rolandlinda3
Reged: 01/24/06
Loc: Crozet VA 22932
I ran enough tests to present a few results. Some others have said they would post some photos soon. The question comes up on this forum about using astro video cameras on telescopes without tracking in order to see Deep Sky Objects...can you do it and what kind of scopes can you do it with?
My experiments have been with an alt-az mount or a tracking mount with tracking turned off. The telescope that I have worked with the most is an 80mm f/7 refractor but I believe the results are generally applicable to a host of f/7 or shorter focal length refractors from 4 inches of aperture on down to about 60mm or so.
Someone else can give their results for a typical f/10 SCT, but I do not think the results will be very good judging from my use of an early MallinCAM with the tracking on the C8 SCT turned off. Star trails were too noticeable for the scene to be worth it to me....unless the integrations are less than 1/4 second (less than 32X). I did not test where the views would be tolerable; someone else may want to do this.
While my camera was an older B&W MallinCAM, I have worked with a STELLACAM EX and regularly use a MallinCAM Hyper Color. I have seen enough results so I am quite confident that the results pertain to any of the MallinCAM/STELLA CAM series as long as one can use the shorter integation times (less than 128x or 2.1 seconds).
I always used a focal reducer; and mine was an older version of Rock Mallin's, although I have used others and I know there are several that deliver good results. Essentially, the lower the net focal ratio, the wider the field, the less star trailing one sees.
Before I give results, understand my definition of a good view on the screen: (1) very little star trailing or blurring of a nebula and (2) the view must be substantially better than a premium eye piece view with twice or three times the aperture. Otherwise, why bother?
My test objects were M92 and M8 on a night where viewing varied dramatically from average to terrible.
RESULTS/CONCLUSIONS FOR NON-TRACKING SMALL SCOPES (ESTIMATED TO BE APPLICABLE TO THOSE WITH FOCAL RATIOS OF F/7 OR SHORTER AND APERTURES OF 4 INCHES OR LESS):
1. Standard non-extended integration times (2.1 seconds or 128 frames of information integrated) are NOT suitable for deep sky objects. The trailing stars look like rectangles and, while nebula and clusters can still be discerned, the view is disconcerting to me.
2. At 64X (about 1 second integration time) the views of M8 and M92 were tolerable. 50% gain (AGC) was sufficient to get a good view; near full or 100% AGC gives you the same picture that 128X or 2.1 seconds of integration delivers but without the star trails. There is a bit of trailing at 64X but it was not that noticeable. The quality of the view for both objects was MUCH BETTER than a view I could obtain with the 12.5 inch Dob with a 22 Panoptic at the same test time and location.
3. At 32x or 1/2 second integration times, the results with 50% AGC produced a steady picture to the eye, not including the movement of the scene across the monitor, which one expects with a non-tracking scope situation. I could not detect star trailing at all at 32X. With full AGC, the view is better than the 64X view at 50% AGC. 32x or 1/2 second integration is actually very easily usable as long as the brightness of the object is enough for the camera to work with. Any faster integration is a no-brainer...it works but you lose more of the integration benefits so you see less on Deep Sky Objects.
4. Limiting magnitudes for using ALT AZ mounts with fast integration times {1 second to 1/2 second or 64X to 32x} is a question of type of object and what one wants to see. Globular clusters are generally beautiful with these integration times. While one does not see the star density or the depth when using these faster times, one still sees MUCH MORE than 4 times the aperture of scope with a good Eye Piece. That is not a guess: I went from the 80mm screen view and compared it to the 12.5 inch Dob view with the 22 Panoptic. So for primary Messier objects and other bright sky objects as defined by the TelRad books: the faster integration times still deliver much better than a lot bigger scope. Note, however, when surface brightness is pretty low for a galaxy or the nebula is pretty faint, the result, while better than an EP view on somewhat larger scope, is not going to blow your socks off.
5. Ease of use of an alt-az mounted scope with faster integration times: This is dependent on a person's ability, of course. I am a relatively recent observer (less than 10 years) and I consider the sky foreign to me except for major stars, bright objects, and significant constellations. I can star hop...sort of. After using a non-tracking mount with a Camera in place of the eyepiece for about 1/2 hour, I was pretty confident that I could find anything as easily as if I want looking through an eye piece. Furthermore, once the object was found, moving the alt-az scope to readjust the target to the center or to one side of the screen was pretty easy. The biggest problem with these smaller refractors on an alt az mount is not moving them around too quickly so you pinch or pull out wires. One does have to be a little more careful.
