Lunatiki
Reged: 08/07/05
Loc: Amarillo, TX
Jupiter w/entire Europa transit 08-01-08
      #2553746 - 08/01/08 12:36 AM Attachment (27 downloads)
I'm shooting numerous sequences tonight. This is the best result as of now. I have some from earlier in the evening showing the GRS rotating into night that I'll post later. That is Europa you see on the disc
Mars Watch
All images taken with:
Celestron NexStar 8i SCT
DBK 21AF04.AS
K3ccd/Registax4/PSP8
ALPO Member #4287
Lunatiki
Reged: 08/07/05
Loc: Amarillo, TX
Re: Jupiter w/Europa 08-01-08 good seeing new [Re: Lunatiki]
      #2553823 - 08/01/08 02:05 AM
Well, I hadn't planned on it at all, or even knew it was going to happen, but I managed to capture the entire transit of Europa across Jupiter at 10 - 15 minutes intervals. Seeing was just OK, but the results are decent. I'll most likely have them posted in a bit, but it might be tomorrow. I think I shot around 15 sequences or about 30 gigs. Might be awhile till I get a gif though. In all seriousness, since I'm not too good at making gifs, if someone out there is, I'd pay them for their time.
Mars Watch
DBK 21AF04.AS
ALPO Member #4287
Lunatiki
Reged: 08/07/05
Loc: Amarillo, TX
      #2553867 - 08/01/08 03:36 AM Attachment (17 downloads)
I think I'm cross-eyed after tonight. But here is a small version of the entire transit. Full version can be found at the link
Full version
Mars Watch
DBK 21AF04.AS
ALPO Member #4287
Pete Gorczynski
Reged: 05/09/08
Loc: Oxford, CT USA
Re: Jupiter w/entire Europa transit 08-01-08 new [Re: Lunatiki]
      #2554045 - 08/01/08 08:04 AM
Very nice sequence, Joel. Looks like you didn't get much sleep!
Pete G.
snowdragonusa
Reged: 09/04/07
Loc: Denver, CO
Re: Jupiter w/entire Europa transit 08-01-08 new [Re: Pete Gorczynski]
      #2554144 - 08/01/08 09:06 AM
Awesome captures! I might be able to make them into an avi for you.
Adam
12" LX200R
AT80mm piggyback
DSI Pro, DSI-C, LPI
Denver Astronomical Society
Brighton Astronomical Group
Alan Friedman
Reged: 08/30/07
Loc: Buffalo, NY
Re: Jupiter w/entire Europa transit 08-01-08 new [Re: snowdragonusa]
      #2554157 - 08/01/08 09:16 AM
Very nice work. I enjoyed the transit in the eyepiece last night.
clear skies,
Alan
Alan Friedman
www.avertedimagination.com
Sunspot
Reged: 03/15/05
      #2554259 - 08/01/08 10:28 AM
I so badly wanted to capture at least part of that transit, I got Jupiter into the scope (it was before the transit), laid down for 2 hrs and went outside to find clouds. Ah well, you did a great job capturing it!!
Paul
Paul Maxson
Mewlon 250, Tak TOA-130, SolarMax 60, SKYnyx 2-0M
http://www.sunspot51.com
Lunatiki
Reged: 08/07/05
Loc: Amarillo, TX
Re: Jupiter w/entire Europa transit 08-01-08 new [Re: Alan Friedman]
      #2554263 - 08/01/08 10:29 AM
Thanks guys. That was a rather tiring deal. Started a bit after 10PM local and posted the finish product at about 2:40 AM. One of the biggest pains was trying to be consistent in the processing, since seeing was spotty and variable. While shooting one avi, I'd be processing the previous in K3ccd. Luckily my scope tracked good all night. I do believe I might take tonight off (probably not though)
Mars Watch
DBK 21AF04.AS
ALPO Member #4287
solshaker
Reged: 06/06/06
      #2554371 - 08/01/08 11:30 AM
great job, Joel. i agree it can be tiring processing an animation especially with the varying conditions. its worth it when it comes out looking good, though.
My Gallery
David Rivas
Reged: 05/29/04
Loc: Lima, Peru
Re: Jupiter w/entire Europa transit 08-01-08 new [Re: solshaker]
      #2554438 - 08/01/08 12:08 PM
Hi Joel,
Very clean and detailed sequence for the altitude(the whole sequence!!!)
On the other hand a big effort...very hard job!!
Excellent job!!!!
David
Lunatiki
Reged: 08/07/05
Loc: Amarillo, TX
Re: Jupiter w/entire Europa transit 08-01-08 new [Re: David Rivas]
      #2554677 - 08/01/08 02:23 PM
Thanks guys. I hope to have an animation soon. Adam is helping me out and I'm seeing what I can come up with. But my skills are rather lacking when it comes to that stuff. I just did a quick run through of the images in order and I'm surprised that the color, contrast and gamma seem to be pretty consistent, so it should be a neat animation. Too bad the detail isn't sharper, but I think that is mainly due to seeing. I know my collimation was good and shooting over a hot roof didn't help.
Mars Watch
DBK 21AF04.AS
ALPO Member #4287
Lunatiki
Reged: 08/07/05
Loc: Amarillo, TX
      #2554848 - 08/01/08 03:49 PM
This is the best I've been able to come up with in regards to a gif. I just can't seem to get the fine alignment down, but then again, I don't know what I'm doing. You can see it drifting a bit through the sequence.
Animation
Mars Watch
DBK 21AF04.AS
ALPO Member #4287
solshaker
Reged: 06/06/06
      #2554886 - 08/01/08 04:05 PM
have you tried ppmcentre?
i export the avi as bmp files using vdub, then run them through to center them before heading to registax.
pcfe is a front end for ppm that works without using the command line. heres a link to icemans page that has a download.
link
my polar alignment usually needs adjusting every few minutes so ive found ppm essential to being able to line everything up for gifs without tearing my hair out.
My Gallery
FoxK
Reged: 11/07/07
Loc: Cape Cod, MA
      #2554902 - 08/01/08 04:15 PM
Lun
Registax can help you make a time lapse...it will be an avi tho, but you can import it into PS's imageplus to make a .gif
Load up the images like normal....hit the align...then look for "create integrated avi" tab. Sometimes it works well. I oftyen just hand align tho too.
Orion 80mm ED Apo Refractor
8" Classic Dob (used as Newtonian on CG5 mount)
Meade 70-AZ-A 70mm Guider using PHD
LS60TCaK/B600/C
CG-5 Advanced GT Mount
Nikon D40x with T-Adaptors
Philips SPC900NC
Imaging Source DMK 21AU04.AS
Dome=the box my mount came in so I can see my solar images in bright sun lol
- click for cloud prediction for Plymouth, MA. area
Lunatiki
Reged: 08/07/05
Loc: Amarillo, TX
Re: Jupiter w/entire Europa transit 08-01-08 new [Re: FoxK]
      #2555427 - 08/01/08 10:13 PM
Thanks Fox! Well, after about 15 hours of work total, this is the best I came up with.
web page
Mars Watch
DBK 21AF04.AS
ALPO Member #4287
snowdragonusa
Reged: 09/04/07
Loc: Denver, CO
      #2555456 - 08/01/08 10:43 PM
Joel - That looks great! It actually looks a lot better than I came up with!
Adam
12" LX200R
AT80mm piggyback
DSI Pro, DSI-C, LPI
2 registered and 8 anonymous users are browsing this forum.
Home
