George Methvin
Reged: 01/30/06
Loc: Central Texas
EON 120mm apo next to Meade 127mm Achromat
      #2552173 - 07/31/08 10:13 AM
I have owend most types of scopes but until this past month I had never owend a Apo refractor. There is so much talk from Apo owners about how much better they are then the Achromats but I always wonder how much better. Now I owned a very good Meade 127mm Achromat and when Orion came out with a 120mm APO for just $2000.00 I went for it. Now the question is how much better is the 120 apo then the $400.00 127mm achromat, was there going to be a WOW affect would the images in the 120mm apo be $1600.00 better for visial use's then the 127mm Achromat, it was time to fined out. I set the scope up one evening side by side and let them cool down. Frist let me say the Orion 120mm apo is one fine looking scope shorter and a little lighter then the Meade 127mm, the meade scope is also a fine looking scope. Star testing both scopes showed they were right on the money the apo had the cleaner rings in and out of fouses. Turning both scope on M13 I frist looked throught the APO the image in a 6mm eyepeice was very nice I used a 8mm eyepeice in the 127mm achromat the view was also very nice I could not tell much different in eather one. Next was the moon using a 20mm eyepeice on both scopes the view were very sharp and detailed neather scope showing more detail then the other. Going to a 6mm eyepeice in both scopes I noted the 120mm apo image was very clear and sharp with no false color what so ever. The 127 image was also sharp but with a slight bit of false color but still the 120mm apo was showing no more detail then the 127 Achromat both scopes show very nice images of the moon even when using a 2X barlow the images in both scopes stayed sharp just dimmer. Spending the rest of the evening viewing through these two fine scope was a lot of fun the 120mm Apo showing the wider fields and no false colors but the 127 was right there. So which did I keep, I sold the Meade 127mm achromat to a guy for $250.00 not because it was not as good as the 120mm Apo but because I do not need two refractor and because I like the look and the feel of the 120mm apo and because the 120mm apo is a very good scope plus now I can say I own a APO. Now to the $2000.00 dollar qustion is the 120mm Apo images that much better then the 127mm Achromat in my mind NO but thats me,are the images $1600 better then the 127mm Achromat again NO not to me. There was no WOW factor no magic just two good scopes. Now this is how I see it others my disagree and I am sure they will. I am not running down APO scopes just trying to let people have a little more info as to how they might want to spend there money. For $2000.00 you can buy a nice 127mm achromat with mount and eyepeices for the price of just the 120mm APO OTA. The best thing you can do is try to view through both types of scopes and judge for yourself. Hope this has been of some help to anyone out there.
Edited by George Methvin (07/31/08 12:53 PM)
Eddgie
Reged: 02/01/06
Re: EON 120mm apo next to Meade 127mm Achromat new [Re: George Methvin]
      #2552234 - 07/31/08 10:39 AM
I am not at all surprised by your findings.. Too bad you sold the 127, because I would have shown you one area where the 127 might have been SUPERRIOR to the ED scope.
THe ED scopes tend to use less expensive ED glasses that reqiure steeper curves to provide the best on-axis color correction. As a result, if you try to make these scopes fast, the off-axis performance starts to suffer. They will show astigmatism (assuming that you are using extremely high quality wide field eyepieces) at very low powers.
The Achromats tend to use shallower curved lenses of similar curvature. As a result, the field is much flatter and almost totally free of astigmatism.
Over on the Mak-cass forum I think I was pretty much treated as a crank when I told a guy that was wanting input on comparing an 8" SCT to a 6" achromat and I told him that I thought that if he could tolerate the mount requirements, I thought a 6" achromat might be a better all-around choice.
Of course people laughed and said that the "False Color" would make the telsescope unenjoyable to use.
What patent nonsense! In most observing, it is meaningless. In planetary observing, while it is not astethically pleasing, as you yourself have seen, it doesn't really detract from the amount of DETIAL that you can see. Oh, I mean it does, but the difference is VERY subtle.
I have owned both 4" achromats and 4" APOs, and 6" achromats, and 6" APOs, and in the end, the difference in MOST REAL WORLD PRACTICAL VISUAL OBSERVING is very very small. Mounting aside, I would rather have a 6" achromat than a 4" APO if you made me choose one over the other as an "Only" scope.
And as for the off-axis performance, the old fashioned 6" f/8 can be a surprisingly enjoyable telescope to use when coupled to something like a 35mm Panoptic or 31mm Nagler.
Thanks for your report. Not surprised at all by your observations.. They are 100% consistent with mine.