Bottom Line: would I buy a decent astro video camera (new or used) if all I had was an alt-az mount and a small refractor with a focal ratio of f/7 or better? For me, the answer is yes, because the view is better than what I can see with my 12.5 inch Dob with a good EP. Does the monitor have to be special or expensive? Nope. The standard B&W high resolution security monitors are available by a number of vendors for about $100. High resolution means 800 to 1000 TVL. Mine is 800 and did just fine. I have a 5 inch TV; it works, too. DVD players work too. In other words, the monitor is not a variable that makes or breaks the issue.
Bottom Line Two: Would I buy a used scope (fast and perhaps with some chromatic abberation) and a used camera? This is kind-of a worse case but not uncommon because there are a lot of relatively small refractors out there with a lot of chromatic abberation. The answer is yes, because a B&W video camera on fast integration times does not care how much CA is present...it will deliver a decent B&W picture of the object. As long as the scope has a short enough focal ratio and is somewhere between 60 and 102 mm, the picture I will see on a monitor with 1/2 to 1 second integration times and middle to high AGC will still be better than a telescope with 4 times the aperture and a real good EP. I used the STELLACAM EX on an old Vernon 80-mm f/6 refractor very successfully. It works.
Last item: how much time can you see the scene on the monitor that is showing the output to one of these cameras that is mounted on a small refractor? The answer is simple to measure and probably calculate. On my setup, side to side motion of the object (from one side of the monitor to the other) was about 2 minutes. After about 10 cycles, it was automatic...I knew how to jiggle the scope and recenter the object quickly...all while sitting and enjoying the monitor scene. If you say that you want to keep the object in the center 50% of the monitor, then you jiggle the scope about every minute.
NOW...wait for some other results and pictures from some other participants that will hopefully follow, fill in gaps, and correct any mess-ups in what I wrote...
Clear skies.
Roland Beard Crozet VA
imp_white
Reged: 12/08/06
Loc: italy
hello, Thank you for the very interesting research and finding. It would be great if there could be simillar reports with different instruments as you suggest(aperture, f/ratio).
Out of curiosity: wouldn't it be possible for you to describe also the results using your 12.5" (i don't see its f/ratio but i'd expect a f/4-f/5)? or are they so bad due to limited fov that you didn't bother with them?
thank you, iw
Chris Schroeder
Reged: 12/11/04
Loc: N.E. WI Sky Glow
Lots of good enough there Roland, thank you for posting.
-------------------- Chris
Mallincam Color Hyper Plus
10" DSH with SC DSC, CPC 800 XLT
M102ED S.V., ZS 80FD 10th Anniv, ZS 66SD, PST
POD XL3 http://POD.SchroederCity.com
rolandlinda3
Reged: 01/24/06
The f ratio for the Dob is 4.5. You can see plenty of results/sketches using the dob and the MallinCAM cameras by going to Members Galleries and doing a search on rolandlinda3 (name of gallery). There is a sketch of the Lagoon, but as expected it only covers the core region because the aperture and focal length yields a FOV that is quite a bit smaller. While the details are EXCELLENT with this combination, to use the setup unguided would be like chasing a cat after a mouse. So it is our primary scope for video use and study, but it is not the scope choice for wide field nor is it good for unguided scope applications, which is the subject of this thread. Fundamentally, narrower field of view and better light gathering generally translate to poor use for unguided situations -- even though the scope may be excellent and the camera doing what it is supposed to.
Roland
Astrojunk
Reged: 11/02/06
Loc: Australia
My results using the GstarEX on a 80mm Zenithstar (f6 I think) with everything maxed out and pointing at Omega Centauri (sorry, but it was easy to locate in my telrad). I found everything to be most 'useable' to my suprise.
-------------------- Astrojunk
20" f5 Alt Az Newtonian
Astrojunk
Reged: 11/02/06
Loc: Australia
Astrojunk
Reged: 11/02/06
Loc: Australia
Astrojunk
Reged: 11/02/06
Loc: Australia
But I wouldn't recommend it in place of a beginners 10" dob for eg which would give much more engaging results. No video camera can capture the true majestic beauty of a globular cluster or Planet the way an eyeball can - for me they only win on the fuzzies.
Astrojunk
Reged: 11/02/06
Loc: Australia
And finally, just for fun, 32x integration on the 20" dob using a 0.6 focal reducer.
rolandlinda3
Reged: 01/24/06
Excellent posting, sir. Thank you. Would you be so kind as to try get a nebula and do the same process so others can see the differences in what is picked up with the Zenithstar. Also, list your gain setting when you do it. Thanks again.
In short, you have found, like I did also, that short integration times with unquided little scopes works just fine.
Roland
ccs_hello
Reged: 07/03/04
Roland,
Nice write-up.
