Ptarmigan
Reged: 09/23/04
Loc: Arctic
I am interested in building a barndoor tracker. I did some research on barn door trackers and notice there multiple variants of them. One is the double-arm drive. http://hometown.aol.com/davetrott/page17.htm http://education.jlab.org/tracker/
Here is a single arm barn door tracker. http://www.jlc.net/~force5/Astro/ATM/Barndoor/barndoor.html
What is the difference and advantage and disadvantage?
-------------------- Ptarmigans=Cute and Cuddly
Meade Starfinder 8
Nikon 10x50
Rebel XT
NeoDinian
Experienced Postmaster
Reged: 10/05/05
Loc: Rockford Illinois
The double arm (or Tangent Arm Mounts) are supposed to be accurate to about 45 minutes when aligned properly, but they take some precise measurements to make them. I actually have a type-4 (Trott) in the basement I tried making years back (Same article you link to). It's STILL not completed!
A normal barn-door has issues beyond about only 4 or 5 minutes, because as the threaded rod gets longer, the angle is increasing slower. People have overcome this by making a CURVED bolt tracker. Same concept as the standard barn-door, but the rod is curved to the radius of the tracker. Now, as you turn the nut on the rod, it lifts the arm at the same rate, throughout it's travel.
So for making a barn-door, the best (and EASIEST) route would be the curved bolt tracker.
There was a great article on them in an issue of (I believe) S&T a while back.
Do a search in this forum (and the DSLR forum) for "curved bolt", and you'll even find a nice build here.
-------------------- Neo... (Jeff)
10" LX200-GPS/SMT UHTC "Draco"
Rockford, Il.
NeoDinian's Eye on the Sky!
Coming soon:
huckabuck
Reged: 02/18/07
Loc: statesboro, ga
the write-up jeff is refering to was written by member extrodinar Clownfish(Peter kennett) in the film astrophotography forum. it's under the sticky best of film astrophotography - start here about 2/3's of the way down
NeoDinian
Reged: 10/05/05
Thats the one.
Rockford, Il.
Coming soon:
s58y
Reged: 12/12/04
Loc: Eastern NY
With DSLRs (or CCD cameras), I wonder how important being able to go for 5 or 10 minutes is? When I was using a barndoor (waiting for the G-11 to ship), I had enough problems getting good tracking with a 300mm lens for 2 minutes, so I just used an extra-large single-arm tracker. With DSLRs, isn't it easier to stack a bunch of short 2-minute subs? I did shoot at f/2.8 so 2 minutes was a reasonable subexposure length given the level of light pollution.
-------------------- Hutech 30D, SBIG ST-402 autoguider
SV80S, TV102iis
Old camera lenses: 800mm f/5.6, 180mm f/3.4
AP900, Barndoor tracker
http://www.pbase.com/s58y
Patrick
Reged: 05/16/03
Loc: Franklin, Ohio
Yep! You can collect an amazing amount of light in 1 or 2 minutes at f2.8.
Patrick
10" f/6 Truss Tube Newtonian
Celestron C6S-GT SCT
AT66ED Refractor
Oberwerk Ultra 15x70 Binocular
475B Geared Tripod & 501HDV Head
Celestron Regal 8x42 Binocular
Canon XSi; Meade DSI;SPC900-NC
Vixen GP2 Photo Guider Mount
My Astronomy Pages
NeoDinian
Reged: 10/05/05
If you have superb dark skies, why not take advantage of them.
Of course, with average skies, yeah, stacking multiple subs is best.
But either way, the curved bolt tracker is still simple to make.
Rockford, Il.
Coming soon:
Ptarmigan
Reged: 09/23/04
Loc: Arctic
I read in Terrence Dickinson's The Backyard Astronomer's Guide latest edition that you can get deep exposures in 15 minutes with a DSLR, compared to film in 80 minutes. You can get more stars in a shorter time with a DSLR than film camera. 2 minutes with a DSLR camera will record more than film. I don't see why it would not hurt to stack a bunch of 2 minute exposures. In my opinion with a DSLR or CCD camera, I think 5 minute should be good. With darker skies, even better.