That being said, the more discerning an observer gets, the more natural it is for them to want to improve the image. Sometimes this improvement is very very expensive.. The analogy I use is the difference between a High end Harmon Kardon receiver and a McIntosh component system. One does everthing so well that most people could be contented the HK for a lifetime.. But some people will want those subtle improvements that further enrich their experience. Who can say that the value of the Mc equipment is not worth the 5 or 6 times higher price tag?
But the bottom line is that someone that can't afford a $2000 APO shouldn't feel that they are being greatly deprived is the only thing the CAN afford is a 5" Achromat...
Enjoy your new scope.. They are beautiful.
George Methvin
Reged: 01/30/06
Loc: Central Texas
Re: EON 120mm apo next to Meade 127mm Achromat new [Re: Eddgie]
      #2552353 - 07/31/08 11:33 AM
I agree with you, you lose very little with a good Achromat refractor if well made.
Clive Gibbons
Mostly Harmless
Reged: 05/26/05
Loc: Oort Cloud
      #2552427 - 07/31/08 12:04 PM
Which ED scopes are you referring to, Eddie?
Eddgie
Reged: 02/01/06
Re: EON 120mm apo next to Meade 127mm Achromat new [Re: Clive Gibbons]
      #2552496 - 07/31/08 12:36 PM
My comment was general. Not referring to a specific ED scope in that particular posting.
However, my own exoerience was that f/7 ED DOublet sold in the 80mm Celestron and 80mm ED Orion scopes were not very sharp well off axis.
Since writing a review on my Televue 101, I had a guy with a High End telescope that used ED glasses contact me. I won't say the manufacturer, but it was a 140mm F/7. You can figure it out from there.
He was somewhat concerned because after reading my telescope review on Buffy (my 6" AP), he became much more aware of the off axis abberations in his own premium ED scope. He had owned some premium 4" scopes in the past (A slower premium Japanese made doublet) and to his recolletion, that scope was sharp to the field stop. He was contemplating ordering a larger scope from the same vendor, but started to have doubts.. He was worried that if the 140mm f/7 scope was't razor sharp off-axis, that the larger ED scope wouldn't be either.
Before buying a Televue 101, I called Stellarvue about the f/7 ED Doublet and I talked to the owner. I had asked him if he had tried the 31mm Nagler in his 4" f/7 to see how it performed off-axis.. He said no, he had not.. He then stated that if off-axis performance WAS important, I might consider his much more expensive APO. Hmmmm.
So, my direct experience with the Celestron 80mm f/7.5 (or whatever it was) was that they are not sharp at the edge of a 31mm Nagler field.
Making a fast scope with a flat, astigmatism free field is very difficult. APs arent' cheap, and there are numberous reasons why this is true. But if you are extremely discerning, you start to appreciate that the center 10% of the field is easy to get pretty.. It is the rest of the field that is more challanging.
So, my DIRECT experience was with a Celstron 80mm ED scope. My Email from the 140mm ED owner tells me I was right to pass on the 4" f/7 scope.
But hey, this is me. Buffy was an eye-opener to me. The field in a 31mm Nagler is GLORIOUS. YOu would have to see it to believe it. The stars even at the very very edge of the feild are just about as perfect as they are at the center of the field.
Even the Telveue 101 isn't as sharp at the EXTREME EXTREME edge of field as the AP is.. In fact, no telescope I have ever owned has been as sharp at the edge of the field as Buffy. None... It is remarkable to see. I literally gasped the first time I looked at the double cluster in this scope.
So, f/7 ED doublet in my book is pushing the envelope. To get good color correction at the center of the field, my guess is that they have to live with field curvature and astigmatism at the edge of the field.
My guess though is that a lot of people are delighted with theirs. I admit to being more anal or "Compulsive" than most people. So for me, I had to spend more to be happy... Maybe it is a curse.. Maybe not... I sure don't see it that way... LOL. But I had owned a Genesis years ago, and it was extremely sharp at the edge of the field. The Celestron by comparison was poor at the edge of the field. Heck, starting from 70% out.. If you want to call that the edge of the field.
Now to be fair, unless you are using an eyepiece like the 31mm Nagler, the field may not be wide enough for you to really see this. Someone using their f/7 ED scope with a 24mm Panoptic may never notice it.
Of course now the tradeoff is that they can't match the bigger, slower scope in terms of true field...
Which is how we got were we are when I said that the 127mm Achromat might have given better off axis performance than the 120mm ED scope...
Regards.
Clive Gibbons
Mostly Harmless
Reged: 05/26/05
Loc: Oort Cloud
      #2552572 - 07/31/08 01:26 PM
OK, thanks!
deSitter
Still in Old School
Reged: 12/09/04
      #2552887 - 07/31/08 04:24 PM
The 120mm was fortunate to keep up with the 127mm if it is like all the examples I've heard of, including mine. Other than color correction, I can't see how any 5" scope could beat it. It is super-high contrast, extremely sharp.