IMHO, star trail acceptability is depend on:
1. object taken is near or far away from the celestral pole
2. videocam's integration time
3. True FoV which is determined by OTA's focal length and the imaging chip's size
4. the monitor's display size and the viewing distance
I.e., how long the trail is less objectionable percentage-wise out of the full width of the display screen
Clear Skies!
ccs_hello
rolandlinda3
Reged: 01/24/06
All of that is true. We are trying to get some general results to steer those who keep cropping up asking the same question: can you use the cameras on unguided mounts. Perhaps you can experiment some and provide some of the boundary conditions with a scope setup to say "here is where it does not work" and show a picture to illustrate the point. Roland
ccs_hello
Reged: 07/03/04
Roland,
Here is my calculation based on worst case scenario:
Assuming a 10" f/10 SCT without focal reducer is used.
fl = 2500 mm
A type-1/2" CCD is used
Based on the above parameters, the TFoV will be
8.9' * 6.6' which is 534" * 396"
For a 2.1 second sense-up (128X), assuming an object near celestral equator is targeted, without moving the OTA,
2.1 second would cover 31.5 arc-sec trail.
Assuming CCD is mounted its narrow-side parallel to the star trail, the trail coverage will be:
31.5/396 = 7.95%
I.e., if a single star is framed and shown in the screen, it will be dragged 7.95% vertically in the screen.
P.S. the calculation does not count the field rotation.
(Note: shooting objects near celestral equator won't show field rotaion )
Clear Skies!
ccs_hello
rolandlinda3
Reged: 01/24/06
That is good. Now translate that to guidance that is good for a newbie....size scope and f/ratio that (with a camera at 2.1 second or less) will yield as picture that is not unpleasing to the eye, not full of star trails, etc. If you have some real examples that illustrate your precision so a reader can interpret it in terms of relatively common types of smaller scopes (perhaps some that you have tried at the shorter integration times), that would be great to add to the others.
Roland
ccs_hello
Reged: 07/03/04
Roland,
I'll give it a try.
First, view the APOD form NASA site:
http://apod.nasa.gov/apod/ap060915.html
Multiple pictures over there in the links with different exposure time, longer exposure has a long dragging trail, while 2.1 second "not so long" exposure generates some almost undetectable star trail in a wide-angle shot.
Near the North Celestral Pole (NCP), the stars move less on per unit of time, while near celestral equator, the stars move faster.
A star located exactly on the Celestral Equator will turn 360 degrees (1296000 arc-second) in a sidereal day (86164 seconds). This translates to a 15.04 arc-sec/sec velocity. A 128x sense-up videocam is a 2.1 second long-exposure imaging session. During that period, the star would have moved 15.04 * 2.1 = 31.58"
Now I use the "CCD Calculator" software, plug-in OTA's focal length and the imager's size, I will now know the area of sky it can cover. It is like drawing an imaginary box in a star trail photo. A long focal-length OTA with a smaller-size imager will have a smaller sized imaginary-box (TFoV), while a short focal-length OTA with a focal-reducer added will have a bigger imaginary imaging box.
This is how I estimate the impact of the star trail. This is the same method used in long-exposure videocam as well as in long-exposure astrophotography. The Earth's rotation is the culprit, not the imaging devices . The latter cannot do any magic in a non-tracking mount nor can it stop Earth from rotating .
Clear Skies!
ccs_hello
nytecam
Reged: 08/20/05
Loc: London UK
Hello Roland - did an experiment last May via my 30cm SCT @ f/2.9 in static mode on M51 undriven in 3.6s exp eg 12 x 0.3s
-------------------- Nytecam 51N 0.1W
Meade 30cm LX200+ETX-70+DS-2090+C8+Ha+CaK PSTs SBIG SGS+homebuilt spectrographs
Starlight SXVF_M9/Lodestar/Canon 300D DSLR/Fuji E550
My observatory build-ETX-70 imaging-spectro page
rolandlinda3
Reged: 01/24/06
Thanks very much. Nice shot. Having a "fast" scope does make quite a difference. Roland
imp_white
Reged: 12/08/06
Loc: italy
Anybody maybe has any samples for medium/big size fast mirrors?
For example I'd be curious for both something like 10" at f/4.7 and 16" f/4.5. Of course eventually with a focal reducer on it aswell. Would it make any sense to use an unguided videocam on such setups? At which timings and eventually to which aperture the results may be comparable?
rolandlinda3
Reged: 01/24/06
My 12.5 inch at f4.5 shows too much star trailing but your 10 inch might do OK. Perhaps someone else has tried an unguided but reasonably fast 10 inch??
Roland
rolandlinda3
Reged: 01/24/06
On second thought, if you can experiment, try either one but raise the gain to more than 50% and start at approximately a 1/4 second then expand the time until you get where star trailing detracts. Then go back, raise the gain a little more (75% or so) and do the same until either trailing looks bad or the camera screen goes white (too much saturation so the MallinCAMs have a safety feature so the screen goes blank white). If I have chance with the Dob next time, I will pick and object and do the same to report the results. Roland
