Observing >> Deep Sky Observing
moron392
Reged: 08/20/07
Loc: Charlotte, NC
M4
      #2558991 - 08/04/08 08:18 AM
i cant seem to find M4. no matter what scope i look for it in, i just cant find it. i always start with binoculars, and look a little to the right of antares. then, i do the same with my scope! and it seems to not be there!
"If you've done something right, people won't be sure you've done anything at all."
http://www.freewebs.com/moron392/index.htm
60mm meade ngc60 refractor.
Meade 70AZ-TR (short one)
50mm homemade refractor (occasionally with a solar filter)
starblast4.5EQ
6mm,15mm expanse eyepieces
9mm meade Mh eyepiece,17.5mm Meade MA
nikon 7x35's
scopethis
Reged: 05/30/08
Loc: Kingman, Ks
Re: M4 new [Re: moron392]
      #2559029 - 08/04/08 08:41 AM
In my 12x80 finder, Antares and M4 are both in the field of view. I would expect this to be the case with a 60mm refractor, but not sure.
JakeT93
Reged: 06/28/08
Loc: Williamstown, NJ
Re: M4 new [Re: scopethis]
      #2559094 - 08/04/08 09:36 AM
It's a little tough, I even had trouble in my 10"! In the scope, go to lowest power, and go a little right, slowly. I's big and resolves in a 10", but I'm not sure about 4.5", I never found it in that. Are you looking into a light dome, or are your skies bright?
-Jake the Snake
My equipment:
Orion DSE 10" Light Bucket!
10x50 Finder and ebay bracket
40mm GSO Plossl
32mm Celestron Plossl
2x Antares Barlow
25mm and 6.7mm Meade 3000 Plossls
Orion Explorer II 10mm and 17mm Kellners
Orion SkyGlow Ultrablock
Antares ND25
70 M's Obsreved
All Planets seen
xfile101
Reged: 12/08/07
Loc: Ocean Gate, NJ
Re: M4 new [Re: JakeT93]
      #2559472 - 08/04/08 12:51 PM
M4 is a bit of a tricky Messier object, it's surface brightness is not, umm, bright. It is also spread out quite a bit as opposed to other globulars hence the low surface brightness. In my 8" it's not easy to detect but after awhile it just appears. Sounds like you are in the correct area so here's what you do, get the scope pointed in that area, get a towel or hood, put it over your head and use your adverted vision. The glob will appear as a faint glow if you keep at it. This, IMHO, is one of the tougher Messier objects to see. Keep at it, you'll eventually find it.
Orion XT8I
Celestron 114EQ Firstscope
Meade 70mm
Astroscan
David Knisely
Reged: 04/19/04
Loc: Beatrice, Nebraska
      #2559710 - 08/04/08 03:10 PM
I think that the best way to find M4 is to form an isosceles triangle with Antares, Sigma Scorpii, and M4, with M4 being at the fattest vertex. From a dark sky site, M4 is actually visible to the unaided eye as a small faint fuzzy spot, and is fairly easy in a properly aligned finderscope. It also begins to show many of its component stars in a 4 inch, and has a nice "bar' of stars extending across its middle. Under light pollution, it may be a little tough, but once you get away from the skyglow, it is one of the easier Messier globulars. Clear skies to you.
David W. Knisely
Hyde Memorial Observatory
http://www.hydeobservatory.info
moron392
Reged: 08/20/07
Loc: Charlotte, NC
Re: M4 new [Re: David Knisely]
      #2561417 - 08/05/08 10:03 AM
there appears to be a star where M4 should be....i'll check back tonight!
starblast4.5EQ
nikon 7x35's
Illinois
Reged: 12/18/06
Loc: near Chicago, Illinois USA
      #2561931 - 08/05/08 02:11 PM
Light pollution in my backyard is very bad! I can spot M4....only few bright stars on my 10"! M13 is much better! M22 still not great but better than M4!
M4 is easy to find on 10 X 50 binocular in pretty dark sky as fuzzy star! When you are in dark sky and you will find M4 then marked on your paper to know the excatly location and you able to find it in light pollution when the night is right.....clear and no moon!
Astronomer since 1975!
Meade 16" Lightbridge Dobsonian
Orion 10" SkyQuest Classic Dobsonian
Tele Vue Eyepieces
Orion Expanse Wide-Field 6mm eyepiece
4.5" F5 Reflector since 1982!
Orion Narrowband and SkyGlow filters
Member of IDA, let's fight light pollution!
Old Edmund 6"F8...donated to cousins
Super Polaris C8...donated to Byron Observatory in Illinois
JakeT93
Reged: 06/28/08
Re: M4 new [Re: Illinois]
      #2563977 - 08/06/08 01:19 PM
In my old 4.5", I thought it was easy as anything, but I saw a star where it should have been also. Wait till a good, clear and cool moisture free night to be looking at the lower constellations. There are 2 pretty clusters arount the Scorpion's tail though, and Saggitarius has a lot to offer for your size telescope.
-Jake the Snake
My equipment:
40mm GSO Plossl
2x Antares Barlow
Antares ND25
70 M's Obsreved
All Planets seen
8 registered and 3 anonymous users are browsing this forum.
Moderator:  matt, Olivier Biot
Home