Meade Starfinder 8
Nikon 10x50
Rebel XT
Edited by Ptarmigan (08/02/08 09:23 PM)
Adrena1in
Reged: 09/02/07
Loc: Hampshire, UK
Don't forget though, you might be able to go nicely to 2-minutes with a single-arm Barn Door Tracker, but between each shot you're still going to need to reset the arm and adjust the whole rig, ready for the next shot.
I was considering making one for myself, just for a bit of fun, and when I'm away from a power-source for my EQ-5 mount. I'd rather go with a two-arm setup at first I think, or a whole new mechanism which I've just thought of...
-------------------- Phenix 102mm f/5.9, Phenix 127mm f/9.5 and Orion ST80 f/5 refractors on EQ5 with GOTOStar
Phillips SPC900NC, Meade DSI-C, Canon EOS 450D with 18-55mm IS, 28-105mm and 75-300mm plus 2x TC
lukasik
Reged: 10/11/05
Loc: Lawrenceville, Georgia
As Jeff said above, a curved rod tracker is pretty easy to make, and can work pretty well. So far I've managed 3 minute widefield exposures with no trailing. I can track for over an hour without re-setting.
Bob
NeoDinian
Reged: 10/05/05
And as long as your nut (On the bolt) is not permanently attached to the motor, resetting takes very little time... I can spin a nut on a bolt real fast...
Rockford, Il.
Coming soon:
Ptarmigan
Reged: 09/23/04
Loc: Arctic
I want to motorize, not turn it manually because I might be doing some starwatching also. I just don't want to turn it manually and somehow forget about it by mistake. Also, I have a zoom lens that can go up to 300 mm. S58y used telephoto lens with a barndoor tracker and came out well in just 2 minutes. He did take a bunch and stacked them with great results.
Edited by Ptarmigan (08/05/08 04:17 PM)
s58y
Reged: 12/12/04
Loc: Eastern NY
I'd definitely recommend a motorized barndoor.
I tried a hand-powered barndoor at 200mm, but at that focal length, I got only about 10% yield, without big tracking problems. At 300mm, I think you'd have to keep turning the handwheel every couple of seconds (or even faster) for good tracking.
Also, it's best to be nowhere near the camera when shooting, to avoid shaking the whole setup (I was shooting from a deck, sometimes). In the winter, it's best to stand inside during each 2-minute (or so) subexposure, and go out only to reset the mount. In my case, I could do two 2-minute subs before resetting the barndoor once every 4 minutes or so.
SV80S, TV102iis
Ptarmigan
Reged: 09/23/04
Loc: Arctic
I found another plan for barn door tracker.
http://massapoag.org/astro_2/Equipment/Barndoor_Tracker/Barndoor_Tracker.html
I wonder what RPM speed would be used for a telephoto lens like 180 mm or 300 mm?
Meade Starfinder 8
Nikon 10x50
Rebel XT
s58y
Reged: 12/12/04
Loc: Eastern NY
It looks like the design there had a 1RPM motor, since it used a 1/4-20 divescrew and had an 11.43-inch arm.
When I used a 300mm lens, I needed an double-sized arm (for better periodic eror), and then had to use a 2RPM motor.
SV80S, TV102iis
Ptarmigan
Reged: 09/23/04
Loc: Arctic
Thanks for your reply. I remember reading that a curved rod is comparable to a double-sized arm.
Meade Starfinder 8
Nikon 10x50
Rebel XT
N6VMO
Reged: 10/15/08
Loc: Lompoc, California
I have started gathering parts for this 'Barn Door Tracker.
The author included a parts list and sources too...
Barn Door Tracker
-------------------- Zhumell 8" Dobsonian
Celestron FirstScope 3" Dobsonian
17mm and 8mm Baader Planetariums
http://www.n6vmo.com
