Observing >> Deep Sky Observing
lymorkiew45
Reged: 12/30/07
Loc: San Jose, CA
NGC 6380 globular cluster in Scorpious new
      #2541598 - 07/25/08 09:24 PM
This is an, extremley, extremley faint globualr in the stinger of Scorpious, and I have thought about searching for this object, but at magnitude 11.5, I would think that this object would not stand out very well in a monster scope, I have read that this globular has been detected in moderate size scopes, and is very, very faint, and extremely small, (30 arcseconds), and it appears as one of the members as a faint double star, so this object is a challenge even in the largest scopes, I plan on seeing this object, but it is so low in the Southern sky, from my location...clear skies
To fail is to succeed, to not fail is to show that you cannot proceed, therefore life is just a learn, and not learn illusion.
20 year martial artist and amateur astronomer, I love it...Jorgen
Starfinder 16 EQ, and dob
DS-10
Orion XT 12i
Z12
All the Lanthanum superwides!
Orion ultrablock filter
9mm Nagler type 6
15mm, 25mm, 35mm Ultrascopics
Orion Shorty Plus barlow
Orion Lazer Colimator
30" dob planned out in far future!
Bill Weir
Reged: 06/01/04
Loc: Metchosin (Victoria), Canada
Re: NGC 6380 globular cluster in Scorpious new [Re: lymorkiew45]
      #2541931 - 07/26/08 01:24 AM
That's a full 10 degrees above the horizon from San Jose. It shouldn't be a problem if the sky is good.
Recently on two occasions, on nights of good transparency, I've observed with detail, NGC 6302 (the bug nebula) from my latitude. It was only 4 degrees above the horizon. I was using 304X magnification with my 12.5" dob.
If the sky is decent your glob shouldn't be a problem. My recent bagging of the faint glob NGC 6540, with my 6"dob at just a little over 13 degrees above the horizon says so.
Good luck.
Bill
6'' Orion SkyQuest
12.5'' f/5 Custom Truss Dob
William Optics 80mm ZenithStar II ED Doublet
f/5 25" newtonian on a giant GEM, any time I want
Observing sessions grand total for 2007, 171.
So far in 2008, 83
sgottlieb
Reged: 07/22/07
Loc: SF Bay area
      #2542003 - 07/26/08 02:49 AM
I found it very tough from northern California in my 13" (Livermore club site) over 20 years ago...
13" (5/30/87): extremely faint, small, very low surface brightness, visible only 20% of time with averted. Mag 9.7 HD 159073 is attached 40" SSW of center. Located 36' ESE of Howe 87 = 7.5/8.8 at 3". Failed to find on several previous attempts. This globular, along with N6749, are the two most difficult NGC globulars.
But it was much easier with a 12" from Australia!
12" (6/29/02): faint but not difficult. Appears as a 2' diffuse glow with no concentration. The observation was hampered by a mag 10 star at the SSW edge. Ton 2 is located 37' NE.
Steve Gottlieb
18" f/4.3 Starmaster
Adventures In Deep Space - New article on MASH planetaries
7500+ NGC/IC Visual Descriptions
NGC/IC Project
Never
Reged: 11/22/05
Loc: Finland
      #2542061 - 07/26/08 04:51 AM
I have to say the object is visible even in small refractors when it is higher in the sky. Extremely faint perhaps but visible. The near by Ton 2 is more challenging.
/Jake
Jaakko Saloranta - Some basic sketches.../
8" Orion DSE
4" Sky-Watcher
3" Konus RFT
RRaubach
AstroCowboy
Reged: 01/26/05
Loc: Douglas (Converse County),WY
Re: NGC 6380 globular cluster in Scorpious new [Re: Never]
      #2550733 - 07/30/08 04:08 PM
How small a refractor? I have tried and tried with my TMB203 f/7, using every trick in my bag of tricks! I have never detected even a hint of this globular. I have also tried using my Discovery 12.5", to no avail. From my site, NGC 6380 is a "horizon scraper" at best. There are very few windows of opportunity for me, since it is obscured by hills to my SW part of the time. This is a toughie! I have also failed to bag N6749.
Rodger
Meade SN-10 (UHTC) on Tak EM-200 mount/Antares rotating rings. Moonlite focuser.
Parallax 14.5" Newtonian on HD 200 mount (arriving soon!) w/ conical Royce mirror.
TMB 203 f/7 APO refractor on Tak NJP-160 mount.
Discovery 12.5" PDHQ
Schneider 18x80 "Flakfernrohr" binoculars/tripod mounted. Canon 15x50 IS binoculars
Unihedron Sky Quality Meter
Never
Reged: 11/22/05
Loc: Finland
Re: NGC 6380 globular cluster in Scorpious new [Re: RRaubach]
      #2551619 - 07/30/08 11:46 PM
NGC 6380 was barely visible with a 4.7" refractor from La Palma (28N) few months ago. I'm sure being further to the south helps in this case.
/Jake
8" Orion DSE
4" Sky-Watcher
3" Konus RFT
sgottlieb
Reged: 07/22/07
Loc: SF Bay area
      #2556747 - 08/02/08 08:56 PM
/Jake
We you able to view Ton 2 in the small refractor?? Here are my notes with a 12" from outside of Sydney, Australia...
12" (6/29/02 - Bargo, Australia): at 186x, this highly reddened globular appeared as a very faint glow, best viewed by keeping mag 4.3 Q Scorpii located 6' SE out of the field. Ton 2 appeared as round, diffuse glow, just 1' in diameter with a faint star superimposed and a few around the edges including a mag 11.5 star just off the south side [40" S of center]. More difficult than NGC 6380 which was viewed a few minutes afterwards.
Steve Gottlieb
NGC/IC Project
Achernar
Reged: 02/25/06
Loc: Alabama, USA
Re: NGC 6380 globular cluster in Scorpious [Re: RRaubach]
      #2557392 - 08/03/08 10:02 AM
I had no luck with NGC-6380 so far either, but not because of lack of aperture. A 10-inch should be able to show it, but the skies here are hazy and light pollution is bad too. Even in coastal Alabama, it does scrape the horizon.
Taras
10-inch F/4.5 Discovery Dob
6-inch F/8 Homebuilt Dob
4 1/4-inch F/4 Homebuilt reflector
3 registered and 1 anonymous users are browsing this forum.
Moderator:  matt, Olivier Biot
Home
