drexelpbp
Reged: 01/21/08
Loc: Phoenixville,PA
Need some advice!! new
      #2542357 - 07/26/08 10:41 AM
Hi
I just purchased a Celestron C8 on Astromart. Its the Carbon Fiber model. It arrived about a week ago. It appears to be in excellent condition - like new.
Last night was the first night I was able to use it. I found two significant problems:
(1) I could not get it to come anywhere near focus
(2) While attempting to focus the image moved all over the place.
Given that I am a complete neophyte with this type of scope I was hoping that someone could give me some advice and point me in the right direction.
Thanks for any help you may be able to provide.
Gary
werewolf6977
Lord High Smasher
Reged: 12/15/03
Loc: Hanover, Ohio
Re: Need some advice!! new [Re: drexelpbp]
      #2542517 - 07/26/08 12:39 PM
Do you have a star diagonal? They add length to the optical train. About the image moving, that's called mirror flop. What ep were you using? MIrror flop is more noticeable at higher magnification. At least that was so with my N8.
Pete
6" Apogee/LXD55 - "The Beast"
Starhopper 6" Dob - "Shiva"
Spaceprobe 130 EQ - "Spacey"
Bushnell Fatboy
The Abomination
Sun Pak Pro 7500 Platinum Edition
10X25 Bushnell Camo Roofies
7X35 Tasco Classic Plastic (good views though)
7X42 Tasco Rare Bird
10X50 Nikon Actions (Type 7)
15X70 Skymasters - "DroolMeisters"
One ratty old IBM 600E LapTop
garyc11
Reged: 11/20/04
Loc: Niagara Falls,NY
Re: Need some advice!! new [Re: werewolf6977]
      #2543341 - 07/26/08 09:54 PM
first thing i would do is check the collimation
CGE 1400
CPC 1100
MallinCam Hyper Plus Color
Celestron 100 ED
CG5-GT
Celestron C-8 Newtonion
David Pavlich
Reged: 05/18/05
Loc: Mandeville, LA USA 30.38 X 90....
Re: Need some advice!! new [Re: garyc11]
      #2543382 - 07/26/08 10:25 PM
What you are seeing while focusing is actually called image shift. It's inherent in most SCs due to the configuration of the focuser relative to the mirror.
Mirror flop happens when you slew the scope from one side of the meridian to the other. Gravity will shift the primary mirror.
One thing that you might want to do while focusing is get the scope lined up on a bright star like Vega. Then focus very slowly. I've read more than once that the only problem was observers were actually focusing too fast and going right past the focus point.
An SC has a lot of focus travel. It should focus, diagonal or not. Also, use a low powered eyepiece.
David
A few scopes and mounts.
Proud Member; PAS NOLA,
Life expectancies would go WAY up if green vegetables smelled like bacon...
sang33ta
Reged: 07/08/08
Loc: UK
Re: Need some advice!! new [Re: David Pavlich]
      #2543423 - 07/26/08 11:02 PM
DON'T PANIC!
Try focusing in your widest eyepiece (highest number). Some days when the air is bad you can't get focus, this is normal. I recommend a 40mm or 32mm for initial focus.
The moving image may just be your mount locks are not tight or your tripod/mount is too weak for your scopes weight.
Of course if it's wobbling it's gona be mighty hard to focus so these two problems go hand in hand!
Hioptic 152mm f12.5 Maksutov
Celestron Advanced CG5-GT Mount (Mr Noisy!)
Meade 4000 Super Plossl Set
Casio QV-2900UX
Got fed up of waiting for Meade ETX-150 so put this together for £500/$1000
Edited by sang33ta (07/26/08 11:03 PM)
drexelpbp
Reged: 01/21/08
      #2543431 - 07/26/08 11:07 PM
Thanks for your response Pete.
I was using an astro tech 1.25" mirror diagonal and a Baader Hyperion EP. Do you think I should try a different diagonal?
Gary
sang33ta
Reged: 07/08/08
Loc: UK
Re: Need some advice!! [Re: drexelpbp]
      #2543484 - 07/26/08 11:42 PM
Try focusing on a land object during the daytime it will be easier. How many mm is your eyepiece?
Casio QV-2900UX
Edited by sang33ta (07/26/08 11:43 PM)
0 registered and 12 anonymous users are browsing this forum.
Moderator:  Jason B
Home
