from any wet weather. Wheels allow it to be rolled completely away, or just laid back as shown (which provides plenty of access for my needs). It's pretty light, 100 lbs or so and takes about a minute to put it up or down. There are cutouts that mate with the pier to help guide and secure it into position and a plexiglass window on the back so I can ensure it's well clear of the scopes while moving it. The only issue I've noted so far is that the front panel needs to be positioned on the box when it's laid down during the night to keep dew out of the interior.
Total cost was less than $200.
Ok, so it looks like an outhouse, but now my gear is protected and I'm pretty happy.
al
Hermie
Reged: 04/20/05
Loc: Cloudy HKG
Re: No room for an observatory. So.... new [Re: AlanT]
      #2537894 - 07/24/08 01:07 AM
Al,
I think that it still counts as an observatory! Theres less setup time than my grab and go. That is a really nice job construction-wise too.
Hermie
WidowMaker
Catchy Title
Reged: 12/29/07
Loc: Frankfort, Ky
Re: No room for an observatory. So.... new [Re: Hermie]
      #2537919 - 07/24/08 01:37 AM
I think thats realy cool, Alan!
Silly question I guess but will you be keeping it outside always?
Nice job!
kiwisailor
Reged: 01/07/04
Loc: Lyttelton, New Zealand
Re: No room for an observatory. So.... new [Re: WidowMaker]
      #2538003 - 07/24/08 04:13 AM
Absolutely counts as an observatory Al, and a nice job too
Apart from dewing of the interior with the front cover off, have you had any issues with bugs etc getting in, or is it too well sealed for creepy crawlies ?
Steve
mlcolbert
Reged: 11/15/07
Re: No room for an observatory. So.... new [Re: kiwisailor]
      #2538024 - 07/24/08 05:14 AM
is it just me or does anyone else have the image of your backyard eventually holding many such 'outhouses'. Don't ever have a party other than a starparty!
michael
StarWrangler
Reged: 09/03/04
Loc: Three Rivers, MI U.S.A>
      #2538185 - 07/24/08 09:10 AM
As one Alan to another it looks great to me,
It does the job and that is what counts.
Feel free to join and post your Observatory over at my
Flip Top & Clam Shell Observatories group.
Just click on the link below my name,
Alan O.
soreneck
Reged: 04/01/06
Loc: Toronto, Canada
      #2538274 - 07/24/08 09:55 AM
Great job! Very tidy and functional, and I especially appreciate good work done on a tight budget. Congratulations!
AlanT
Reged: 08/20/07
Re: No room for an observatory. So.... new [Re: soreneck]
      #2538495 - 07/24/08 11:58 AM
Thanks all for the kind comments.
To answer some of the questions:
Widowmaker: I expect to bring the scopes in during stretches of poor weather, and mount too during the long wet winter months. During such times I may only leave the equipment set up if we get a cold dry stretch (which happens once or twice each winter). High wind is a bit of a concern, I'm going to add some heavy bungie cords to clamp the guides to the pier if it blows really hard. If the weather turns really nasty, it's pretty easy to roll the shed to the carport.
Steve: All exterior wood is sealed and painted, the insulation is pest resistant, and the bottom seal is like a garage door seal. I expect spiders will be the main pests I'll have trouble with.
Michael: Fortunately, there won't be any more outhouses sprouting up . The pier position is in the optimum spot to see the most sky and is the only spot shaded from a nearby streetlight.
Alan O: Thanks for the link. Wish I'd known of that group before. I'm sure there are some great ideas there I'd have incorporated.
thanks again,
al
Chris Schroeder
Reged: 12/11/04
Loc: N.E. WI Sky Glow
      #2538738 - 07/24/08 02:33 PM
Well done Alan, that looks great
Starman27
Reged: 01/29/06
Loc: Illinois, Iowa
Re: No room for an observatory. So.... new [Re: Chris Schroeder]
      #2539141 - 07/24/08 05:40 PM
My grandmother used to call my observatory a "telescope house". You have areal one. Great idea and execution
Pedestal
Reged: 03/11/06
Loc: Smoggy Bottom, Baytown,Texas
      #2539184 - 07/24/08 06:09 PM
Very nifty! It appears you remove the door entirely? Any particular reason for doing that instead of hinging it?
Hubert
AlanT
Reged: 08/20/07
Re: No room for an observatory. So.... new [Re: Pedestal]
      #2539284 - 07/24/08 07:05 PM
Right, I do totally remove the front panel.
I was going to hinge it, but ran into a couple issues. Because the ground is sloped, I would have to mount the door so it would swing to the right (when looking at it). I got to measuring real close and found it was touch-and-go whether the door would clear a nearby hose spigot.... Then got to worrying about getting it mounted just right so the bottom rubber would slide across the concrete yet still seal well.
My wife got tired of hearing me hem and haw and suggested just making the door removable. So that's what I did. There are two 1/4" bolts that stick out of the frame near the top that align with mating holes in the door, and 4 draw latches to pull it up agains the seals. Getting it on and off is a breeze.
I think I'd like hinges better though. If I can find suitable bottom seal material/design, I may dig out enough of the slope to allow me to mount the door to swing left which would be best. But for now, it's easy enough.
al
Chris Schroeder
Reged: 12/11/04
      #2539356 - 07/24/08 07:35 PM
Your design probably helps keep the whole thing square and as you said, seals better.
dgs©
Reged: 03/29/04
Loc: West Monroe, Louisiana
      #2539357 - 07/24/08 07:35 PM
Reminiscent of the Observalavatory.
Seen here with the door closed displaying the nifty logo.
DeanS
Reged: 07/12/05
Loc: Central Kentucky
Re: No room for an observatory. So.... new [Re: dgs©]
      #2539443 - 07/24/08 08:19 PM
Nicely done! Simple design and quick to set up which is the key to any observatory.
o1d_dude
o1der than dirt
Reged: 10/03/07
Loc: The Wolfpack
Re: No room for an observatory. So.... new [Re: DeanS]
      #2539506 - 07/24/08 08:51 PM
Excellent idea!
All you lack is a crescent moon painted on the door to complete the outhouse look.
David PavlichAdministrator
Transmographied
Reged: 05/18/05
Loc: Mandeville, LA USA
      #2539527 - 07/24/08 09:02 PM
Very nice! Ya' gotta' love innovation.
David
Oly Olson
Reged: 02/17/08
      #2543473 - 07/26/08 11:34 PM
I think that's simply outstanding! Really nice job.
Best,
Oly
Snow dog
Reged: 07/17/05
Loc: Alberta Canada
Re: No room for an observatory. So.... new [Re: Oly Olson]
      #2543492 - 07/26/08 11:50 PM
Very nice. I was thinking when I first saw it "That looks like an outhouse". Great idea and well done on the construction. Like someone else pointed out...just be careful when you have friends over for a BBQ or other party
Mike Lewis
Reged: 01/20/05
Loc: Near Mulliken, Michigan USA
      #2543774 - 07/27/08 08:08 AM
Outstanding!!!!
Well done
Best skies!
3 registered and 2 anonymous users are browsing this forum.
Moderator:  csa/montana, Chris Erickson