The 120mm does look to be very well made. If I were looking for a 5" refractor, I would probably assume the Meade was no good just because it is so inexpensive.
=drl
HandyAndy
Reged: 01/11/08
Loc: West Midlands and around
      #2552905 - 07/31/08 04:32 PM
I am contemplating filling in the gap between my 60mm F5 Pentax spotter and my MN78 with a 90mm and 127mm refractor as you have convinced me of the wide field experience I can expect.
Should I be looking at the AT 127EDT, the 5" F8 Astrozap or the 5" F5 Petzval Astrozap?
At 90mm there are the AT90EDT, SV 90 or the WO Megrez 90.
I have a 55mm Plossl and a 31mm Aspheric Hyperion as my widest field eyepieces. What would you reccomend for each scope?
Cheers. Andrew.
George Methvin
Reged: 01/30/06
Loc: Central Texas
Re: EON 120mm apo next to Meade 127mm Achromat new [Re: deSitter]
      #2552906 - 07/31/08 04:32 PM
The Meade 127mm I owend had very good optics the views were outstanding and on most objects view color free. Only on the moon and planets at high mag was there a hint of color. Very sharp scope.
Edited by George Methvin (07/31/08 04:39 PM)
Luigi
Reged: 07/03/07
Loc: MA
      #2552950 - 07/31/08 05:00 PM
In comparing ED and non-ed doublets in the daytime, I find ED scopes generally show better contrast images at high powers. The CA reduces contrast on find detail. I have not really looked at this on the night sky.
warf
Reged: 10/25/04
Loc: Wisconsin
      #2552997 - 07/31/08 05:23 PM
So if one were looking for a 5 or 6 inch Achromat, in your opinion what would be your top 3 to consider?
Eddgie
Reged: 02/01/06
Re: EON 120mm apo next to Meade 127mm Achromat new [Re: HandyAndy]
      #2553031 - 07/31/08 05:37 PM
I have not owned either of the scopes in question. I can only provide my thoughts.
The Petzval design is a proven way to get excellent field sharpness. Televue and Vixen have both used this design to great effect. My Vixen 140 was sharp to the edge of a 31mm Nagler.
That being said, they are extremely sensistie to collimation errors.. And none of them to my knowledge can be re-collimated by the owner. Ouch...
The Petzval may also offer slight improvements in color corretion. Typically, the front element is something like f/10 or f/12 and the back element is like a built in field reducer. Mostly, whatever corretion the front element gives is what you get at the back.
The other drawback though is some contrast loss because of the rear elements. My Vixen (Older) Vixen 140 did not use advanced coatings on ALL of the optics. The light throughput seemed a bit low, and around bright targets (Plantes) there seemed to be a bit more scatter than doublets.
One factor would be what kind of eyepiece you can plug in. If you can afford a really superb eyepiece like the 26mm Nagler, that might be a stunning combo in the Petzval. But if you can't a lesser eyepiece may be challanged by the steep light cone. In other words, you get a scope with a sharp field, but an eyepiece that can't bring it to focus.
If you can put a 35mm Panoptic on the f/8, you come close to the same field as you are getting on the f/5.
So, hard choice. Both have merit.
I don't know the AT 127 scope, but if it is one of the faster (f/7) ED scopes, I would not buy until you have someone with picky tastes tell you how sharp it is off axis with something like a 31mm Nagler. I do not think that these scopes can generate the same extreme off axis sharpness that the other choices might give.
TV 55mm Plossl is a great eyepiece, but the giant exit pupil causes a lot of sky brightness. Better to go with a sharp 30mm to 35mm 68 degree design or a Nagler or Panoptic in ANY of these scopes.
This is an interesting topic to me though because everyone seems obsessed with tiny bits of color on in focus stars at the very very center or the field, but from where I Sit, they seem to ignore the other 90% of the field, and I am learning that THIS is where the action is for a LOT of small scope targets.
Anyway, back to your question.. If the quality is good, I think that the 5" f/8 and a good widefield eyepiece is the way to go here. Simple, light, good wide-field performance, no worries about collimation, and CHEAP... You DON'T need and APO to do good widefield observing, and in fact, a fast one with bad off-axis performance will be be less rewarding to use in this manner than the achromat.
These are my opinions though... But given those choices, I would go with the 5" f/8. Sounds like you already have the mount for it, and you don't need a planetary scope becuse well, heck... You have a MN78... Hard to do better than that...
Regards.
