Privacy Policy |
Please read our Terms
of Service | Signup and
jrw11
Reged: 06/09/07
Loc: U.S.A.
I have an old pair of 7x50s. The eyecups are hard plastic and with my eyeglasses looking thru them is like looking thru a pair of 30 -35mms. Is it possible to purchase a set of soft rubber eyecups that can replace the old ones?
-------------------- Celestron C6n -HD Reflector
dual axis drive motors added
Orion 80mm Short tube refractor
Skyscout
Early 70's Pentax 7x50
Garrett Optical 12x60
Garrett Optical 15x70
Oberwerk 20x80 Standards
Canon Rebel Ti (film)
4 Minolta Srt cameras
Mamiya RB67 Pro-s with 180 lens
127mm KL lens for RB, Bellows hood for RB67
120 and 220 film backs
Cambo SCII 4x5 view camera
over 50 other film cameras
several eyepieces
Tarnsman
Reged: 02/12/06
try a search on ebay of ... minolta a2 eyepiece....they might work
jrw11
Reged: 06/09/07
Loc: U.S.A.
thanks!
Skyscout
several eyepieces
Gordon Rayner
Reged: 03/24/07
Try some O-rings (hydraulics, automotive, plumbing, etc), if all else fails.
jrw11
Reged: 06/09/07
Loc: U.S.A.
Thanks for the suggestions. I was thinking of replacing the old eyecups for rubber ones that can be screwed on. As, the old ones are.
Skyscout
several eyepieces
EdZ
Professor EdZ
Reged: 02/15/02
What diameter inside the rubber pullover woud be needed?
Orion sells an assortment of rubber eyeguards
Orion Eyeguards type keyword Eyeguards
SEE ALSO
Eyeguards and binocular caps at scopestuff
Eyeguards at Scopestuff and Orion sell for $2.95 to $3.95 each
At Edmund they sell for about $6.95 to $8.95 each
Edmund scientifics online eyeguards
Oberwerk sells replacement eyecups. Inside dia is 37.5mm (1.5").
OberwerkParts List
same eyecup as found on regular Oberwerk 15x70
edz
jrw11
Reged: 06/09/07
Loc: U.S.A.
Edz, When the hard plastic eyecup is screwed off, the threads around the eyepiece is about 30mm, maybe 29. They are the old Pentax 7x50s that have the gold coating.If i can replace them with flexible rubber ones. It might be easier to use with my eyegasses. Thanks!
Skyscout
several eyepieces
EdZ
Professor EdZ
Reged: 02/15/02
appended here from a post by Stan,
In the past there has been inquiries about replacement eyeguards. Today I received a catalog from ANCHOR OPTICS, a divison of EDMUND OPTICS, which contains a variety of rubber eyeguards.
I am posting the link for those who still may be interested in a reputable source.
http://www.anchoroptics.com/catalog/product.cfm?id=195
http://www.edmundoptics.com/onlinecatalog/displayproduct.cfm?productID=2064&search=1
-------------------- Teach a kid something today. The feeling you'll get is one of life's greatest rewards.
member#21
mercedes_sl1970
Reged: 12/02/05
Loc: Canberra, Oz
If all else fails, you could make a pair out of a section of bicycle inner tube. I did this for a while for a missing eyeguard on an old binocular until I made a replacement. It's not the most elegant solution but worked. Just cut a length, say a little longer than double what you want, fold it back on itself to get a smooth edge and then stretch on. Et voila!
Andrew
12 registered and 21 anonymous users are browsing this forum.
Moderator: EdZ
