AstroRealtor
Reged: 03/26/08
Loc: Terra Firma
Catsperch observing chair
      #2557493 - 08/03/08 11:29 AM
Has anyone built one of these from just the plans? I realize they are available in kit form as well. I'm trying to decide if building it from scratch is a worthwhile project. Does anyone know the degree of difficulty?
Clear Skies, Jim
Discovering: Messier objects, Deep sky treasures, NGCs, Double stars, & Nebulae of all kinds.
Televue 85 "Polaris" Mount
Custom Crafted Newtonian Dob 8" f7 w/Feathertouch
Celestron Cometron Reflector 114mm f8
Zeiss Diafun 8 X 30 Binos
Zeiss 10 X 56 Binos
Aldrich Astronomical Society
John Jarosz
I'm being watched...
Reged: 04/25/04
Loc: Chicago area, IL
Re: Catsperch observing chair new [Re: AstroRealtor]
      #2557542 - 08/03/08 11:58 AM
Depends on your woodworking skills. It's hard to assess the degree of difficulty. You should have a tablesaw and drill press as a minimum. You need a router to round off the corners.
I've built one from the plans The plans are very detailed and if followed, results in a perfect chair.
If you have a wood source, there's no reason you can't simply make it from the plans.
The chair is very nice to use as well,, a good design.
john
6" F4.6(w/Paracorr) GEM reflector, 8" F11 Dall Relay Scope
6" F5 RFT Refractor, Garrett Gemini 20x80 LW
AstroRealtor
Reged: 03/26/08
Loc: Terra Firma
Re: Catsperch observing chair new [Re: John Jarosz]
      #2557574 - 08/03/08 12:19 PM
I think the woodworking part will be no problem as I have the necessary tools and have completed projects similar in scope. My concern is more about the hardware and whether or not it will be readily available where I live in Massachusetts.
Clear Skies, Jim
Zeiss 10 X 56 Binos
John Jarosz
Reged: 04/25/04
      #2557643 - 08/03/08 01:19 PM
There is only one piece of hardware. i got mine online. I'll have to look for where I got it.
I think the parts list said where to get it. I'm sure Jim would tell you where to get that one piece.
John
AstroRealtor
Reged: 03/26/08
Loc: Terra Firma
      #2557660 - 08/03/08 01:29 PM
John
Thanks John, It was the hinge that I was concerned about, the rest of the hardware is standard stuff. I'm getting excited about completing this project and saving my back during those long observing nights! All assistance is greatly appreciated.
Clear Skies, Jim
Zeiss 10 X 56 Binos
Astrowood
Reged: 04/02/05
Loc: New Brunswick, Canada
      #2557674 - 08/03/08 01:40 PM Attachment (11 downloads)
If you go with a lower strut, down further in the supporting frame, you will only need a strap hinge to attach it. The added benefit is the seat locking pin will not have to be removed from the seat, as you adjust up and down the full length of the back.
Roy
22 X 100 Antares
20 x 80 Meade
couple of Pmounts
8" F/5 Dob
4" SkyWatcher
Observing Chair
Wooden gadgets to numerous to mention
Observing Buddies "Max & Sam"
www.astrowood.com
Edited by Astrowood (08/03/08 01:42 PM)
Bill Kocken
Reged: 08/07/04
Loc: Coon Rapids, MN
Re: Catsperch observing chair new [Re: Astrowood]
      #2557904 - 08/03/08 04:03 PM Attachment (12 downloads)
I built one from similar plans. The plans that I had called for 1" real thickness hardwood. That is overkill. I used 1" (3/4" nominal) thickness lumber. As for the upper hinge, I used a 1" dowel as a pivot pin. No hardwae needed. My biggest challenge was the spreader bar. I also put it down low. I made mine tall enough to sit on and observe at the zenith with my 16" f4.5. I got tons of compliments on it.
Bill
16"F4.5 Homebuilt Truss Dob
2 - 8"F6 Homebuilt dobs
Member, Minnesota Astronomical Society
7 registered and 7 anonymous users are browsing this forum.
Moderator:  Don W, Joe Cipriano
Home