Regards
Jan Owen
Reged: 02/12/06
Loc: Sun City West, Arizona
      #2553181 - 07/31/08 07:08 PM
As I've said several times before, I'm quite happy with my EON 120, and it has delivered BETTER performance than I expected...
But right now, I'm suffering from severe cabin fever, awaiting the end of the Arizona monsoon/summer heat... It's over 115° outside right now (just came in from being out IN it for about 45 minutes, and it isn't pretty)... As much as I'd like to resume testing, I'm NOT putting a telescope out in THIS...
I've done visual observing, star testing, and artificial star testing on my EON 120, however, and I'll say again, while it certainly is NOT an AP, TEC, or Tak, it IS quite good in it's OWN right, and offers plenty for the money...
I'll fill in more blanks when the weather becomes more tolerable... I plan to do more star testing, more artificial star testing, Ronchi grating testing, and, most important, still more visual observing... So LOTS more to talk about in another month or so...
I calls 'em as I sees 'em, so you'll ALL know what the results are, as soon as there ARE more results from here.
In the meantime, like everyone else, I just watch what OTHERS have to say...
Have FUN!!!
Me, I'm sitting in front of a fan, cooling down from being outside... ACK!!!
Jan
Rich N
Reged: 09/22/04
Loc: San Francisco Bay Area, Calif...
Re: EON 120mm apo next to Meade 127mm Achromat new [Re: Jan Owen]
      #2553423 - 07/31/08 09:19 PM
IMHO, Jupiter is one of the best natural test targets for comparing refractors. You need to have them side by side because seeing can change so much from night to night and so can your memory.
Jupiter has a wealth of low contrast detail. If the seeing is very good, Jupiter is a fun challenge.
Rich
Jan Owen
Reged: 02/12/06
Re: EON 120mm apo next to Meade 127mm Achromat new [Re: Rich N]
      #2553513 - 07/31/08 10:02 PM
I have no intent to compare the EON to, say the quasi-vaporware Meade 127 triplet that I waited 2 years for...
My testing will be just to satisfy myself around how good (or not) the EON is, and I already have a pretty good idea, so it would take something pretty unexpected to change that opinion at this point...
But I probably WILL inevitably do some side-by-side testing of the EON 120 versus my Brandon 94... Obviously a mismatch, but since I HAVE them both, and plan to KEEP them both, it's a natural to do... Could be interesting; or it might be interesting only to me...
Jan
Rich N
Reged: 09/22/04
      #2553614 - 07/31/08 11:12 PM
Meade had a 127mm triplet 10 years ago. The reports I've read about the 120mm EON have been very positive. I look forward to trying one under the stars one of these days.
Jan Owen
Reged: 02/12/06
      #2553661 - 07/31/08 11:42 PM
Hmmm...
I remember the Meade ED 127 doublet (nice scope, even today), but don't recall a triplet, until the ill-fated one that never quite happened (except in Europe and a few that were rebadged as AstroTech)...
Jan
Edited by Jan Owen (07/31/08 11:49 PM)
Rich N
Reged: 09/22/04
      #2554219 - 08/01/08 10:02 AM
You're right. My memory must be slipping.
George Methvin
Reged: 01/30/06
Loc: Central Texas
      #2554311 - 08/01/08 10:52 AM
All I was saying was that the EON 120mm apo is a very good telescope very sharp and color free and I am very pleased with it. The Meade achromat was also a very good telescope and in side by side views the images were a bit more pleasing and cleaner in the EON 120mm apo then the 127mm meade achromat but I was still seening about the same amount of detail in both scopes. Was the views in the EON 120mm apo $1600 dollar better then the 127mm achromat, that for each person to judge for there self. The views were better in the EON 120 but to me not $1600 better. If money is not problem for someone then I say get the biggest and best APO out there but if you have a limited income you may want to compare the views through each scope for yourself to see what each scope will show . You may find you can stand a little false color in a cheaper achromat and save yourself a thousand dollars or the false color may drive you nuts in which case you may need to put out more cash for a good Apo telescope. We live in a great time we have so many choices....maby thats the problem we have to many. Remamber there are no magic telescopes just magic moments at the eyepeice on a clear dark night.
Edited by George Methvin (08/01/08 11:39 AM)
HandyAndy
Reged: 01/11/08
      #2554909 - 08/01/08 04:19 PM
Here in the UK I can Buy a Telescope Service 127mm F9.45 OTA for £395 and I have a Vixen GP2 to mount it on or a Bresser 127mm F8 with a Mon2 mount for £469.99.
Would you agree the F9.45 would be better?
Cheers. Andrew.
27 registered and 40 anonymous users are browsing this forum.
Moderator:  Scott in NC, Bowmoreman, KWB
